Manual Brake Conversion Advice Needed
Old January 7th, 2012, 11:49 PM   #1
2001 gt
osa6637 is on a distinguished road
One of the mods i have planned for the coming weeks is converting to a manual brake set-up.I found jegs sells what appears to be a nice set up and so does UPR. i called upr yesterday and the guy on the phone was pretty adament that i would have to completely remove the porportioning valve? this just does'nt sound right to me? i see that the brake lines run from the master cylinder and then through the porportioning valve and the just two lines go over to the abs unit.
my plan was to use the existing lines over to the abs unit which im replacing with a abs delete i purchased and leave the factory valve in the car and then install a line loc between valve and the abs delete. does this sound right?
01 GT totaled, 97 cobra,95 GTS
bracket racing crew member #8
Old January 7th, 2012, 11:58 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
are you installing a manual rack? im not a fan of manual breaks but i see why you would want to do them if your getting rid of your ps and switching to a manual rack. even then i think i would swap out for an older vacume brake booster, unless my car was track only
bone stock from the factory!
Old January 8th, 2012, 12:08 AM   #3
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
if I was doing a manual brake conversion, I'd be redoing all the lines anyway so I wouldn't need the abs delete & would just use an aftermarket adjustable proportioning valve.
much cleaner that way & you could mount the prop. valve anywhere you wanted it.
as to why the rep told you that you cant use the factory prop. valve, I have no idea, doesnt really make sense.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 8th, 2012, 12:44 AM   #4
2001 gt
Yes i did buy a manual rack, i may just re-do all the brake lines. i have'nt taken anything apart yet but i believe these cars use that goofy bubble flare on the ends of they're lines?
Old January 8th, 2012, 12:47 AM   #5
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
they do use a bubble flare, but thats no problem, you'll just need to buy a bubble flare tool.
2012 300a GT auto
Old January 8th, 2012, 01:33 PM   #6
2001 gt
Casper i should have just called you! L.O.L
Old January 8th, 2012, 01:37 PM   #7
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
you know I'm here for you anytime bro, lol.
2012 300a GT auto
Old January 8th, 2012, 03:08 PM   #8
Hooo Ha Ha
sharkbait's Avatar
1997 Mustang GT
11.65 @ 115
sharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud ofsharkbait has much to be proud of
iTrader: 10 reviews
The reason you need to redo them is because you want the rear port going to the front brakes and the front port going to the rear brakes.
My racecraft MC has more volume going to the rear port so you want it to have the most volume going to the front brakes (for a street car).
For a drag only car you would need the rear port feeding the rear brakes because thats were you have the most tire. Trying to stop at 150 with most of your braking force going to your skinnies isnt going to work out so well lol
410rwhp 520rwtq @ 12.9 psi
Old January 10th, 2012, 12:33 PM   #9
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
not quite. if you have too much rear brakes on a drag car, the rear slicks will lock up and once they do, its all done for. Theres no stopping it. Seen it before and even started to witness it at 160 mph after crossing the trap, not fun.
Threads Similar to: Manual Brake Conversion Advice Needed
Brake advice needed ASAP! townaj 99-04 20 November 7th, 2011 07:12 PM
Manual Brake Conversion? ModMustang97GT Modular Mustangs 25 January 20th, 2011 08:44 PM
Repair manual and parts source advice needed MustangMD 2.3 Mustangs 5 January 2nd, 2011 01:20 AM
Auto/Manual Conversion batlaxe 5.0 Mustangs 23 February 16th, 2009 10:46 AM
