#21 |
!FACEPLATED!
the locker will give you better 60' times due to the fact that the clutches do actually slip a little. I just got off the phone with my dad and he said that the locker will indeed net you better 60' times. Its the closest thing you can get to a full spool but yet be streetable
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
#22 |
11.463@121.50
Yes, I remember some launches where I could actually feel one wheel turn over/spin maybe a half a turn or 1 turn and then the car hooked and picked up the front tires. I guess the stock differential was switching over the torque to the non-spinning wheel - it seemed like it took a couple of tenths of a second - but you know how time slows down on the dragstrip!.
MM Bracket Racing Crew Member #5 |
#23 |
!FACEPLATED!
A locker will def help cut down on your 60' times
#24 |
!FACEPLATED!
You will also want to screw your tires to the wheels
#25 |
2003 mustang gt
how bout the trutrac? not sure if its the same as the same kinda thing as the locker but im curious because i was gonna get that instead of the locker
![]() 386/385 Kenne Bell powered ![]() 11.44@121.9 1.59 60 foot |
#26 |
!FACEPLATED!
trutrac isnt as good as the dlocker but is better than the clutch type rear diff. The trutac is a little more streetable as it doesnt make a ratcheting noise around corners like the dlocker does
#28 | |
2003 mustang gt
#29 | |
!FACEPLATED!
Sent from my HTC Wildfire using AutoGuide App
#30 | |
2003 mustang gt
REPS man
#31 |
2001 Gt
I used to do a lot of rockcrawling in highly modded jeeps and buggies. Why not run an ARB air locker? You can flick the switch when you want the locker and then turn it off ro street use.
#32 |
04 mustang gt
7.21 @ 98
they are pretty expensive ^^
but great if you got the cash
![]() cams + 150 shot |
#33 |
!FACEPLATED!
plus you have the added weight of the air compressor or air tank for it, and what if you end up breaking or tearing a hose? then you would be down to a 1 wheel peel
#34 |
2001 Gt
The compressor weight would not be much, but when you are watching the ounces it weighs a couple pounds. As far as breaking or tearing up a line that is not really an issue. Once the line is run it will not be doing any work. As long as it is run where it will not be bound in a control arm or something dumb you will be fine. I ran a number of them and like I said every part of my vehicle came in contact with rocks....
#35 |
!FACEPLATED!
For a car that mostly sees strip I wouldn't put one in. That's just my experience from building drag cars
#36 |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
I would run a mini spool which can use a stock diff and not require c clip eliminators. For a car that sees the street a trutrack is a great diff. I run one in my car and it locks every time. They open up during turns with vary little noise and are extreamly sensitive so they feel like a locked up rear off the line
![]() bone stock from the factory! |
#37 |
2002 mustang gt
I was considering the trutrack, I actually thought that's what the thread was about but I was wronng
Rock stock
Threads Similar to: Detroit Locker - how much improvement?
| Detroit E-Z Locker trouble...Help!! | overtimeracing | All Other Vehicles | 6 | December 25th, 2008 10:11 PM |
| Who is or has had a Detroit Locker on the street | White 89 | 5.0 Mustangs | 11 | March 18th, 2008 11:19 AM |
| Detroit Locker Q. | Flomaster_Knockoff | 5.0 Mustangs | 10 | April 28th, 2007 12:10 AM |
