MM's most Hated
2001 Mustang GT
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
P1sc missing parts?
Hey ive pick up the majority of the kit
It would be helpful to know what else im missing Parts I have: Headunit Bracket all the tubbing and clamps 3 core intercooler 42 lb frpp injectors maf svt focus pump. 3.6 pully Goal: 380-390 rwhp Imma have ret do the tuning I know i need colder sparks plugs, 108 inch belt, guage cluster, and guages. Is their anything else im missing? Should I also buy another blow off valve? I heard the stock ones that come with the kit arent very good. I also was reading that some people are running kb boost a pumps so do i need to pick one of those up 2?
MM's Most Hated
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
Got idler pulley?
![]() 4.75 MMR 900se Livernois ported heads HP 292s blower cams Procharger D1sc at 20+ psi IW 15% OD pulley (and more bolt ons) E85 ![]() Tune/numbers coming shortly!! |
2003 v6/2003 GT vert
![]() iTrader: 11 reviews
Procharger oil
![]() 2003 sonic blue v6- 18" gianna's, straight pipes, 12" DC level 5 with DC 3.5 K 2003 sonic blue GT vert- Bout to be a Procharged P1sc BEAST
MM's most Hated
2001 Mustang GT
I believe so, theirs a random pully in a box with the hose clamps so im assuming thats it. Is a boost a pump a must have? also what about the fuel rails?
MM's Most Hated
its the parts list for our year
im assuming this is a used kit you bought? make sure you have the 1.95" idler, and you need the offset spacer, otherwise the belt will rub
12.73@111.36
I didn't see the by-pass valve listed or the cold air intake with air filter. Spread out the parts and take some pictures. We might be able to see if anything else is missing.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
MM's most Hated
2001 Mustang GT
MM's Most Hated
MM's most Hated
2001 Mustang GT
link didnt work seems like im missing some hardware for mounting it, but not all sure. Any one have any links to a better blow off valve?
MM's Most Hated
12.73@111.36
I've been using that BOV for around 76,000 miles. It will work fine. The pipe with the long rod runs down from the head unit. The rod attaches to the top of the radiator. It has the port for the BOV. That port should face downward. The ribbed hose with the red line attaches to the BOV port on one end and the BOV on the other. It curves upward under the head unit toward the cold air intake. The air filter is on the wrong end of the CAI. The short 90* hose coming off the CAI attaches to the top of the BOV. The other port on the CAI is for the driver's side PCV valve hose. The middle pipe below the CAI has the hose that connects to the IAC. The top of that pipe connect to the throttle body. You have green top 42# injectors and below that the pipes for the MAF.
The head unit attaches to the Y bracket using 4 bolts (two large and two small). It looks like one of the large bolts is missing. The allen head bolt goes through the idler pulley into an offset spacer. The idler pulley is the small pulley. I don't see the offset spacer. I also don't see the 1.25" stud and bolt that mounts the Y bracket to the motor. The stud goes through the middle of an exhisting idler pulley. Did you get the installation manual? In case you didn't here is a diagram of the belt routing and a couple of pictures of installed systems that may help. ![]() ![]() ![]()
MM's most Hated
2001 Mustang GT
where can I buy the offset spacer and for how much do they go for?
Ya I have the instructions Are you running a boost a pump?
MM's Most Hated
12.73@111.36
No. I'm running a 255 lph SVT Focus fuel pump. No boost a pump.
You have to get the offset spacer from ProCharger. Someone bought one not long ago. I think they said it was $30 but you have to have it or else the belt rubs against itself.
Can fill 7 car garage
Eagle has had good luck with his stock ProCharger BOV.
Me, on the other hand...the stock ProCharger BOV crapped out and caused surge in the head unit which broke the main seal. I sent the P1SC back to ProCharger and paid extra for them to return a D1SC to me. I replaced the stock ProCharger BOV with a Vortech mini-race valve that has worked well with my D1SC. The Vortech mini-race valve was $100+ cheaper than the ProCharger Big Red. So now my car sounds like a train/airplane whatever you want to call it coming down the road, love it. |
i think the offset spacer cost me somewhere around 50-60 but i had to overnight it...
Bad... ![]() Good...
Threads Similar to: P1sc missing parts?
| Missing Parts | Gauge | 99-04 | 1 | January 16th, 2011 10:25 AM |
| What am I missing? Suspension parts... | Lava | 2005 - 2010 | 10 | November 22nd, 2010 06:00 PM |
| p1sc | realrider88 | 99-04 | 9 | March 24th, 2010 11:22 PM |
| New Car to us + Missing body parts (x) | Broke Neck | Pictures | 11 | August 17th, 2008 03:51 AM |
| 01 gt w/ P1SC | 00GT | 99-04 | 30 | September 21st, 2007 12:18 PM |
