Max boost with pump gas? - Page 2
Old January 11th, 2012, 08:31 AM   #21
andrewskaggs's Avatar
2003 Mustang GT
8.26@83.06 (1/8)
andrewskaggs has a spectacular aura aboutandrewskaggs has a spectacular aura aboutandrewskaggs has a spectacular aura about
Originally Posted by SSG Pate View Post
I disagree The octane Boost is quit significant up to 116 and the tune is based off the octane. That is the point with meth it raises the octane so you can run more timing and boost safely without the fear of detonation. Yes it also cools the AIT, but if that was its main point it would be useless in most intercooled applications.
You are correct that the octane of the methanol is 116, but you are injecting so little methanol compared to the rest of the fuel being injected that the overall increase in fuel octane is generally less than 2 (see the math in Tang Stang's post and the Trick Tuner's post that I linked).
Keep in mind that an air-to-air intercooler can never cool your IATs below the ambient temperature. Methanol injection can, so yes meth does have a use in intercooled applications.
SLP :: SCT :: Eaton :: Maximum Motorsports :: Baseline Suspensions :: Strange Engineering
MM Bracket Racing Crew
BAMA Performance Drag Team #1
Project Thread :: YouTube Channel
Old January 11th, 2012, 11:41 AM   #22
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
Originally Posted by ytngt View Post
Mine has lived for a couple thousand hard miles at 20 ish psi on mostly pump gas. Now bear in mind that I use a J&S Safeguard knock control system.
How much timing are you running?
Old January 11th, 2012, 01:18 PM   #23
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
Trick is also a guy who refused to tune meth setups. I ran a 70/30 meth mix in my car and it cost me 13 dollars for 3 gallons of that mix and in 1the year I went threw 3 tanks. Not a bad deal if you ask me. As for raising octane I ran a 5 gpm pre and a 10 gpm post jet which dropped my af by .8 which is right where you want to be. With that combo I ran 18# of boost at 20 degrees timing. Sounds like alot but the car is still running strong and detonation free. Do the math any way you want but water meth pulls so much heat out that it cools the tops of the pistons, valves, and everything else it comes in contact with. Even the percentage of meth I ran with the amount I sprayed an extra 3-4 octane goes a long ways
bone stock from the factory!
Threads Similar to: Max boost with pump gas?
How much boost on 91 pump gas?? horsepowerjunkie 5.0 Mustangs 9 September 19th, 2010 02:46 AM
Boost-A-Pump or GT500 Fuel Pump? stanglifemike 2005 - 2010 64 September 21st, 2009 01:17 PM
Boost-a pump? 02ATIstang 99-04 4 June 1st, 2007 01:54 PM
