FRPP Aluminum Driveshaft Problem
Old January 7th, 2012, 07:38 PM   #1
13.91 @ 102.04
02'TrueBlue will become famous soon enough
Maybe it's not a problem, but better safe than sorry..I was gunna install my FRPP driveshaft that I ordered from American Muscle about a year ago (Never got around to installing it lol), and when I had both driveshafts next to eachother, the new aluminum one was about half an inch longer than the stock one. My friend's dad who was helping us was really concerned that the size difference could mess with the tailshaft of the trans if I hit a bump or something and it caused the driveshaft to go in a tad...Is this normal or should I be flipping on someone?
TRUE BLUE CREW MEMBER #6
Old January 7th, 2012, 08:12 PM   #2
1_nice_03_gt's Avatar
2003 ford mustang gt
13.9 stock
1_nice_03_gt has a spectacular aura about1_nice_03_gt has a spectacular aura about
hmm never notice it on mine when i installed it, now you got me thinking damn it. havent notice any issuse and my car is lowered
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
Old January 7th, 2012, 08:20 PM   #3
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
I can't see it being to bad? Is there anyway you can take measurements off another one?
Rock stock
Old January 7th, 2012, 08:23 PM   #4
13.9 stock
arent cobra's drive shaft longer? could have ordered the wrong one
Old January 7th, 2012, 08:28 PM   #5
13.91 @ 102.04
Unfortunately I can't get my hands on another FRPP driveshaft lol. And cobra's are different, but I definitely ordered the right one.. And it fit into the tailshaft just fine; we're just worried it would go in further than the stocker and possibly cause damage if something was maybe cut wrong at the factory
Old January 7th, 2012, 08:28 PM   #6
number1gt's Avatar
2002 mustang gt
Cobra drive shafts are shorter due to the extra length of the t56
Rock stock
Old January 7th, 2012, 09:26 PM   #7
Pittbull's Avatar
2001 Mustang GT
If you're not first you're last
Pittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to beholdPittbull is a splendid one to behold
iTrader: 6 reviews
Send a message via AIM to Pittbull
hmm that is strange.. id contact someone from frpp honestly cuz that sounds really weird. i wouldnt b worried about it hurting anything but id b worried about it not fitting but if it fits i guess itll be ok? idk... id definatly talk to someone that sells/designed it. if at all possible
Stock Rear Springs FOR SALE! PM Me
Stock 99-04 GT Exhaust Manifolds FOR SALE! PM Me
Old January 7th, 2012, 09:40 PM   #8
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
kinda of curious where your measuring from, are you including the yoke.
the reason I'm asking is there are diffrent yokes depending on which driveshaft you have.
fyi, all 79-04 mustangs (except irs cobras) use the same basic shaft so the basic shft on yours being the wrong length would be strange
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 7th, 2012, 09:49 PM   #9
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
The drive angle is so shallow that 1/2" difference in overall length will make less than 0.2" difference in travel. Insert the tranny end into the tail housing and push it fully forward, if the pinion drive flange is 3/4" to 1" or more from the pinion flange with the rear-end hanging then you are good to go...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old January 7th, 2012, 11:05 PM   #10
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
X2!! how long the drive shaft is, is not an exact measurement and there is some give in how long it is.
bone stock from the factory!
Old January 8th, 2012, 02:31 AM   #11
13.91 @ 102.04
hm. I wish I had access right away, I'd check again. I measured from end to end of the shaft, not including the yoke; the yoke was the same length. I'll have to check up on it as soon as i can get back onto my friend's lift and get back to everybody. Thanks for the input
Old January 8th, 2012, 05:03 AM   #12
Mike Hadz's Avatar
2000 Gt
Mike Hadz is on a distinguished road
if your car is an automatic and the drive shaft is for a manual i think it fits nice if you remove the yoke? that's what i've heard so if thats the situation maybe remove the yoke, does it drive oddly?
2000 Gt - full bolt on's 3.73's eibach suspension. 265hp/307tq
Old January 8th, 2012, 10:46 AM   #13
13.91 @ 102.04
I have a 5 speed. and I ended up putting the stock one back in for now lol I wasn't trying to break anything before I knew for sure it wasn't a mess up
Threads Similar to: FRPP Aluminum Driveshaft Problem
FRPP aluminum driveshaft...how strong? Mus408 99-04 7 January 30th, 2011 09:20 PM
FRPP aluminum driveshaft install. 96SNAKE 4V / SVT 7 August 13th, 2010 06:12 PM
pulleys or frpp aluminum driveshaft for better overall ET? texasd18e 99-04 24 April 2nd, 2008 09:39 PM
