Bringing Yellow Back
3V 5.4 Swap In Progress Questions
ok so some of you know that im working on my 3v 5.4 swap right now.
what i need to know is if i can wire up the 3v fuel pressure sensor on the fuel rail to work on my 2v harness... also nee to know if i can splice the 3v IAC plug onto me 2v harness and use the 3v IAC sensor ( will make using the super charger elbow easier also, the rousch charger has a small blax box under the lower intake that has a 2 wire plug on it and has a couple vacum lines going to it that i need to know what the two wires are for... any help on these questions would be fun
![]() SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT ![]() BAMA Performance Drag Team Member #4 |
2002 mustang gt
![]() iTrader: 1 reviews
Im sure you can splice the in no problem but as far as that last part...good luck wish I could help
Rock stock
yea im jsut hoping they send the same info to the ecu like the 2v sensors do
2002 mustang gt
Did you get the whole kit to do the swap?
Rock stock
i got the entire engine,
5.4 3v out of the stage 3 f150 witht he twin screw roush charger, then i got it home, pulled the oil pan to find out its fulyl built lol
2002 mustang gt
You luck bastard
how much did you pick it up for? I know there is a company that sells everything you need to swap a 3v in for 900 or so
Rock stock
i paid 2500 for the whole thing, and the lower end should be good for more power than ill ever make
2002 mustang gt
Then more boost is a must
Rock stock
i think its logan motorsports.
the sensors should be the same other than having to splice them. if they dont work you could probably make a fitting to make the 2v sensor fit but i would much rather slice the wires. as for the 2 wires it could be something for you to hook a gauge up to. i know the guy that i got my front valence off of just wired his gauge to the supercharger while i was picking up the bumper.
![]() Check out our race team! http://www.facebook.com/media/set/?s...3927011?v=wall American Iron Mustang- ^1.6 lateral gs 03 Steeda 1.2 lateral Gs-ra1 08 Gt |
i figured out the two wire plug is for the EGR, so its not needed
wrong, 3v's dont have egr, the cam phasers retard and advance the cams to meet emissions.
Its under the intake? are there metal rods attached to it? almost sounds like the imrc box to me
the engine does not have the intake flaps on it. so idk i they where taken off then the super charger was put on or not
so i guess the mystery remains on wtf that plug it for
prob the old imrc box. It sat/sits at the back/under the intake
yea thats right where it is, im hoping thats what it is, at first i thought it was for the small throttle body looking thing thats in the super cahrger, but from what im learing that is the vacum operated boost contoller of some sort
sorry im very new to roots stlye super chargers
thanks bro
that sounds like the boost bypass valve on your current set up, lets boost escape when cruising. Are the vacuum lines a colored hard plastic or black. Small square connector or a flatter looking connector?
86er, do you know if i can runt he 07 style fuel pressure regulator on my 2v harness? the 07 style has four wires to it and the 2v has 3..
also need to know if i can use the 07 style IAC on the 2v harness... any help would be awsome!
they are hard red lines, one goes to the intake wlbow behind the throttle body and one goes to the acuator fort he bypass valve
#19 | |
its not a regulator, its a pressure sensor, youd prob be better off finding a way to adapt the 2v one. 07 doesnt have an IAC. It only has a TPS. The DBW handles the idle/throttle opening that the IAC use to do on cable driven tb's
so i need to figure out a way to use the 2v IAC on the 3v elbow...
Threads Similar to: 3V 5.4 Swap In Progress Questions
| Eaton Swap in progress; Couple Questions | 0949er | 99-04 | 7 | June 9th, 2011 12:39 PM |
| Operation Chassis Swap. Progress and Problems | Xynic | 5.0 Mustangs | 32 | February 6th, 2011 07:02 PM |
| 5.4 4v swap in progress | TimothyJames26 | 99-04 | 41 | February 5th, 2011 11:52 AM |
| 96 to 5.0 swap in progress... | 96StAnG5.0 | 94-95 | 3 | May 24th, 2010 12:59 AM |
| Woo... Another PI Swap In Progress | Uncle Humjaba | The Clubhouse | 57 | April 20th, 2008 11:11 PM |
