stainless steel Vortech oil feed
Who has done this upgrade? The stock brass fittings and line are known to leak, and mine is starting to leak a little more than i'm comfortable with. The lower part of the bracket and entire hose are wet. Today for the first time I saw a drop of oil on the ground. Will the stainless steel upgrade stop the leakage? Vortech 1996-2004 Mustang 4.6L Stainless Steel Oil Feed Upgrade [V8L101-002] - $82.00 : SuperchargersOnline, Worlds largest Supercharger Resource. Get Serious About Power
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
2003 Mustang GT
Sure its definitley not the blower? Thing that sucks about brass is it strips so easy yoy cant really tighten it. I destroyed one of the fittings because of that.
I say buy it, I'm sure if its the brass causing the leak the ss will make it better. I need a new oil line to, mine pushed into the harmonic balanced and cut it alittle but didn't go all the way through. I was thinking of getting a stainless hose made but with brass pieces on the end so i dont have to spend all the money on the ss setup.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
Not the blower. Oil feed line has been wet since day 1. The line is pressurized so it probably squirts some on the bracket. It is more dry oil on the bracket and the line is wet. One more thing to add with the intercooler install in the spring.
00 Mustang GT Vert/88 5.0
wow thats expensive, but PRETTY!!
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
2003 Mustang GT
Summit sells one too. Might be alittle cheaper
!FACEPLATED!
I'm sure you can just get a braided stainless line thr correct length with thr correct size fittings for cheaper than that
Sent from my HTC Wildfire using AutoGuide App
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
2003 Mustang GT
^ Thats what I planned on doing, but if you change the line to SS with SS fittings on it (vs brass) I would think you would need to change the other pieces that go into the blower to SS too right? Other wise it wont really seal good. Wont be able to crank the line down because the brass will strip, and brass kind of softens.
Correct me if Im wrong though
!FACEPLATED!
Can u get just a ss nozzle? If so, then u can put one together cheaper
2003 Mustang GT
Might be able to. Yeah you could buy the other pieces at Ace hardware really cheap. A place that does plumbing lines made me a new oil line with the brass fittings on there for $8. Compared to superchargers online charging $25. I was going to have them do a SS line but I was nervous of using that with brass fittings.
2003 Mustang GT
Here you go, but fuck $55?
Vortech 8R100-002 - Vortech Supercharger Oil Feed Fittings - Overview - SummitRacing.com
1999 GT 35th LE
Specialty items aren't cheap, mainly because a lot of you guys do't want to buy them so they have charge a lot of money for them. AN fittings aren't cheap either. I've made a lot of stainless steel hoses and the fittings get expensive when you have to start buying a lot of them, like when doing fuel rails.
Spend the money and your oil leaks will be a thing of the past.
![]() Drive it like you stole it |
Ya a little cheaper. $79 and $88 shipped.
#13 | |
#14 | |
'03 GT
15@98mph :(
Magnaflow Catback | Steeda UDP | UPR CAI | AccuFab 75mm TB+Plenum| 14" rotors with 8 piston calipers | BMR LCA&UCA | Eibach Sportline Springs |
Threads Similar to: stainless steel Vortech oil feed
| Mild Steel or Stainless Steel Flange for Procharger Pipe? | phoenixmustang | 99-04 | 3 | September 2nd, 2011 01:44 PM |
| Stainless steel necessary? | TheWop | 99-04 | 11 | October 14th, 2010 02:41 PM |
| Aluminized Steel vs 409 Stainless Steel | OutKast09 | 99-04 | 3 | August 17th, 2010 03:42 PM |
| Moto STEEL Polished Stainless Steel Headers and H-Pipe | RX Bandit | 2005 - 2010 | 6 | October 5th, 2009 06:23 PM |
| Stainless steel? | sk8flip67 | 99-04 | 9 | October 26th, 2008 06:42 PM |
