My 01 Mustang Gt is Shutting off on me.
Old January 14th, 2012, 01:12 PM   #1
01 Mustang Gt
2vStangGt is on a distinguished road
Hey I am new to this site and im trying to get some help on my Mustang GT.
I Traded my 94 Integra for it , And I picked it up about an hour away from where I live I drove it home no problem . Parked it that same night for 30min. Came out started right up drove down the street and it died . like It didnt get gas . I cranked it over and it didnt start all it was doing was cranking but seemed like it wasnt getting any gas . Looked at the fuse box I think fuse #24 was blown . Got some wire and put it where the fuse goes and it started drove it home and it sat. dropped the tank and fuel pump and has a brand new fuel pump in from factory ford . Now its still doing it drives for a bit and dies.But now where it reads miles it blinks once and blinks twice and the second time the numbers dont come up just dashes ...and the theft light starts blinking real fast. I let it sit for 30mins went to start it and battary was dead ? so i called a friend to bring jumper cables and it started right up ?but also to let you guys know the box right next to the right fender by the windshield started smoking at one point. Im confuesed and dont know what to do if you guys can please help me . Im a import guy and switched to Muscle and its a bit different and dont know where to start.
Miles 200k on body , 120k on suppose swapped motor
Year: 2001
Model: Mustang Gt
I hope thats enough information to explain my problem
Old January 14th, 2012, 01:14 PM   #2
2000 Mustang GT 5spd
35.9@16.99
Cabikejumper is a jewel in the roughCabikejumper is a jewel in the roughCabikejumper is a jewel in the rough
iTrader: 17 reviews
Pats problem if your theft light is blinking very fast
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs
Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html
Originally Posted by RZNCAIN View Post
Thats not a Mustang, thats a V6!
Old January 14th, 2012, 01:22 PM   #3
01 Mustang Gt
Can you please tell me what is a "PAT" sorry im that much of a newbie. And will that Make it die at random times ?
Old January 14th, 2012, 01:25 PM   #4
35.9@16.99
iTrader: 17 reviews
Ford uses a PATS system (passive anti theft system). There is an electronic device in the key that communicates with the power train control module (PCM) to allow the car to start. The signals are relayed through a device in the steering column that may be malfunctioning in this car. Try tilting your wheel in different positions and see if it won't start. could have broken wires
The transceiver is easy to replace.
1. Remove the plastic parts around the steering column
2. remove the lock cylinder. Put the key in and turn it to run and push in on the retaining pin with a punch or similar tool and pull the cylinder out.
3. remove one screw and remove the transceiver and disconnect the wiring connecter. The transceiver sits in the hole the lock cylinder goes in.
4. install the new one and put it back together.
Old January 14th, 2012, 01:26 PM   #5
35.9@16.99
iTrader: 17 reviews
There is a chip in your key that may not be sending signals too.
Old January 14th, 2012, 01:35 PM   #6
01 Mustang Gt
Thats what I was thinking . Dont you have to take the whole car and key to reprogram it ? Will I have to take the column apart to see if it a wire. because itll idle all day its just when you drive it . Thats when it dies .
Old January 14th, 2012, 06:39 PM   #7
01 Mustang Gt
Anything else ima be with the car tomorrow to work on it a bit ? Any other things I should check ?
Old January 15th, 2012, 10:31 PM   #8
01 Mustang Gt
Up
Threads Similar to: My 01 Mustang Gt is Shutting off on me.
Mustang Losing power and shutting off RED BONE V6 94-95 6 October 12th, 2010 09:33 AM
Car keeps shutting off........ wikiweak 4V / SVT 4 May 6th, 2010 08:00 PM
03 Mustang chirping then shutting off. mchapa V6 Mustangs 4 February 22nd, 2010 10:54 PM
1988 Gt Mustang shutting off harrylee 5.0 Mustangs 12 July 8th, 2009 01:23 AM
Car not shutting off HELP!!!! koda 279 Classic Mustangs 5 January 23rd, 2008 08:25 AM
