Low MPG and P0190
Old January 14th, 2012, 03:41 PM   #1
mdb12002's Avatar
11.56@119.24
mdb12002 is on a distinguished road
Low MPG and P0190
As the title states, I noticed that my car is only getting around 6-7mpg city and about 10-11 highway. This is under normal highway speeds also. I did not think too much of it at first. I changed the sparkplugs which involved me taking off the COP's, and one was hurting a little bit, the rubber housing came off, and the spring was exposed. I just put the housing back on, and bolted it back in without worries. One day at the track, I was doing a run, and the car bogged down, sputtered, and threw a P0190. I parked the car, cleared the code, and it went away. I drove the car back with no issue with no sign of the code. About 2-3 weeks later, I was sitting at a stop light on my way home to park the car for my deployment, and the code came again, along with the sputtering. The car wont die, just runs like total SH*T. Except this time the car is keeping the code, and wont get rid of it. I know I shouldnt be getting that low of mileage with my setup. I run a P1SC at 9lbs with dual SVT pumps, a KB BAP, and 42lb injectors. I know this has been brought up before, but it has been some time, and I want to know if anyone has experienced this issue lately, and could offer some guidance. Maybe a bad connection with the COP? FRPS? Im lost ):
Just your average '02 GT
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 14th, 2012, 03:48 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
Could have blown your frps sensor or it could be fpdm issue. Your running alot of amps with the twin focus pumps and bap combo
bone stock from the factory!
Old January 14th, 2012, 03:56 PM   #3
mdb12002's Avatar
11.56@119.24
Being I run alot of amps with that setup, should I drop back down to a single pump setup with the BAP? or just replace the fpdm and frps? I already have a FRPS on standby for when I return in the coming weeks. Thanks for your input!
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 14th, 2012, 04:56 PM   #4
mdb12002's Avatar
11.56@119.24
I also read that with dual pumps and a KB BAP, it significantly reduces the life of the FPDM. I thought about upgrading to a dual FPDM setup to reduce the strain of a single one. Any input on this dual setup?
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 14th, 2012, 05:39 PM   #5
stal94gt's Avatar
2003 mustang v6 ;)
slow
Dual fpdms is a good setup. You have to run an additional power wire to your second pump but it prevents thermal shut down and damage. I run a modified fpdm with my dual ford gt pumps and bap combo. It does take quite a bit of tweaking on the fp voltage tables to get it right so be sure your tuner is good.
Old January 14th, 2012, 06:00 PM   #6
mdb12002's Avatar
11.56@119.24
I tried to find a modified fpdm for my '02 gt with no luck. Looks like they only make them for the 03/04 cobras?
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 14th, 2012, 06:01 PM   #7
mdb12002's Avatar
11.56@119.24
Do you think this could contribute to my low mpg?
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 14th, 2012, 06:04 PM   #8
stal94gt's Avatar
2003 mustang v6 ;)
slow
Cobra and gt fpdms are diff part numbers but both work. Do a quick test, pull the reference vac line at the frps and smell for gas. If you smell a strong fuel smell it is damaged. This is not a full proof test cause it could be damaged and not leak fuel.
Old January 14th, 2012, 06:49 PM   #9
mdb12002's Avatar
11.56@119.24
I will do that as soon as I get back on U.S. soil. I appreciate all the help though, I hope I can get it fixed relatively fast when I return! Plan on taking a trip with it
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 14th, 2012, 06:57 PM   #10
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
P0190 is a very distinct code indication a problem with the Vref power to the Fuel Rail Pressure Monitor--read possible causes and diag tips here.
Vref is supplied by the PCM and is normally 5.0V, though anything 4.0V to 6.0V is OK--you can measure it between the brown/white (+) and gray/red (-) wires at the FRPS...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old January 14th, 2012, 07:02 PM   #11
mdb12002's Avatar
11.56@119.24
So your saying the sensor probably went bad? Because I think if the FPDM failed, the car wouldnt be getting ANY fuel, and just wouldnt run, correct me if im wrong. Im new when it comes to working electrical issues on these cars.
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 14th, 2012, 07:10 PM   #12
cliffyk's Avatar
I am saying that, according to the Ford shop manual, P0190 has nothing to do with the fuel pump driver module--and has everything to do with the reference voltage the PCM supplies to the fuel rail pressure sensor--so it would seem most logical to check that first...
-cliff knight-
My Mustang
Old January 14th, 2012, 07:35 PM   #13
mdb12002's Avatar
11.56@119.24
and this is something that could change while sitting at a stoplight? I mean I threw the code originally at the track, but went away for a couple of weeks, then returned for good. Thanks for your guy's help!
Stock bottom end
Slower than yours
459rwhp/415tq
Old January 14th, 2012, 07:48 PM   #14
cliffyk's Avatar
Sure, many components (especially sensors) in a modern EFI system can fail in stages--from intermittent to just plain dead...
-cliff knight-
My Mustang
Old January 14th, 2012, 07:54 PM   #15
mdb12002's Avatar
11.56@119.24
Thats good to know, that what it did. I really appreciate the information! Now I just have to get state-side to start looking into it! only a few more weeks.. its been bugging me since I left back in march of last year haha.
Stock bottom end
Slower than yours
459rwhp/415tq
Threads Similar to: Low MPG and P0190
p0190 help please SnakeBite03 99-04 3 June 22nd, 2011 09:29 AM
Need help!! Code p0190 prochargedGT 99-04 15 April 15th, 2011 07:08 PM
P0190 and P0442 help!! Garagebuilt01 99-04 0 August 12th, 2010 02:21 PM
P0190 Question crappy_head 99-04 14 October 31st, 2008 03:54 PM
DTC p0190 some one out there help PLEASE 46gtstang 99-04 2 October 24th, 2007 08:41 PM
