2000 Mustang Gt
no clue
Taking My Car To Ford Tomorrow...
I did some research on my stalling issue when coming to a stop and stumbled upon this
2000 Ford Mustang Vehicle Speed Control Complaints I heard that this issue is with 99 and 00 stangs and ford knows about it. Sometimes its the iac (not what my problem is) but I guess ford updated this guys computer and it solved the problem so Im going to check with my ford and see what they say. Also my pass window is all screwed up, Ive tried to fix it with no luck so Ill let them take a look at it too. Hopefully this solves my problems. Ill report my results back tomorrow.
Just because your cars loud doesnt mean its fast |
2003 v6/2003 GT vert
![]() iTrader: 11 reviews
Good luck! Hope they can figure out your issue!!
![]() 2003 sonic blue v6- 18" gianna's, straight pipes, 12" DC level 5 with DC 3.5 K 2003 sonic blue GT vert- Bout to be a Procharged P1sc BEAST
2000 Mustang Gt
no clue
Thanks!!! Yea I hope so too. Its a lot of fun to corner with no power steering or power brakes while trying to restart my stang
MM's king of Neon's
404 - car not found
17.81@87
You're going to get boned.
If it is a calibration issue they're going to whack you for an hour labor for a 5min job. Unfortunately there's no real alternative. My 02 Neon has the same sort of problem, they issued a TSB for the IAC control in the calibration, and Dodge wanted $100 to upload a new cal. Yeah right. I'll live with low idle on occasion, but no stalling. And FWIW my 2000 had the same issue, but it turned out to be a combination of vacuum and exhaust leak from the PO. Make sure to check all those sorts of things before Ford screws you.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
#5 | |
2000 Mustang Gt
no clue
2004 mustang gt
yes, i work at ford. they are going to charge you to diag your car
Vortech Intercooled hitech stage 2 cams 373 gear 75mm tb and c&l plenum bbk l/t 410rwhp 390ft lb @7psi ![]() image host |
'99 GT 35th Anniversary
14.266 @ 103.41
Mine does this also, and does it a few seconds after the RPM surge of the A/C engaging too. Mine hasn't stalled yet, but the RPMs drop very low, to the point of the car shaking.
SMR #2043 |
12.73@111.36
Mine does this also. More often in winter than summer. I tweaked the throttle body stop screw a little and that helped. A little extra by-pass air gives the IAC more time to react. Let us know if they fixed the problem.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
99 limited edition vert
auto or manual?
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
Baker Jr.
Alot of stangs do this..mine used to then stopped after new tune
MMR-Modular Mustang Racing Phils Machining-For your ABS Module Delete Manifold! American Muscle-www.Americanmuscle.com HorsePower By Hermonn-TUNER THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
2000 Mustang Gt
no clue
Wow I didnt think that this thread would have this many replies lol. To answer limiteds question its a manual. Anyway, to spare me a couple hundred bucks i called ford this morning and talked to a tech. He told me he had the same year stang and its either a bad IAC ( I already replaced mine) or a vacuum leak. He told me its probably one of the green or red vacuum lines and for me to follow them and look for leaks. I told him that I have an evap code (p045 I think) which it no purge flow or a large vacuum leak. He said that could be the problem. I already have the new purge valve so its a matter of me getting around to do it. Ill let you guys know how it goes.
#12 | |
2000 Mustang Gt
no clue
Haha thanks. I tried taking my pass fender off today but I cant get to the bolts by the door. I need a hack saw to get the screws to take the fender liner off so I can get to it thru the wheel well.
Threads Similar to: Taking My Car To Ford Tomorrow...
| Taking my discovery flight tomorrow! | Fox2102 | The Clubhouse | 43 | April 7th, 2010 11:58 PM |
| Ford Is supposed to announce the new V-8 Tomorrow.... | Smoothgrandmama | The Clubhouse | 20 | December 3rd, 2009 01:03 AM |
| Taking the GT to the track tomorrow :) | supermachone | The Clubhouse | 11 | October 2nd, 2008 10:11 PM |
| taking off cat | mm49271 | V6 Mustangs | 6 | March 24th, 2008 09:55 AM |
| Taking my car to get brakes fixed tomorrow! | MustanG_guy17 | V6 Mustangs | 20 | August 16th, 2007 11:10 PM |
