Harmonic Balancer failure
Old January 11th, 2012, 09:04 PM   #1
me2dumb4college's Avatar
me2dumb4college will become famous soon enough
Has anyone had any problems with this harmonic balancer failing?
1996-04 Mustang 4.6L Street Harmonic Balancer by Professional Products at LRS - Same Day Shipping!
I had this thing put on with the supercharger less than a month ago and it's already wobbling... mechanic said the balancer is bad?
Old January 11th, 2012, 09:44 PM   #2
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
You get what you pay for these days.
Either get the stock balancer or get one that is SFI approved.
Drive it like you stole it
Old January 11th, 2012, 09:52 PM   #3
I paid 80 bucks for it... only other option was this 1996-04 Mustang 4.6L Race Harmonic Balancer by Professional Products at LRS - Same Day Shipping!
Old January 11th, 2012, 09:56 PM   #4
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
There's more options than that. You can get a March Performance SFI fluid dampened pulley for 115
Sent from my HTC Wildfire using AutoGuide App
Old January 11th, 2012, 11:43 PM   #5
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
Man Is that one the same size as the stock?
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old January 12th, 2012, 12:33 AM   #6
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
I run the stock damper on my current motor in the car. On my new motor I'm running an Innovators West 8 Rib 10% OD damper. I see no use in putting a stock or cheap aftermarket balancer or oil pump in a new motor. Proper crankshaft end play, billet geared oil pump and IW Damper on anything I build.
http://www.innovatorswest.com/804-MOD-Damper.html
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old January 12th, 2012, 12:36 AM   #7
If you want cheap order a new stock one from ModularHeadShop.com or buy the best IW.... I say buy an 8 rib so one day you can grow and already have the damper. I love the overdrive option also because you can run more boost with less belt slip normally.
Old January 13th, 2012, 05:51 AM   #8
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
If I'm not mistaken the used SFI underdrive setup on my car (I bought used pulleys from ebay) is professional products. Like I already said... used.... and on my car now. No wobble whatsoever. Works like a champ. Also keep in mind that these motors are assembled from the factory with an internal balance. Ford actually refers to the balancer as an auxillary balancer (in other words it's not necessary). I had a friend recently purchase a new edge that he wanted me to go over and I discovered several problems such as the NPI motor that had been swapped into the car but the first thing I spotted after that was the lack of a balancer. The car had piggy back underdrive pulleys but lacked the balancer bolted to the underdrive crank pulley. I started pulling info as well as a stock balancer off the shelf for him only to find out that Ford claims the motor to be internally balanced...... which goes inline with the fact that the motor idled as smooth as glass with no balancer. I still wanna put a balancer on it but he won't let me.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Old January 13th, 2012, 05:59 AM   #9
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Thats how mine was when i got it and I will be putting a March Performance SFI pulley on it
Old January 13th, 2012, 06:06 AM   #10
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
if your supercharged and looking for a budget over drive dampaner pp makes a 7.5 inch crank but i still would not trust it.
Professional Products 90040 - Professional Products PowerForce Plus Harmonic Dampers - Overview - SummitRacing.com
bone stock from the factory!
Old January 13th, 2012, 06:22 AM   #11
bulloch27's Avatar
N/T @ Fast
Yours was missing a balancer too? I almost pissed my pants when I saw it and noticed how smooth the engine was idling. Shocked me honestly.
Old January 13th, 2012, 06:57 AM   #12
stal94gt's Avatar
2003 mustang v6 ;)
slow
internaly ballanced motors will idle nice with out a dampaner, but the elastomer ring along with the mass of the pulley dampens harmonics passing threw the crank. not running one short term will have vary little effect but as the engine gets older the harmonics will start its damage.
btw most cheap dampaners have some sort of wabble to them, its when you see forward or aft movement/eroded elastomer ring.
Old January 13th, 2012, 10:12 AM   #13
Look what daddy got!
Old January 14th, 2012, 07:43 PM   #14
skidad62's Avatar
2003 Centennial Edition
skidad62 will become famous soon enoughskidad62 will become famous soon enough
I wouldn't cut corners if you are supercharged... I got a Ford 8 rib crank dampner when I did a GI Joe 8 rib conversion... and then even it separated... the crank separated from the rubber dampner - walked forward 3/4" and sheared off my belt on the track
Have since gone to an Innovators West - very quality piece
Vortech YSI driven MMR 1000
Old January 14th, 2012, 07:49 PM   #15
moneygreenstang's Avatar
2001 Mustang GT
moneygreenstang will become famous soon enough
What if you're NA and it doesnt have one? My car idles like an electric bull.. my cars in storage but the crank pulley just looked like a big rusted pulley
01 GT Vert - Triple Black - 2v 5.4 270/340
00 Lightning - Triple Black - 2v SC 5.4 400/500
Brand New Tubular UCA and LCA set for sale PM me
Slightly Used 05-09 Halo Headlights for sale PM me
Old February 9th, 2012, 02:32 PM   #16
11.463@121.50
saxmanJJ will become famous soon enoughsaxmanJJ will become famous soon enough
I've been thinking about doing some upgrades to my supercharged 2V and I found this thread.
Can I mix in an 8-rib balancer with my 6-rib belt and pulleys (stock) and be OK until I upgrade the rest of the pulleys? I was looking at the Innovators West product.
Are there any negative issues w/ running an overdrive balancer, since it will spin the alternator and water pump harder? I'm already spinning the motor to 6500 rpms.
MM Bracket Racing Crew Member #5
Old February 9th, 2012, 02:40 PM   #17
As for the water pump if it's spinning faster than stock you run the risk of overheating your engine, which is counter intuitive because you'd think more water would be flowing through, but it's because you can get little air bubbles instead of continuous fluid from the water pump working too hard and air doesnt disperse heat nearly as well as the water
Old February 9th, 2012, 02:54 PM   #18
CobraStang161's Avatar
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
CobraStang161 will become famous soon enoughCobraStang161 will become famous soon enough
Close but no cigar. The reason it overheats is the fluid doesnt stay in the radiator long enough to disperse the heat.
Built 4V Motor with Sullivan Single Plane Intake
Custom 66MM BB TT kit
Borla XR-1 Dumped before rear
Moser built 9" Rear
35 spline WaveTrac Diff with 3.75s
35 spline Moser axles
14PT roll cage and minitubbed
Threads Similar to: Harmonic Balancer failure
Harmonic Balancer mkdnk 96-98 9 March 15th, 2011 02:21 PM
harmonic balancer help! osa6637 99-04 4 September 1st, 2010 07:52 PM
Harmonic Balancer orangestang42 5.0 Mustangs 15 August 30th, 2010 02:42 PM
Harmonic Balancer shawn91stang 5.0 Mustangs 4 January 6th, 2007 12:24 AM
