#21 |
2003 gt
5.4 32v on the way
More than that could be made with better heads and cams though. Navi heads are far from ideal, 03+ c heads will not only make more power, but actually match the ports for the boss290 intake. I was really hoping for 450ish with the right cam before I bailed on C heads and only +030 over on the bore. 450 for a properly setup NA 5.4 is not unreasonable, its just a hassle dealing with the intake and exhaust fitment.
2003 Mustang gt - usual mods - slowly working on 5.4 swap 2004 srt4 - Stock DD/winter beater Click here for your tuning needs Before asking a gearing related question click THIS link and enjoy all your saved time. |
#22 |
1999 gt
Don't know 13s
There is a article on the new 4.6/5.0 fast ford mustangs that started with I think the new boss 5.0 block and used a livernois crank with a 3.750 stroke and a 3.70 inch bore that give u 323 ci or 5.3 L. They used forged diamond pistons and Manley h beam rods. They used the 03/04 4 valve cobra heads did a Cnc port and polish job and 5 angle valve job as well. The cams were a stage 3 I believe Custome grind 238/238 at 0.050 and 113.5 LSA. And a 0.475 inch lift. After the tune and dyno testing it made 519 hp and 471 tq and revs up to almost 8k so it's not easy to achieve those numbers but it can be done without boost or spray. I'm not sure how much they spent on the engine but I'd say 10-12k worth or parts. I'm sure the 2v would be much lower in peak power numbers but 500+ hp na on a 4v is doable. How much do u think a 2v could achieve
bbk CAI, bbk throttle intake, frpp, 3.73s, sct 91 oct tune, steeda upd, magnaflow cat back, magnaflow O/R X pipe, MM Flsfc, Lakewood LCA, mgw shifter, king cobra clutch, 18"rims nt 555 Nittos 245, 285, halo angel eyes, autometer guages.
#23 | |
2001 Mustang GT
01 GT Vert - Triple Black - 2v 5.4 270/340 00 Lightning - Triple Black - 2v SC 5.4 400/500 Brand New Tubular UCA and LCA set for sale PM me Slightly Used 05-09 Halo Headlights for sale PM me
Threads Similar to: NA cost????$$$$$$
| What should it cost? | Huck | 2005 - 2010 | 21 | August 19th, 2011 10:52 AM |
| How much will it cost!! | LAStang1234 | V6 Mustangs | 5 | April 11th, 2010 11:51 AM |
| How much would it cost? | mustang fanatic | 2005 - 2010 | 15 | May 22nd, 2008 12:10 AM |
| Cost of 331 | 1BADSTANG | 5.0 Mustangs | 14 | March 25th, 2008 04:18 PM |
| Cost? | D-Brow | General Tech | 4 | August 30th, 2007 10:28 PM |
