Need your opinion on my next mod!
Old January 11th, 2012, 03:09 PM   #1
mdb12002's Avatar
11.56@119.24
mdb12002 is on a distinguished road
Like the title states, I want to get some opinions on what mod to throw at the stang next. I am returning off deployment, and ive put away a good chunk of change, and I have about 2k set aside for the car. My current setup is:
Engine/Fuel:
Stock Bottom end
P1sc Intercooled
VMP MAF
Stage 2 Patriot heads
272/272 comp cam
42lb Injectors with msd COP's
Accufab TB with 1/2'' Spacer
Dual svt pumps with KB BAP
BBK LT's into BBK x-pipe
Trans/rear/suspension:
Stock trans
stage 3+ spec clutch
Built 8.8 Rear end
Lowered 2'' front and 1.5'' rear
Tokiko d-spec adjustable shocks
AM LCA's
Accessories:
Already got a decent set of rims/tires 245 up front/315 out back
Stock brakes/rotors
Short throw with line lock
The interior is all OEM still, minus 3 guage pillar, and shifter.
So, any suggestions?!
Just your average '02 GT
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 11th, 2012, 03:16 PM   #2
wiggety wiggety whack!
brokenweasel's Avatar
brokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of light
Subframe connectors? Also I'd go braided brake hoses all 4 corners.
3 hookers for good weight distribution?
Originally Posted by dr.gonzo? View Post
Monkeys wear spandex with hotdog legs because race car.
Originally Posted by IndianaJoe View Post
yesterday was shorter because of the massive burnout i did, it spun the earth faster.
Old January 11th, 2012, 03:20 PM   #3
mdb12002's Avatar
11.56@119.24
Touche'
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 11th, 2012, 03:28 PM   #4
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
...3 hookers for good weight distribution?
Originally Posted by mdb12002 View Post
Touche'
Nooo, you need Douche' for the hookers!!!
And +10 on the SFC's
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old January 11th, 2012, 03:32 PM   #5
mdb12002's Avatar
11.56@119.24
Definitely going to go with SFC's,AM had some decent SFC's, but that's only like 200$ max. Ive got 1800 left over :-D
Thanks for the input guys!
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 11th, 2012, 03:37 PM   #6
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
I agree with the SBF's and throw some nice adjustable uppers and lowers on it.
For the lowers if your car is straight line oriented I would recommend JR Mega Bites.
MM FOBRA CLUB CO-FOUNDER
Old January 11th, 2012, 04:16 PM   #7
I've never heard of the JR mega bites, do you have a link? google isn't helping me find them.
An aftermarket K-member would save you some weight up front, you could do coil overs and tubular A-arms at the same time.
Old January 11th, 2012, 04:21 PM   #8
mdb12002's Avatar
11.56@119.24
What exactly would coil overs do for me? Ive heard of them, just really never did any research, thought my d-specs were good enough
And how hard would be doing K-member and A-arms?
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 11th, 2012, 04:26 PM   #9
mdb12002's Avatar
11.56@119.24
and I thought the K-member brought my front wheels forward a couple of inches? Is this true? I dont really want to do that..
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 11th, 2012, 04:32 PM   #10
From maximum motorsports website:
Q.What are the benefits of switching to a coil-over front suspension?
A. Better handling and better ride quality! When the spring is in the stock location on the control arm, the minimum spring rate for performance handling is 700 lbs/in. Better handling can be had with higher spring rates, but ride quality begins to suffer with rates over 850 lbs/in. A coil-over kit allows the use of wheel rates that are much higher than those obtained with an 850 lbs/in spring in the stock location. This will dramatically reduce body roll and brake dive. Other benefits include easily adjustable ride height, the ability to fine tune corner weights, ease of bumpsteer measurement, less weight, and a wide selection of available spring rates.
Here's a write-up from a member here who did a k-member swap:
******zincs k member install tons of pics!!*****
Old January 11th, 2012, 05:09 PM   #11
Mineral Gray GT's Avatar
Mineral Gray GT is on a distinguished road
Forged short block?
2002 Mustang GT- built C head 4V swap in progress
FOBRA CLUB MEMBER #7
Old January 11th, 2012, 05:15 PM   #12
termi_GT's Avatar
12.41@114
here you go......
HPM MEGA BITE JR REAR LOWER CONTROL ARMS , NASCAR Gifts and More at Guaranteed Low Prices White’s Pit Stop
Old January 11th, 2012, 05:18 PM   #13
termi_GT's Avatar
12.41@114
Coil overs are better with weight transfer then having the standard location of the spring. Plus have total adjustability when combined with the correct strut/shock.
You can adjust ride hieght and how hard/soft everything is.
IMO I would not do the tubular K unless you are planning long tubes or a turbo setup. The gain just isn't that much. I am also not a fan of tubular a-arms on street car.
Old January 11th, 2012, 05:21 PM   #14
mdb12002's Avatar
11.56@119.24
I already have BBK Longtubes on there, are they going to get in the way of anything?
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 11th, 2012, 05:33 PM   #15
termi_GT's Avatar
12.41@114
You would just have more room with the tube k-member and the longtubes. If the longtubes are already one, I would skip the k-member and do all suspension.
No reason in having all that power if you can't get it to the ground and hooking.
Old January 11th, 2012, 06:00 PM   #16
StangGT99's Avatar
1999 Mustang GT Auto
StangGT99 is on a distinguished road
Think the 3 hookers are going to cost way past $2K!!!
Old January 16th, 2012, 06:35 PM   #17
mdb12002's Avatar
11.56@119.24
Just ordered steeda full length sub frame connectors, hopefully worth it! Bought them off american muscle and literally 15 minutes later they were shipped. haha
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 16th, 2012, 06:42 PM   #18
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
forged shortblock for sure. put the 1800 on as a downpayment for an mmr900 or so and then you wont have to worry about that time bomb of a bottom end. then next time you get some cash, throw that p1 away step up to a d1 and bingo make 500+
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Threads Similar to: Need your opinion on my next mod!
need an opinion. Mlx50man 5.0 Mustangs 14 March 14th, 2011 08:24 AM
What's every ones opinion on MMR ???? Mustang46 99-04 43 June 28th, 2010 03:24 PM
Gun opinion dude496 The Clubhouse 89 April 16th, 2010 06:24 PM
i want ur opinion 01sta1k3r 99-04 4 January 27th, 2008 12:34 PM
Need help/opinion!!! 04Pony 99-04 0 January 6th, 2008 09:51 PM
