150 Nitrous Shot
Old January 9th, 2012, 04:29 PM   #1
moneygreenstang's Avatar
2001 Mustang GT
moneygreenstang will become famous soon enough
150 Nitrous Shot
I got rid of the Mod Bug for almost a year but, its time to give my mustang some more pep in its step.
The 5.4 HPS intake I have is supposedly good for nitrous and designed for nitrous so since i paid 500 for it ill keep it and spend grab the nitrous kit, tune, spark plugs, and drag radials
Im looking to add a 100-150 shot with a dyno tune @ Big Shot Dyno in Tallmadge ohio. Maybe MHS Stage 3 Nitrous Cams. Im trying to get to 400hp and into the 11 second range. Supsension is there it just needs to be dialed in once I get it to the track.
Can the stock 5.4 hold a 150 shot?
01 GT Vert - Triple Black - 2v 5.4 270/340
00 Lightning - Triple Black - 2v SC 5.4 400/500
Brand New Tubular UCA and LCA set for sale PM me
Slightly Used 05-09 Halo Headlights for sale PM me
Old January 9th, 2012, 05:03 PM   #2
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
The stock 4.6 can all day so I don't see why not, that's about an hour away from me though
Edit: was that 270 horsepower with the cams?
Rock stock
Old January 9th, 2012, 06:09 PM   #3
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
If your worried about it just do a 125 shot, the 5.4 with a 125 shot will still probably make more than a 4.6 with a 150 shot. The 5.4 with a 125 should do 400-430 I would think, and 11's would be really easy with a good suspension setup and the spray.
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old January 9th, 2012, 06:14 PM   #4
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
if you've got decent suspension already, and can hook up you should have 11's np on just a 125 shot. I'd start there since it's a 5.4. I have bolt ons and a 125 shot and ran a 12.1 and I didn't even spray it right off the line due to traction issues. you should see 11's all day.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old January 9th, 2012, 06:28 PM   #5
2001 Mustang GT
I have a built 3650, 4.10s, superior hardened axles, baseline relocated uppers, weight jackers, eibach drag springs, 200 lb coil overs in the front, 4.10 gears and im going to get a set of drag radials
Do you a 12.1 on those wheels?
Im going to put the purge in the shaker and start with a 100 shot.
Old January 9th, 2012, 06:33 PM   #6
11.85@116
yes the 12.1 was with the cobra wheels on 275 555r's. It only trapped 111 so if it was on a 5speed my combo would trap a bit higher and i prolly woulda got 11's. however i got a stalled auto because i cant shift for shit and 3rd gear sucks on this thing lol.
Old January 9th, 2012, 06:34 PM   #7
number1gt's Avatar
2002 mustang gt
Pick up some big and littles
Rock stock
Old January 9th, 2012, 08:08 PM   #8
2001 Mustang GT
What size shot do you run?
Old January 9th, 2012, 08:17 PM   #9
2004 Mustang
Not really "ran" it yet because it ran out of fuel on the dyno. Need to get a bigger pump in and a retune before I spray it but im spraying a 150 shot, NX plate system. Hoping for 450whp after a bigger pump. Never ran the 1/4th but my 7.88 says it converts to a 12.3X and I ran that with only 285WHP, if your serious about drag racing then getting the suspension dialed in, good tires on, and rear built is the 1st thing to do THEN start adding power lol people always do it backwards.
Old January 9th, 2012, 08:20 PM   #10
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
I ran a 125 shot on my stock block of course I only ran about 50+ botttles through it in no time. You should be ok if you take all the right precautions such as fuel pressure sensor, Bottle heater, never run the Nitrous until your pressure is optimal. I ran a purge kit to just to ensure I was getting a pure shot of the Good stuff. you sont have to purge all day, just enough to get a clean shot. colder plugs are also a must.
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old January 9th, 2012, 08:28 PM   #11
2001 Mustang GT
yup thats exactly what i did to my car first >> from above I have a built 3650, 4.10s, superior hardened axles, baseline relocated uppers, weight jackers, eibach drag springs, 200 lb coil overs in the front, 4.10 gears and im going to get a set of drag radials
I can pretty much stab it in 1st with 4.10s and 300+ ft lbs from 2000-5000 rpm
Old January 9th, 2012, 09:12 PM   #12
2004 Mustang
Not sure how well the weight jackers are gonna be, everytime you raise or lower it it will throw off your pinion angle
Old January 9th, 2012, 09:59 PM   #13
2001 Mustang GT
baseline recommends weight jackers or coilovers to adjust ride height to get the proper pinion angle
"For best results and to get the suspension set up correctly for Drag Racing it is recommend that there is some way to alter the ride height of the rear of the car. Adjusting the rear ride height alters the rear control arm geometry thus moving the Instant Center (IC). Lengthening the IC changes the amount of leverage the suspension has to lift the nose of the car and it changes the amount of tire loading during the launches. Some ways that can be done to adjust the ride height are the use of coilovers, coilover conversion, weight jacker type LCA's, cutting springs or adding weight.
Doing this is not necessary but it's recommended for best results." - Baseline
Old January 9th, 2012, 11:21 PM   #14
2004 Mustang
Adjustable uppers do the same thing
Old January 9th, 2012, 11:29 PM   #15
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
if all you want is 11's the 100 shot will easily get you there...
cams + 150 shot
Old January 9th, 2012, 11:29 PM   #16
2001 Mustang GT
I have both already so ill have ultimate adjustability
Old January 9th, 2012, 11:34 PM   #17
2004 Mustang
Good setup and a 50-75 should do it lol
Old January 9th, 2012, 11:34 PM   #18
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
yea on my 4.6 with a 100 shot i ran a 12.2 at 117hp, so i would hopw a 125 shop would have you into the 11s eay
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old January 9th, 2012, 11:39 PM   #19
MM's Taint Shaver!
TaintedStang's Avatar
2003 Mustang GT
TaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to all
iTrader: 5 reviews
I'm still impressed with that trap speed! Too bad we'll never see you run that combo again to see if the trap would hold up.
Old January 9th, 2012, 11:41 PM   #20
2002 mustang gt
12.2 at 117
i hope to be faster this year lol
Threads Similar to: 150 Nitrous Shot
I just did it...4.10s + 100 Shot of Nitrous = supermachone 99-04 48 October 2nd, 2010 10:15 PM
Will a shot of nitrous help.. ?? SilverGT04 99-04 9 December 28th, 2009 10:45 AM
125 shot nitrous 1BADSTANG 5.0 Mustangs 66 July 17th, 2008 07:02 AM
What Shot of Nitrous Do You Use? crappy_head 99-04 3 September 14th, 2007 10:45 AM
max nitrous shot TKE493 99-04 6 April 26th, 2007 10:35 AM
