02 gt coupe
Limits Of Stock 2v Crank
Hey guys, I got a spare engine and want to slowly piece together parts to build the bottom end to hold about 600rwhp....I kno forged rods and pistons are a must but how strong is the stock crank...who has actually broken one....Im not looking for fake numbers that people say to try an sell stuff....
For sale...vortech 6 rib 3.6 pulley new..55 shipped Vortech 6 rib 3.48 pulley 100 miles on it..50 shipped used aviator pump with 80k..50 shipped 01-04 steeda underdrive pulley set...about 200 miles on it before going s/c 160 shipped |
MM Official Sammich Maker
1999 mustang gt
n/a
![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
I think its somwhere in the range of 600hp.
If it was me and I'm building the motor I would put a new crank in it, why spend all that money on that type of a setup and not upgrade the crank too.
KASE Racing
72 Chevell 500hp 74 Comet 500+hp and spray 99 Mustang GT bolt on's and 93 tune 85 Notch 520ci BBF |
2003 gt
5.4 32v on the way
cast crank can take 600hp, as long as you keep the RPMs reasonable. You will probably be told to get a cobra crank, they aren't expensive and will take whatever power you could ever make.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
man, there is has been some go over 600. I was at 599rwhp with my stock crank but spun a bearing.
Ive got a set of rods and pistons. 4340 MMR H beam rods with .20 over Manyley 18cc pistons. About 2000 miles on them or so. If that.
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
02 gt coupe
What are u asking for them...and did the rod get damaged from the spun bearing
02 gt coupe
I will honestly like to sit at 450-475rwhp ( superflow dyno) on the supercharger and occasionally spray a 75-100 shot on a separate fuel supply just for the heck of it....plus the torque would be ridiculous
Never Enuf on here I believe has spun a stock crank to 8k and made some decent power to boot
I havent pulled them out yet. I will have the rod checked before i was to sell them. I just pulled the pan and saw my problem.
No need for a forged crank in most applications. The factory cast crank is much lighter also. My crank after all the work was done to it was something like 14lbs lighter than my friends cobra crank. For a build under 600rwhp I would run the stock crank. Spend the money else where.
My new engine build is 14lbs boost, h beam rods, 16cc dish forged pistons, New stock PI heads, CMS stage 2 blower cams. I'm shooting for over 500rwhp. This is a budget build honestly.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
02 gt coupe
Thanks guys....I also feel like the stock crank is fine ..especially if prepped right I think it'll be fine at less than 600hp and 7k rpm
99 limited edition vert
you may not need one, but if you keep looking for a cobra crank you can usually find a good deal on one. the peace of mind is worth the couple hundred to me
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1MTuned by Joe at http://www.tricktuners.com |
2003 Mustang Fauxbra
N/T @ Fast
Check NMRA Real Street. Almost everyone is running in the 9s and almost everyone is running stock cast 6 bolt cranks. That says enough in my book.
![]() All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now? 03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold |
2000 gt
im at 414 rwhp and 450 rwtq with my 2v crank spun up to 6300 rpm. i think rpm kills stock cranks more than horsepower does.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
im late on this topic but a few things to consider when choosing a crank. for a street driven car making 600 or less hp turning under 7k rpms the cast crank is fine. hell i would push it even higher with no stress about it. but where to consider going to the steel crank is when you have a car that sees alot of track time on slicks. steel cranks rob hp but the gain from them is their ability to flex. on hard launches with trans brakes or leaving the line off a 2 step manual it sends a shock threw the crank and steel cranks are able to handle much more abuse. many may say they have never seen a cast crank fail but 99% of people dont run their car like that with over 600 hp.
![]() bone stock from the factory! |
N/T @ Fast
Real street cars are mostly in the 525 hp range....... they do, however shift in the 8000 rpm range. Decent parts assembled well can make it happen.
02 gt coupe
You make a good point stal...but in my case its looking like the stock crank will do just fine...I rarely get a chance to go to the track...and i don't rag my cars that hard anyways...
and of course ill have the crank turned if needed and proper balance is a must
Threads Similar to: Limits Of Stock 2v Crank
| Limits of a stock LS2? | Calogero6685 | The Clubhouse | 4 | September 14th, 2011 03:41 PM |
| Limits of the stock fuel pump?? | 2011GT1979 | 2011+ | 10 | November 18th, 2010 04:07 PM |
| Stock 4.6 2v Block Limits | 0949er | Modular Mustangs | 6 | April 9th, 2010 09:57 AM |
| Limits Of Stock GT bottom End | 03GT_Hybrid | 99-04 | 15 | April 11th, 2008 08:25 AM |
| RPM limits of a stock 4.6. | ModMustang97GT | Modular Mustangs | 31 | January 7th, 2008 04:46 PM |
