01 cobra brakes
Old January 14th, 2012, 12:11 PM   #1
prochargedGT's Avatar
prochargedGT is on a distinguished road
01 cobra brakes
Does anyone know if the 01 cobra brakes and rotors are the same as the 03/04 cobras or the 01 bullitts? I have been looking and cant find anything and I have a chance to pick up the lines, rotors, pads and calipers for cheap if they are. I just have the stock GT brakes now. thanks guys
2000 Black GT: Procharged D1SC Setup Coming Soon!!
P1SC Setup @ 10psi ,424Hp & 388Tq
2000 Performance Red GT: Bone stock, Totaled
1994 Plymouth Sundance, DD
Old January 14th, 2012, 12:24 PM   #2
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
If you want to save money and have JUST as good a set of brakes..... Brakes Upgrade
Sig
.................................................. ...................................l
.................................................. ..................................V
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old January 14th, 2012, 12:25 PM   #3
Run ur car, not ur mouth.
SON1C's Avatar
2003 Sonic Blue 4.6L
SON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of light
i dont see why the bullitts would be upgraded and the cobras wouldnt, cobras are putting down more, but idk
238rwhp/263rwtq
Drew's Build Thread
Old January 14th, 2012, 12:35 PM   #4
so the front 01 cobra brakes arent any different from my 2000 GTs?
Old January 14th, 2012, 12:38 PM   #5
SON1C's Avatar
i think that they are but someone else will chime in that knows for sure
238rwhp/263rwtq
Drew's Build Thread
Old January 14th, 2012, 12:44 PM   #6
Abyssinian of AX
'02 Saleen
19.34@42.259
The Cobra brakes do indeed differ from the GT's, but yours will be BETTER with less cost and only need follow the steps in Brakes Upgrade ~ Speeding up slowing down thread
Old January 14th, 2012, 12:53 PM   #7
the guy has 01 cobra Front Brake calipers, brackets, pads, lines, rotors. for 250? but ill read the write up! thanks jazzer!
Old January 14th, 2012, 12:56 PM   #8
Abyssinian of AX
'02 Saleen
19.34@42.259
If those parts are in good shape and the lines are SS, then buy them
You will still need good fluid, but would need it regardless of my upgrade or those. Just make sure the parts are all in good shape and do good quality rear pads and SS lines at the same time.
Jazzer
Old January 14th, 2012, 01:11 PM   #9
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
Yes the Cobra and Bullitt brakes are the same. The difference is the emblem on them. Make sure you get the complete caliper with the bracket on the back. If you do the front brakes are a direct bolt on. The Cobra rear brakes are not really needed as they are only slightly different from the GT's. The rear calipers are the same. The pads are thinner to allow for the thicker rear rotor and the rotor is a little larger. The rear brake kits come with the dust shields and other small parts. I'm running 13" Cobra front brakes but I didn't change the rear brakes on my car.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old January 14th, 2012, 01:12 PM   #10
Here is what they look like jazzer! he says they have 2k on the pads an rotors .
doesnt look like they have SS lines tho
Old January 14th, 2012, 01:18 PM   #11
12.73@111.36
I bought my Cobra upgrade kit new. It didn't come with stainless steel lines.
Old January 14th, 2012, 01:41 PM   #12
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
I bought my bullets(same thing from 96-98 cobras and 2000-04 cobras and machs)new for 260, the only difference is the emblem in those years I mentioned, from the picture I see they do not have ss lines, you should buy some ss lines but the upgrade is worth it in my opinion
Rock stock
Old January 14th, 2012, 02:10 PM   #13
Abyssinian of AX
'02 Saleen
19.34@42.259
pro.... I am not sure the hoses are compatable with the GT lines
In such a case as I see now, you WILL be better off just doing the upgrades in my guide. The caliper will not be better in any sugnificant way and a larger rotor is basically an esthetic upgrade anway. Save the cost of those parts toward new pads, SS lines and fluid and will have better brakes for a lower cost. Eagle is correct on the upgrade of rear brakes to Cobra's. With the current brake-bias and rear-suspension on the Mustang 4-link, there is just no real gain to be had out back. One still needs the SS lines, as the OEM rubber ones will create a soft pedal feel in times of repeated hard braking, even if the front lines are SS.
Jazzer
Old January 14th, 2012, 02:13 PM   #14
86er's Avatar
Like jazzer said, good pads, good fluid and ss lines on stock sized GT brakes will be a night and day difference for a lot less coin
Just a truck
Old January 14th, 2012, 02:19 PM   #15
thanks guys!
Old January 14th, 2012, 02:21 PM   #16
StangGT99's Avatar
1999 Mustang GT Auto
StangGT99 is on a distinguished road
Brown truck just delivered my new Powerslot rotors, Hawk HPS pads, and SS lines. Thinking I should feel a BIG improvement over original equipment.
Old January 14th, 2012, 02:25 PM   #17
Abyssinian of AX
'02 Saleen
19.34@42.259
Just don't forget to get GOOD fluid... DOT 5.1>
Old January 14th, 2012, 03:24 PM   #18
SON1C's Avatar
examples of good and bad fluid? how often should you replace fluid?
238rwhp/263rwtq
Drew's Build Thread
Old January 14th, 2012, 03:36 PM   #19
Abyssinian of AX
'02 Saleen
19.34@42.259
Examples are in my guide and fluid should be replaced every two years. Every year, is not a bad idea and especially if one puts LOTS of miles or a lot of hard braking. Moisture build-up causes breakdown of the fluid and contributes to soft pedal feel.
Jazzer
Threads Similar to: 01 cobra brakes
FS:Sweet Silver GT Cobra Brakes/Cobra Seats $$/Bolt-Ons/New stereo/ etc! LOTS OF PICS Pony Problem Vehicles For Sale 17 February 21st, 2012 09:53 AM
Cobra R brakes with 2003 10th anniversary cobra wheels...? Gen1sve 99-04 11 August 31st, 2011 11:57 PM
cobra brakes vs Baer brakes 03SuperchargedGT 99-04 20 May 1st, 2009 05:08 PM
cobra brakes zigbigadoru 96-98 2 June 20th, 2008 01:02 PM
