Discussing Best Axles? in the 99-04 Forum. Well I'm looking at going to a junkyard and pulling a 31 spline t-... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Best Axles?
Don't buy from this guy: 1fstmach1 http://forums.rpmplanets.com/sigimages/1952.png |
Oh forgot about Strange Axles... so keep them in mind too.
Ok, ok, I know I'm posting too much on my own tread, but I found these Alloy Axles http://www.pfeifferperformance.com/p...products_id=87 ....with a 10yr. No questions asked warranty, for only $210.
Anyone tried these or heard of them?
2000 mustang gt
12.01@114.69
i have a set of those in my car, so far they have held up just fine. i got mine from summit racing and had them here in 2 days.
stock long block, bolt ons, slicks, and a little squeeze 1/4 E.T. 12.06@114.69 ![]() Only two defining forces have ever offered to die for you: 1. Jesus Christ 2. The American G. I. One died for your soul, the other for your freedom. |
Do you launch on slicks? If so what RPM
2000 mustang gt
12.01@114.69
i have a set of mickeys when i go to the track or when i wanna play around. i am lauching with nitrous and at 3400, n/a i launch at 4800. i am finally getting the car dialed in and getting the left front in the air.
That sounds like it'll pretty much hold up to what I plan on throwing at it. Thanks.
2000 mustang gt
12.01@114.69
no problem. i see that you have the hooker mufflers on your car. you have a sound clip of it? i run those mufflers on my truck and had them on my t/a. i always wondered what they sound like on a 4.6.
No, I was going to get them.... A blown diff bearing made me change my plans though. So I'm looking at bullet proofing my rear-end now.
I run Mosers and launch at 6500 on slicks.
1985 Mustang GT-Yeah, it's FAST 2006 Black on Black ProCharged Mustang GT-It's the Mrs' 2006 FX4 Superduty Powerstroke-The Toy Hauler |
Did you do anything else to your rear-end? Weld the axle tubes? c-clip elim? Diff cover w/ cap screws?
#12 | |
That's great, I'm pretty much going to be running the same set-up but with a 31 spline Traction-Lok with carbon clutches.
Should be fine for a bolt-on mustang launching on slicks, with 100 shot in the future?
#15 | |
K, thanks.
2000 mustang GT
11.79@125
im also running moser axles, and launching a 6400rpms itll bring the front tires off the ground slightly but i also had a problem when installing ym mosers, one wwas about a 1/8" l;onger than the other one and caused the caliper mount to rub into the disk brake. so i had to shim the caliper out. if i was ognna do it again id prolly go strange
12.37@110.89
I have run Moser 31 splines and 31 spline trac lok from an exploder. The diff was purchased off of ebay and was supposedly rebuilt with heavy duty clutches. The diff lasted 1 season launching at 6500 on slicks. I installed a Detroit Truetrac last weekend with Strange 31 spline axles. I will abuse them just like the Mosers. You can't go wrong with either. Just make sure they are forged 31 splines and you should be fine. The stock 28 splines are cast which makes them extremely brittle.
http://www.moddedmustangs.com/forums/image-apic687.jpg |
Well, I just need the TracLoc to last a year out here in Cali. The nearest strip is about an hour and a half away so I really don't go that often. When I move back to Oklahoma next summer I'm going to throw an Eaton in 'cause the track is nearer.
my car came with superiors idk what spline but no problems yet
2001MustangGTCoupeYelloww/SatinBlack*3.73Gears AuburnLSDBBKColdAirIntakeBBKCaster/CamberPlates EibachMACCatbackMACO/RHpipeSportlineSprings SteedaTimingAdjusterSteedaUpperADJ.ControlArms SteedaShocksSteedaShortThrowShifter SuperiorAxles |
Threads Similar to: Best Axles?
| 31 Spline Axles??? | Bies08 | V6 Mustangs | 25 | July 13th, 2007 11:35 PM |
| what type of axles? | killagt46_t-top | 99-04 | 13 | March 31st, 2007 11:21 PM |
| 02 GT axles | DrHolliday | 99-04 | 1 | March 20th, 2007 05:29 PM |
| Rear Axles | GT529 | 96-98 | 1 | February 18th, 2007 09:06 PM |
| 28 Spline Axles | stangliter04 | Drivetrain | 3 | September 25th, 2006 10:28 AM |
