MM's Orangest
2004 Mach 1 Mustang
Vibration When Stopping
I've been having a vibration in the car when I'm coming to a stop. It does not occur (at least that I can feel) when the car is accelerating or cruising. It can only be felt below ~10mph and stops when the car has stopped. Any ideas?
Around the same time this happened (within a month) the ABS module and the wiring harness connection to it caught fire/melted and I had to disconnect it. I don't know if it can be related I'm just mentioning it as a side note.
![]() Looking for 03/04 4V ABS Wiring Harness Connector/Incomplete Wiring Harness (with ABS connector) |
EVO LVR
2003 Mustang GT
.3 @ 246927429243
I have no idea. But I have a question, did you race a LS1 dodge ram? lol
EVO LVR
2003 Mustang GT
.3 @ 246927429243
Knew I recognized the car lol.
MM's Orangest
2004 Mach 1 Mustang
This shaking shakes the whole car. It's not a small vibration. I can even feel it in the shifter while I'm holding it.
2003 Mustang GT
Does it happen when you hit the brakes at higher speeds or ONLY under 10 mph? And does the brake pedal dive towards the floor a couple inches and then act like its having a seizure?
Sent from my Autoguide iPhone app
![]() '03 GT w/BBK CAI, MAC Pro chamber, Borla Stingers, MGW Orange, SCT X3, and some make it sexy mods ![]() '89 GT 5.0 w/full bolt ons-SOLD '04 STi w/ A'pexi N1 catback and accessport-SOLD '00 Audi A6 2.7t stock - DD/Wifey's whip |
2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
Rotors?
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
It wont be abs related if its disconnected, its prob warped rotors. When you first drive the car and the brakes are cold does it do it? Or is it after a little bit of driving and the brakes have gotten some heat in them
2003 v6/2003 GT vert
![]() iTrader: 11 reviews
I had shaking when I stopped and had to replace brake lines and rotors.
![]() 2003 sonic blue v6- 18" gianna's, straight pipes, 12" DC level 5 with DC 3.5 K 2003 sonic blue GT vert- Bout to be a Procharged P1sc BEAST
MM's Orangest
2004 Mach 1 Mustang
The brakes don't even have to be applied for me to feel this. It's only under 10mph roughly, that's the only variable. Clutch, brakes, gear the transmission is in doesn't matter. I've been doing just local driving but now that I think about it it seems as though it happens after the car has heated up. I just replaced the rotors this summer which means they are still under warranty. It just sucks that I'll have to pull them to figure out which ones it is.
how many miles are on the car?
1997 Pacific Green Cobra
14.80 No traction
Sounds power steering pump/load related. How is the PS fluid and the pump. is it free spinning without a belt on it ?
GT ENGINE (temporary) 4.30 Gears , 31 spline Moser axles , Detroit tru Trac diff, Jmod 4r70w , Pi intake Hitech stage 2 cam, Vortech V2 3.33 pulley. Alum drive shaft. Lowering kit x2 ball joints ,screamin demon coils, LCA " |
MM's Orangest
2004 Mach 1 Mustang
73000 on the car. Fluids are fine, but for some reason the car will die sometimes if I turn the wheel one way or the other all the way at a low speed.
MM's Orangest
2004 Mach 1 Mustang
Any other ideas guys? I'm planning on checking this stuff on Thursday when it gets a little warmer.
As others have said--the brake rotors are warped. It is common on all older cars, I just replaced the fronts on my wife's 2003 Highlander a few weeks ago.
The stalling could be a failing IAC. With the engine hot and idling disconnect the IAC electrical connector, engine speed should drop or perhaps even stall--if is does not the IAC is dying/dead. There are resistance tests to confirm this, but first unplug it and see what happens...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
From what he said earlier it doesnt sound like the rotors. The stalling is prob from the pressure switch in the p/s. Suppose to up the rpms when at full lock to compensate for the extra strain put on the engine when turned lock to lock
That is a possibility, the p/s pressure sensor reports p/s load to the PCM so that it can tell the IAC to pass more air...
00 Mustang GT Vert/88 5.0
Have you checked your driveline for loose bolts or a u joint?
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
MM's Orangest
2004 Mach 1 Mustang
I didn't think that it would be the driveline since it doesn't get worse with higher speed. I just remembered that the night I moved from St. Louis to Indy my car developed a whine much like a bad belt or the tensioner going bad. It was completely random except for that the car had to be above 65 mph for it to occur. It only happened that one night and hasn't happened since. This makes me want to check the P/S first then the rotors. Mainly because everything else that everyone has mentioned has been replaced rather recently.
Thanks for the help guys.
Warped rotor in the front.
![]() Sig by Tricep |
Threads Similar to: Vibration When Stopping
| Stopping is fun... | Jucostud | 2005 - 2010 | 17 | February 21st, 2011 05:59 PM |
| New Guy just stopping by! | Hooahshel | New Members Introductions | 10 | September 17th, 2010 02:24 PM |
| Stopping Power! | goren813 | Pictures | 16 | September 27th, 2009 10:54 PM |
| Brakes (Rumbles While Stopping) | johnbarberr | 99-04 | 6 | September 19th, 2007 10:24 AM |
| AOD Shutters While Stopping | shwagy357 | 5.0 Mustangs | 1 | March 25th, 2006 06:42 PM |
