My Setup So Far..
Old January 10th, 2012, 08:08 PM   #1
Mustang_Girl_32's Avatar
2003 v6/2003 GT vert
Mustang_Girl_32 will become famous soon enough
iTrader: 11 reviews
My Setup So Far..
Ok so as you all know, I had recently purchased a procharger p1sc with a 2 core intercooler. I have the majority of the kit complete and only need a few couplers and clamps which isn't a huge deal. Anyway, so far I have purchased a 3.4 pulley for a very good deal and that guy previously made 10lbs with that on his p1 so I am hoping to make that or a little less. I have also went ahead and got NGK Tr6 plugs, 90mm lightning MAF, 39lb cobra injectors, and a great deal on a Tial Q bov with the 3lb spring I need. All I have a few things left to purchase like my powerpipe, belt, svt fuel pump, and some miscellaneous procharger parts. However, my question is with the 90mm lightning maf and 39lb cobra injectors, are they going to be ok for around 425 hp. I really don't see myself going any higher than that. I have read up on the maf I had purchased and realize that I may need a diablo mafia so that the sensor will read right. And my 39lb injectors will be good for 500 hp. I just want to make sure that I am in line with the info I am getting with this and I will be fine. Your guys infor would be very helpful as always!
2003 sonic blue v6- 18" gianna's, straight pipes, 12" DC level 5 with DC 3.5 K
2003 sonic blue GT vert- Bout to be a Procharged P1sc BEAST
Old January 10th, 2012, 08:22 PM   #2
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
I would buy a MAFia just to be safe. Last thing you want is to go get a tune and the MAF isnt working right. I believe its Baker whos making 600rwhp on his stock MAF with a MAFia. I think so.... you may not need the MAFia, but if it were me Id do it to be safe.
As for the powerpipe, why not just buy a stock Procharger intake? Powerpipe for a Procharger is a waste it seems. I never see them pick up any boost, as far as horsepower, I dont really think they do much. Unless you have the money to buy one, then definitley do it.
For the Tial BOV, if you cant find someone to weld the flange on, just buy this
Tial Blow Off Valve Adapter- TREADSTONE PERFORMANCE
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old January 10th, 2012, 08:23 PM   #3
Irregular
bullitt1680's Avatar
2001 Mustang Bullitt DHG
bullitt1680 has a spectacular aura aboutbullitt1680 has a spectacular aura about
Might be worth getting a boost a pump.
Vortech V2 Non I/C 377rwhp and 365 rwtq
Old January 10th, 2012, 08:26 PM   #4
bullitt02875's Avatar
2001 Bullitt
bullitt02875 is on a distinguished road
Why not go with a slot style maf? Has the iat integrated and is good to like 1500hp or something depending on pipe size. And my powerpipe alone picked up 2-3 psi but fits like garbage
Sent from my Autoguide iPhone app
01 DHG Bullitt
Stroked, Forged & Blown
Built Rear, Viper T56, Suspension, Drag Radials
374.6 rwhp 374.4rwtq @ 4.6L 10psi
Now 5.1 and 15psi, no idea on the numbers!!
Old January 10th, 2012, 08:31 PM   #5
iTrader: 11 reviews
Thanks! I am going to go ahead and get a diablo mafia when I get paid again cuz u make a good point. Also I would buy the normal intake pipe or whatever rather than powerpipe from procharger but I have a feeling it is probably similar priced to a powerpipe. And I really don't want to weld so that will be helpful!
Old January 10th, 2012, 08:32 PM   #6
iTrader: 11 reviews
What exactly does that do?
Old January 10th, 2012, 08:34 PM   #7
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Sends the fuel pump more voltage to make it spin faster and pump more fuel
Sent from my HTC Wildfire using AutoGuide App
Old January 10th, 2012, 08:34 PM   #8
iTrader: 11 reviews
Well I'm trying to keep this build pretty budgeted and I got a killer deal on it.
Old January 10th, 2012, 08:35 PM   #9
iTrader: 11 reviews
That's easiest enough to understand.
Old January 10th, 2012, 08:41 PM   #10
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Do you have a Vortech though? Vortech stock intakes flow like shit. Prochargers dont see any gains with a powerpipe. Maybe some but not much.
OP, for the BAP, thats like the MAFia. Except for your fuel pump (like F8L said) but that 255lph fuel pump "may" not be enough. It could be fine, it might not, dont know if you want to take that risk. It would suck needing to pay for a re-tune although, it shouldnt cost much.
You can find them used for $150. What happend with me was I made 372rwhp and my fuel pump hit max duty cycle at 5500rpm. In 1st, 2nd, gear my tuner told me its fine to shift at 6300rpm since its wrapping up so fast and my fuel rail pressure wasnt dropping to bad. But 3rd and 4th dont go past 5500rpm. Got the BAP on and $50 for a re-tune.
Something to think about.
Old January 10th, 2012, 08:44 PM   #11
iTrader: 11 reviews
Should I get a boost a pump or invest in a better pump? like the one byznasty got. I think it was a division x. I mean I guess if I will be fine with a svt focus pump and a boost a pump then thats ok but as your saying i can't afford for mess ups lol
Old January 10th, 2012, 08:48 PM   #12
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
I would run a Boost a pump. Play it safe, and give you alittle room to grow if need be. Say if you got tuned on 80* weather and the fuel pump was at 95% duty cycle. Well if you get on it in 40-50* weather, chances are the cars going to be making a good amount horsepower will the cooler air, and your fuel pump will max without you knowing, run lean and throw a rod. Just for example.
I say look around on the forums for someone selling a 20 amp boost a pump they usually go for $150.
Lightning MAF
MAFia
255lph Fuel pump
Kenne Bell Boost a Pump
39lb injectors
that will be fine for a stock motor.
You plan on running the MAF in a blow through setup?
Old January 10th, 2012, 08:50 PM   #13
iTrader: 11 reviews
Lightning MAF
MAFia
255lph Fuel pump
39lb injectors
i feel like a retard but I don't know what that means exactly..
Old January 10th, 2012, 08:56 PM   #14
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
lol! Thats how you learn
Blow through the air gets blown through the MAF, basically your putting it inbetween the coldside of the intercooler and the throttle body. Heres where mine is
Draw through, the air gets drawn through basically. You put it before the supercharger. Which I sucks imo.
Blow through is a lot better, and tuning is a lot better and easier with it. Plus incase you have an intercooler pipe that got loose and blew off, any i/c pipe BEFORE the MAF you can drive it home. If its after the MAF, the car will stall, and probably wont start up.
I definitley suggest going blow through. Make life easier for you, and your tuner.
Old January 10th, 2012, 09:03 PM   #15
iTrader: 11 reviews
That's probably what I will do then. Do you have to modify your intake pipe and everything because originally my maf is place in the fender well in the front left..
Old January 10th, 2012, 09:13 PM   #16
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Nope you won't have too. Also make sure the iac hose is after the maf or it will never idle right
Old January 10th, 2012, 09:23 PM   #17
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
Should be pretty cool, if the maf was there wouldn't that be draw through?
Rock stock
Old January 10th, 2012, 09:25 PM   #18
number1gt's Avatar
2002 mustang gt
Never mind I thought she was saying it was before the blower
Rock stock
Old January 10th, 2012, 09:25 PM   #19
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Nope thats blow through. Since the MAF is after the blower. Draw through is when the MAF is before the blower.
Mustang girl, post a couple pictures of your intercooler and intercooler piping.
Old January 10th, 2012, 09:26 PM   #20
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Ahhh okay
Threads Similar to: My Setup So Far..
Computer setup for high rpm setup teej281 99-04 18 March 30th, 2011 02:27 PM
Fuel pump setup for 500RWHP setup bobz18711 99-04 34 September 19th, 2010 11:52 PM
Which MAC setup do you like better? SlideFox V6 Mustangs 26 November 12th, 2008 05:46 PM
Anybody have a v-2 setup? vortech4.6l 96-98 4 August 3rd, 2008 10:05 PM
Classic body taillight setup vs. s197 setup rockybalboa Visual 1 May 22nd, 2008 12:08 PM
