Crower Stage II Blower Cams
I'm looking at picking up some Crower stage II blower cams and Comp Valve Springs from a member on here. If i degree the cam properly, will I have PTV issues with stock pistons? I've read every thread on here about PTV contact issues and it seems like most all NA cams have PTV issues but I didn't know if it made a difference being a blower cam.
2002 Mustang GT- built C head 4V swap in progress ![]() FOBRA CLUB MEMBER #7 |
What are the cam specs?
Duration and lobe separation angle are the major factors that determine if a cam will work. You may want to visit Nick at MHS. He has already done all the research and knows what will work on a stock 2v.
Brand Crower
Manufacturer's Part Number 62802-2 Part Type Camshafts Product Line Crower Performance Level 2 Camshafts Summit Racing Part Number CRO-62802-2 Cam Style Hydraulic roller follower Basic Operating RPM Range 1,500-6,500 Intake Duration at 050 inch Lift 234 Exhaust Duration at 050 inch Lift 234 Duration at 050 inch Lift 234 int./234 exh. Advertised Intake Duration 276 Advertised Exhaust Duration 276 Advertised Duration 276 int./276 exh. Intake Valve Lift with Factory Rocker Arm Ratio 0.581 in. Exhaust Valve Lift with Factory Rocker Arm Ratio 0.581 in. Valve Lift with Factory Rocker Arm Ratio 0.581 int./0.581 exh. Lobe Separation (degrees) 110 Computer-Controlled Compatible Yes Valve Springs Required Yes Quantity Sold as a pair. Notes Fits 2V SOHC engines only. Require bolt-on cam gears. These performance Level 2 cams from Crower are designed for individuals who require more power and an extended rpm range. They provide excellent low-end and midrange power for spirited street and off-road driving and mild marine applications. These cams work well with stock or near-stock engines and drivetrains.
My first opinion would be that they are to "big" for a stock 2v. They will probably fit but require modifying the install angle to get marginal ptv clearance.
Threads Similar to: Crower Stage II Blower Cams
| FS: crower blower cams, comp valve springs | twinmill | 1999 - 2004 Mustang Parts | 23 | March 2nd, 2012 02:27 PM |
| Crower blower cams | mustanginky | 99-04 | 15 | November 16th, 2010 10:15 PM |
| hitech stage 2 or crower stage 2 cams? | Boostang | 96-98 | 2 | March 15th, 2009 05:33 PM |
| Crower Stage 3 cams | Norse1974 | 2005 - 2010 | 42 | June 30th, 2007 10:54 PM |
