2000 GT
N/A
Coolant light?
My coolant light has come on a few times over the past 2 weeks. It doesnt come on everytime I start the car just kind of randomly. My coolant is not low, that was my first guess haha. Would this be the thermostat sticking? Any ideas? Car runs fine doesnt get over heated or anything.
the coolant level sensor is a float style sensor. Sometimes they get hung up.
MM's king of Neon's
404 - car not found
17.81@87
Coolant is based on the sensor which I believe is in your coolant reservoir. How does the level look in there?
It could be a bad sensor, or you could have an air pocket. Has it been filled recently?
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
2000 GT
N/A
I've owned the car for a year and a few months and never messed with the coolant. The level is fine. I just checked it the other day. Is there a reason why this would just start happening after a year? It never happened before as long as I've owned the car.
#5 | |
2000 GT
N/A
Thats where I am confused though. It has never come on before and now with in the last 2 weeks it has come on like 5 times randomly.
12.73@111.36
I have had mine come on a couple of times do to low coolant and then stick. I'd fill the tank and it would still be on. For some reason the float gets stuck. As you are looking at the engine from the front of the car the float is on the drivers side underneath the cap. The two times mine has stuck on I took a rod and gently wiggled it around the float. It freed the float and everything was normal. I tried that first because according to my maintenance manual replacing that float is a real pain.
By the way, I have absolutely no idea why the float stuck but its been a year and its not happened again.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
00 Mustang GT Vert/88 5.0
You need to do a test on your coolant and see what mixture you have, color etc. those floats are very sensitive. take the 2 screws off it and dump out your fluid in your resorvoir so you can inspect the rod and float. Specific gravity of the coolant can effect the Float, some will disagree, but it does.
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
2000 GT
N/A
Ok I'll check the coolant. If I turn the car on and the light comes on, I can shut the car off and restart it and the light will go off and not come on for a day or so. It's just completely random. I will check the coolant like I said though, the level is fine. Maybe I'll just drain the coolant and put new in since I havent done so since owning the car. Is there a write up on how to change the coolant? I assume its pretty easy, but I dont know as I have never done it.
i just unplugged mine haha it was too annoying and always came on when it was full. i tried playing with the floater but it would always just sink so i just unplugged it haha
![]() 2000 Black GT: Procharged D1SC Setup Coming Soon!! ![]() P1SC Setup @ 10psi ,424Hp & 388Tq 2000 Performance Red GT: Bone stock, Totaled 1994 Plymouth Sundance, DD |
2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
Mine is always on. So I just unplugged the sensor and check the level everyday.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
2000 GT
N/A
Been doing a little research. From what I gather, to change the coolant and flush the system, I need to drain the old coolant, and place a hose with running water into the radiater filler, then start the car and let it warm up with water running through the system from a hose. After the car is warm, I need to fill back up with a 50/50 mixture of antifreeze and water. Sound right?
2000 mustang gt
13.7 @102
+1 most people on this site are under the hood a lot. checking/changing oil. cleaning. spark plugs. bollt ons. ect. just check on it
Threads Similar to: Coolant light?
| Low coolant Light help | Green4.6 | 96-98 | 9 | March 10th, 2011 07:55 AM |
| coolant light | ZoomZoomMFer | 99-04 | 7 | September 15th, 2008 12:41 PM |
| Coolant Light | redponygt | 99-04 | 5 | June 7th, 2007 12:14 PM |
| Coolant Light | KLance221 | General Tech | 1 | February 3rd, 2007 06:09 PM |
| Coolant Light | Victor | General Tech | 1 | October 25th, 2006 02:44 PM |
