Stripped Bolt...Need Advice.
Old January 8th, 2012, 10:38 AM   #1
03OFP's Avatar
2004 Mustang Gt
Unknown
03OFP is on a distinguished road
So the bolt holding one of the COPs in, is just spinning. What's some advice to get it out?
04 GT, Vortech V-3, Hi-Tech Stage 2 Cams, BBK shorties, ProChamber mids, SLP LM1's, FRPP aluminum D/S and 3.73's, Acufab upper plenum, 75mm TB, 75lb/hr FIC injectors
Old January 8th, 2012, 10:51 AM   #2
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
can you get a screw driver under it that way you can put some upwards pressure on it while you turn the bolt with a wrench.
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old January 8th, 2012, 12:49 PM   #3
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
Pate's suggestion works most of the time. If that doesn't work, place a screwdriver on the head of the bolt and give a gentle, yet firm tap to the head of the bolt to help re-seat the COPs insert in the intake. Don't get carried away with this as you can crack the intake.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Old January 8th, 2012, 12:56 PM   #4
03OFP's Avatar
2004 Mustang Gt
Unknown
thanks fellas. i'll give it a try.
Threads Similar to: Stripped Bolt...Need Advice.
Stripped Caliper BOLT! projectGT 96-98 15 July 28th, 2011 11:36 PM
how to remove stripped IAC bolt? WhiteShadow V6 Mustangs 7 April 27th, 2011 12:00 PM
stripped oil drain bolt wishIhada5.0 99-04 19 May 12th, 2010 11:35 PM
Oil Pan Bolt Stripped 92hatchback 5.0 Mustangs 12 February 27th, 2009 07:34 AM
stripped bolt Monster90 99-04 18 January 18th, 2009 07:05 PM
