12.35 @ 116
Max boost with pump gas?
What would be the "pump gas limit" with a turbo setup? My compression is 9:1. I've seen people run from 14-20+ on race, and people running 20 on pump.
Vortech boosted MMR900 and supporting mods 420rwhp 410rwtq loaded Mustang Dyno Turbo boost in progress |
There isn't a precise answer to that. While CR plays a role, so do ACT's, cam profile, ignition advance, gear ratio (Load), etc.
Rod @ AzzKicker Cars 2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's. ![]() 1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC. ![]() 1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch |
2001 Mustang GT
You would run around 15-16* on the street with a good tune and have another for 20*+ with race gas for the track
01 GT Vert - Triple Black - 2v 5.4 270/340 00 Lightning - Triple Black - 2v SC 5.4 400/500 Brand New Tubular UCA and LCA set for sale PM me Slightly Used 05-09 Halo Headlights for sale PM me
I like boobs!!!
2000 GT convertible
dunno
Or get yourself a water/meth injection system and you'll be safe for more. Water/meth effectively boosts the octane of your fuel (in a way)
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
2003 Mustang GT
8.26@83.06 (1/8)
The octane boost of meth isn't really something you can base a tune around (it's not much anyway). The main advantage of water/meth is the lower IATs.
![]() SLP :: SCT :: Eaton :: Maximum Motorsports :: Baseline Suspensions :: Strange Engineering MM Bracket Racing Crew BAMA Performance Drag Team #1 Project Thread :: YouTube Channel |
I like boobs!!!
2000 GT convertible
dunno
Kindof correct. It does lower your IAT's but the main benefit of meth is the drastic reduction of detonation risk, allowing you to either run more timing or more boost.
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
Not quite. My old car runs meth to these day. After 20 thousand miles of 18# of boost and 20 degrees timing it is still kicking. The meth jet size determins how rich it will go. The shot I ran dropped the af .8
![]() bone stock from the factory! |
#8 | |
2003 Mustang GT
8.26@83.06 (1/8)
Trick Tuners posted a well-thought out mathematical explanation of meth as relates to octane awhile back here: Meth injection TL;DR version: to increase your octane rating 6 points, you'd have to inject about 20% of your total fuel as methanol. I think we both agree on what we're trying to say...I'm just clarifying. Yes, meth lowers IATs. Yes, it increases the effective octane of your fuel (a little). Yes, meth will allow you to run more boost because of the combination of the two factors above.
For instance, if you ran 10 psi of boost (assuming a FPR with a 1:1 ratio) with 42lb/hr injectors at 100% duty cycle with a 625 ml/min methanol nozzle, injecting 93 octane pump gas and a 50/50 mix of meth/water, you would be running the equivalent of ~94.8 octane fuel. The main effect of methanol/water injection is cooling the air charge, but the small octane boost helps a bit, too.
00 Mustang GT Vert/88 5.0
i am running 20 to 21 PSI with methanol on pump gas.
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
11.463@121.50
I'm non-intercooled and I run 16* max timing, 12PSI max boost.
My motor is "built" (forged internals). I throw some race gas (103 unleaded) in to the mix (on top of 93 octane) for piece of mind. I want to go intercooled (air to water since I could add ice at the track) though - maybe this year.
MM Bracket Racing Crew Member #5 |
12.35 @ 116
Yeah I'm not planning on running meth to run 20psi on pump gas. My cams will be MHS stage 2 turbo cams, 4 core intercooled, probably around 16-17* of total timing around 18psi for high boost. I'm trying to get around 600whp with stock heads but with cams. We will see since the turbo is way more efficient and less strain on the motor from a blower.
#13 | |
2003 Mustang GT
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
Mine has lived for a couple thousand hard miles at 20 ish psi on mostly pump gas. Now bear in mind that I use a J&S Safeguard knock control system.
#15 | |
12.35 @ 116
I think I'll have my high boost at 18psi on 93 octane. We'll see how it does. My goal is to trap ~130 though the 3650 and still be driven on the street like a regular car. I.E not have to fill it with race gas to run high boost.
2003 mustang
7.48x1.56=11.67
The most I run on pump gas is 15psi with a built 9:1 motor and race ported heads and cam. I wouldnt push it past that with out more octane.
New combo: Forged SC short Block,280cfm heads, Precision 6262 turbo, cx 31x12x3 fmic ![]() ![]() http://photobucket.com/JTsTurboBuild http://youtube.com/user/JTsStang |
Baker Jr.
Arent you selling your car?
MMR-Modular Mustang Racing Phils Machining-For your ABS Module Delete Manifold! American Muscle-www.Americanmuscle.com HorsePower By Hermonn-TUNER THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
12.35 @ 116
Nooooo way. I'm selling the blower kit off of it which is unofficially sold.
I disagree The octane Boost is quit significant up to 116 and the tune is based off the octane. That is the point with meth it raises the octane so you can run more timing and boost safely without the fear of detonation. Yes it also cools the AIT, but if that was its main point it would be useless in most intercooled applications.
2003 mustang v6 ;)
slow
You sure can. I have twin ford gt pumps in mine. Plus this kit helps and its cheap
PPRV Delete Hose Kits, AD AutoParts
Threads Similar to: Max boost with pump gas?
| How much boost on 91 pump gas?? | horsepowerjunkie | 5.0 Mustangs | 9 | September 19th, 2010 02:46 AM |
| Boost-A-Pump or GT500 Fuel Pump? | stanglifemike | 2005 - 2010 | 64 | September 21st, 2009 01:17 PM |
| Boost-a pump? | 02ATIstang | 99-04 | 4 | June 1st, 2007 01:54 PM |
