I Got 99 Problems
Old January 7th, 2012, 08:36 PM   #1
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
I Got 99 Problems
well, not 99, but a few. put sfc's on the car tonight, and while up on my buddies lift, he pointed out i have coolant running down the side of the transmission tunnel. awesome. then, at the back end, noticed that i have oil coming out of the pinion seal. rearend has about 3k on it. tits mcghee, and i also got a a throw out bearing going bad.
never noticed oil where i part from the rearend, and thought i had a coolant problem awhile back, but did a system test and it didn't show any leak at 15PSI on the coolant system. what the heck could it be? hopefully leaking at the manifold instead of the cylinder heads.
dunno what to do about the rearend, other than have it rebuilt again (wife will be happy lol). it's also making a "wah wah wah" sound on deceleration. if the headgasket is bad i'll lose it.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old January 7th, 2012, 08:57 PM   #2
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
What about the heater core hoses?
Rock stock
Old January 7th, 2012, 09:03 PM   #3
Mustang_Girl_32's Avatar
2003 v6/2003 GT vert
Mustang_Girl_32 will become famous soon enough
iTrader: 11 reviews
Man this situation just plain sucks.. May god be with you lol
2003 sonic blue v6- 18" gianna's, straight pipes, 12" DC level 5 with DC 3.5 K
2003 sonic blue GT vert- Bout to be a Procharged P1sc BEAST
Old January 7th, 2012, 09:14 PM   #4
2000 gt
it COULD be that, but from where i saw the coolant, doesn't seem it would be. i didn't see any on the head though so perhaps.
HARDCORE CREW
Old January 7th, 2012, 09:49 PM   #5
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Antifreeze, idk. Mine must be leaking too because everytime I check it in 2 weeks its low. Hopefully its not going into the motor.
The rear end, probably just needs to be resealed. Pretty common
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old January 7th, 2012, 10:30 PM   #6
2000 gt
nah shaun it's actually leaking out of the front of the pinion seal. unless that's the seal you were talking about, and it's a PITA to fix lol.
as far as the coolant leak, my friend pointed out that it could be the o ring on the coolant pipe running through the valley. i'll have to let it warm up and check it out later on. possibly tomorrow, supposed to be kinda nice here today.
HARDCORE CREW
Old January 7th, 2012, 10:36 PM   #7
MyGT's Avatar
13.1@105
MyGT has a spectacular aura aboutMyGT has a spectacular aura about
iTrader: 7 reviews
The seal in front of the pinion is a royal pain in the ass seeing that it requires you to reset the pinion lol.
2009 Super-Stangs Fantasy Football League Champion
Thanks Brees!
Old January 7th, 2012, 11:00 PM   #8
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
i have re-done the pinion seal with out opening up the diff. you gotta have good sense of touch to set the pre load considering the crush collar has be crushed already. this time i used a solid collar so i dont have to swap it out anymore. as for the coolant good luck, 2v's manifolds, and heater cores are always a problem.
btw if it is a real small leak in the rear end i would just leave it and check the level every so often.
bone stock from the factory!
Old January 7th, 2012, 11:08 PM   #9
2000 gt
stal how do you check the level? just curious as i've never done that before.
HARDCORE CREW
Old January 7th, 2012, 11:11 PM   #10
stal94gt's Avatar
2003 mustang v6 ;)
slow
there is a fill plug at the front driver side of the rear end. it uses a 3/8th drive to remove it. it is just above the shoulder.
Old January 8th, 2012, 09:28 AM   #11
laoutlaw01's Avatar
laoutlaw01 is on a distinguished road
Yep,^ +1. Just fill it till it runs out the hole.
Old January 8th, 2012, 10:26 AM   #12
jkolbfleisch's Avatar
2001 Mustang GT
jkolbfleisch will become famous soon enough
If your Head Gasket were bad, the coolant would never leak out the side of the block. It'd burn up inside before it ever made it out. Plus is normally leaks into the cylinder or oil passage. I'd put $20 on a leaking heat core hose.
Just tell your body your leaks are "Rust-Prevention"!
2001 Mustang GT [518 WHP, 502 WTQ][P1SC + 10psi][MMR900][Trick Flow Heads/Intake][Stage 3 Blower Cams][JBA Headers, Magnaflow Tru-X, Flowmasters][11.89@119mph]
Old January 8th, 2012, 01:34 PM   #13
2000 gt
i let it get fully warm today, and didn't find where it was leaking from from up top, so i'm not sure. my coolant levels are ok, so i don't know. it is coming from an area where you'd think it would be the heater core though, on the passenger side. weird thing is when i put in my driveshaft loop, the carpet beneath my driver side floorboard was damp, but not the passenger side, which is where it should be damp i would think. is there a drain somewhere for the heater core? i've never had this problem in this mustang.
to top it off, i changed the oil in my wifes car and my dodge truck today, and while under my dodge, noticed that there is a coolant leak on the 4.7 in my truck as well. i can see where its coming from though, appears to be around the water pump like the gasket is bad. only has 50k miles on it so i wouldn't think it'd be leaking that soon but no surprise. i'm gonna keep driving it and monitoring my levels on both vehicles lol.
HARDCORE CREW
Threads Similar to: I Got 99 Problems
CAI problems rafter40 V6 Mustangs 31 March 1st, 2011 09:56 PM
Car problems. SNmustang95 94-95 3 January 27th, 2011 01:28 AM
new with temp problems and trans problems 89Bullitt 2.3 Mustangs 4 September 18th, 2010 03:14 PM
2.3 problems ks_emt 2.3 Mustangs 36 June 27th, 2007 01:46 PM
Car problems! stanggurl2 5.0 Mustangs 6 June 13th, 2007 11:25 AM
