2001 Mustang GT
What Could Cause This Problem
I have a 01 GT auto and I get about 195 miles out of a full tank. Engine is completely stock with a drop in K&N filter. Car runs smooth, no check engine light, no leaks, no smells or anything. I only drive from work and home and I rarely, if ever, step on it. Mostly highway miles as well. That's not normal gas mileage at all especially the way I drive. Anyone have any ideas or suggestions to help me fix this?
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
be honest, you probably give it more go than you think. if not i would start simple and do a tune up. run some sea foam threw your motor.
![]() bone stock from the factory! |
2001 Mustang GT
Did all of that still no change. For the last two fill ups I didn't step on it at all because I was testing to see if it was because I was stepping on it, and no change in MPG. Maybe bad o2's? but would bad o2's cause a big decrease in MPG? I'm averaging like 11 MPG city-highway.
2003 mustang v6 ;)
slow
o2 sensors can cause bad milage. when you installed your k&n filter did you happen to drive it for 200 miles then clean the maf? most filters are over oiled and dirty up the maf.
2001 Mustang GT
Traction...?
1996 GT/ 2008 GT Vert
Try some injector cleaner, new plugs and wires, constant oil changes, maf cleaner as mentioned above and a new pcv valve. The o2's will pop a code.
Threads Similar to: What Could Cause This Problem
| misfire problem, probelms, probably a problem? | rewadferger | 96-98 | 5 | September 13th, 2010 12:17 PM |
| just solved my evap problem now a more serious problem arises I NEED HELP please | sj408 | 96-98 | 5 | July 16th, 2010 08:12 PM |
| Transmission problem??? need help diagnosing the problem... | Tmac3320 | 99-04 | 19 | April 13th, 2009 12:58 AM |
| O Jesus! Problem After Problem! | mustangmanic | 99-04 | 94 | March 28th, 2008 03:36 PM |
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 12:03 PM |
