2000 Gt
Engine Blew Piston - Still Reliable? (PICS INSIDE!!)
okay so after a high speed cruise on the highway i blew a piston, just pulled apart the engine to find out the piston was mangled a bit in there. my first thought was okay time for a new engine, my 2000 gt windsor block has 98k at the time of this happening, i know these engines are good for 200k or so, anyways i've been looking into mmr 4.75 block, but just got the cold awakening of the fact that my car won't be on the road for probably another 2 months if i go with the mmr block, i need my car for school.
Anyways my ultimate question is if i rebuild my stock windsor block (new piston, re-honing the cylinder, and put a new set of comp cam's in) will the engine hold up? or simply just blow again? heres the pics, thanks! (the cylinder wall has a 1/1000th scratch/hole in it) which is apparently pretty minor. and re-honing should get it back to where it was. ![]() ![]() okay here is a pic of the other 3 pistons, any idea as to why they look half burnt? it's probably the fact that the fuel is injected on a certain side. ![]() Thank you everyone\ p.s if i do decide to rebuild engine & get cam's what cams do you guys suggest for most power without sacrificing reliability for daily driving.
2000 Gt - full bolt on's 3.73's eibach suspension. 265hp/307tq Last edited by Mike Hadz; January 6th, 2012 at 06:16 PM. |
95gt,67maro,05sti....
14.8@93,13.6@101,
If you rebuild and fix tuning issues you will be good. If you rebuild and don't fix tuning you may blow again. If you go MMR and don't fix tuning you may blow that too.
2000 Gt
shameless...
2000 Gt - full bolt on's 3.73's eibach suspension. 265hp/307tq |
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
Sorry but that whole motor is toast. The rest of the pistons look like they were detonating.
2000 Mustang GT Built 4V Motor with Sullivan Single Plane Intake Custom 66MM BB TT kit Borla XR-1 Dumped before rear Moser built 9" Rear 35 spline WaveTrac Diff with 3.75s 35 spline Moser axles 14PT roll cage and minitubbed
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
once the motor is built i would send your injecters out and get them inspected and flow matched. a good thing would be you had a bad tune and that is why your motor went but more often than not you had other issues.
![]() bone stock from the factory! |
MM's king of Neon's
404 - car not found
17.81@87
If the damage was limited to that cylinder alone, and you are aware of what cause the issue and remedy it, I see no problem with replacing it.
However I can't see all your pistons and if they were detonating. If they've taken some damage you'll need to replace them as well. Either way, I would want to find out what caused the detonation, and fix it. Was this during a WOT pull? Is your tune good? AFR? Bad injector? etc... Fix the underlying problem or you'll be replacing yet another piston.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
#7 | |
2000 Gt
2003 mustang v6 ;)
slow
its tough to tell from your pictures, it looks like build up on the tops of the pistons which is normal for motors especaily to favor the side of the intake valve. pistons that have been running lean look grey/white and pitted out from detonation.
#9 | |
MM's king of Neon's
404 - car not found
17.81@87
If this was in fact a good dyno tune you were running and that was the only piston damage then I'd look at a mechanical failure, such as injector. You might be able to get it flow tested to see if it's still good.
Use the block and crank, bore, forged pistons new forged rods, cams, injectors, forged oil pump, dynamic balanced. Rock on
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
1999 GT 35th LE
Personally I would not rehone a 100,000 mile engine, I would get it bored to .020 and go with new rods/pistons and have the crank worked over. Add the price of all that up and your only a few hundred short of buying a shortblock.
How long have you had this car? Did you ever experience any issues before taking this high speed cruise? How fast and for how long were you running during this high speed cruise?
![]() Drive it like you stole it |
2003 mustang v6 ;)
slow
getting a block machined adds up. gotta figure minimum would be cleaning, square deck, tq plate, bore/hone, and if you use arp main studs you need to get a line hone done. at your power levels and anything under 600 hp i would stick to stock main studs. hell i have not heard many issues with running stock main studs for anything under 800 hp. it is almost just as cheap to get a budget sb for the price of getting all your stuff re-machined, and balanced. now companys are making sb's as cheap as 1500 dollars.
#13 | |
2000 Gt
12.73@111.36
All of my cars ran great until I blew them up. You are correct. You can rebuild the block but you are going to need more parts than you are anticipating. With damage to a piston like that I would think it would have to be bored out to fix the cylinder. I really don't think honing will do it. If you are on a limited budget and you need to get the car fixed quickly then you need to go to a salvage yard and get a replacement motor.
I've had to do that three times in the past. All of the motors were good and lasted a long time.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
#15 | |
2000 Gt
Today was a warm day here and the first time I had drove the car since changing the boost level. i knew the timing was borderline and today it rattled TWICE hard enough to scare me lol. Held up, pulled 1 degree and banged on it some more haha. Moral of the story. Some stock motors hold, some dont but either way they will all meet their maker sooner or later if pushed hard enough.
2000 Gt
damn... my mechanic has probably already put the engine back together, no chances it will hang up just honed?
12.73@111.36
I've been around a long time and I wasn't very smart when I was your age. The first motor I blew up was my 1966 Dodge's 426 ci Wedge. Antifreeze had gotten in the oil and I drove it anyway. I replaced it with a 440. The second was my 1969 Camaro's 350. I was racing down some back roads. To get through the first corner of an S curve I downshifted to third. To get to the second part of the S curve I went to second and spun the motor way too high. I replaced it with a built 327 which lasted 500 miles. I replaced that with a 305 truck motor. I blew up the third motor missing second while powershifting (no rev limiter). It was a 1973 Pinto. I blew the motor on Friday. Bought a salvage yard motor and transmission on Saturday. Put them in on Sunday. And drove the car to work on Monday. Needless to say nowadays I watch my oil carefully, I watch my rpms when downshifting, and I no longer powershift.
P.S. If you hadn't noticed I'm a little conservative when it comes to max horsepower, max boost or max rpms. Now you know why.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. Last edited by Eagle2000GT; January 7th, 2012 at 03:01 AM. |
12.73@111.36
None of us have seen the motor. Your mechanic has. If you took it to a respectible shop then you'll probably be OK.
LOL EAGLE word on the powershifting especially some of the older trannys. I used to race my 67 Mustang in HS. Was a 289, 250hp N20, tunnel ram, 4 speed. Sent the main caps off once power shifting from 3rd to 4th....... went into second, on the bottle lol. That was a bad night. The oil pan looking like a grenade came through it. We litterally picked up 5 pistons and rods.
Threads Similar to: Engine Blew Piston - Still Reliable? (PICS INSIDE!!)
| Finally getting engine together. (Pics inside) Where to hide the wires...? | Mustang46 | 99-04 | 22 | January 1st, 2012 11:21 AM |
| New motor blew a piston or something? :( | Roadrashjr | 99-04 | 34 | October 12th, 2011 11:12 PM |
| fire extinguisher at work blew up!(pics inside) | 00mustang00 | The Clubhouse | 20 | November 12th, 2010 01:13 AM |
| engine bay painting..pics inside... | oscrfsh | 5.0 Mustangs | 15 | June 16th, 2010 05:36 PM |
| how reliable are piston rings | ddarkslayer | 5.0 Mustangs | 1 | November 12th, 2009 01:54 AM |
