Burning oil?
Old January 14th, 2012, 09:54 PM   #1
2001 Mustang GT
2001SilvrGT is on a distinguished road
Burning oil?
I got a 01 gt with 89k miles on it for some reason when i start my car it spits out a cloud of blue smoke an when i rev it it does it to (obv means im burning oil) i don't think it could be the piston rings because these motors go awhile before the rings going but could it be my valve seals or guides? causing to burn oil?
BBK Shorty headers,O/R X pipe, Magnaflow Catback
CAI
Accufab 75mm throttle body
C&L Plenum
Tokico Lowering springs
Trans go shift kit
Soon:Comp Cams,SCT Tuner,3:73 Gears,MM Cast Chamber Plates
Old January 14th, 2012, 09:57 PM   #2
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Valve stem seals can certainly cause excess oil consumption issues, and are especially noticable on startup.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old January 14th, 2012, 10:00 PM   #3
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
yep for valve seals, that's my guess anyways.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old January 14th, 2012, 10:01 PM   #4
2001 Mustang GT
it only burns on start ups an light revs though...
CAI
C&L Plenum
Trans go shift kit
Old January 14th, 2012, 10:08 PM   #5
MM's king of Neon's
404 - car not found
17.81@87
Sounds consistent with valve stem seals. Their oil consumption is highest upon startup and idle.
Old January 14th, 2012, 11:33 PM   #6
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
My guess is valve seals. I bought a Harley that had been sitting a long time. It did exactly the same thing. It was the valve seals. Do you have a black oily film on the inside of your tail pipes?
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old January 15th, 2012, 10:53 PM   #7
LowFlyin99GT's Avatar
1999 Mustang GT
LowFlyin99GT is on a distinguished road
I have the same issue on high revs, and it is because my car sucks oil through the PCV system. When I did my intake swap, i freaked cause there was a pool of oil in the lower plenum. 4.6/5.4 have a higher crank case pressure than some other engines, so PCV health is real important! Cheap replacement PCV valves (ie;fram, parts store's house brands) have a flat peice of light weight metal for the plunger. They have a tendency of opening way too soon and get stuck sideways and that keeps them open all the time. I bought the motorcraft PCV, which has a heavier peice with a tapered nipple on the bottom that helps for alignment and seal when its closed. That helped 10 fold. Installing a catch can in the line fixed it completely. I got tired of draining it every couple of days and eliminated it, so i do get oil in on high revs now. Try the Motorcraft PCV, because it will help some. Being that you have oil smoke on start up, does indicate valve seal wear, but the PCV will help some.
Old January 15th, 2012, 11:03 PM   #8
MM's king of Neon's
404 - car not found
17.81@87
True but unlikely given his symptoms. PCV oil is a function of blowby pressure (piston rings), which means you'll get the most oil blowby at high RPM/load, and he's getting it right at start and low load, which sounds like stem seals.
Not to mention all he has to do is look in his intake to see if there's oil. If there is, PCV, if not, seals.
BTW, where in southern Indiana are you?
Old January 15th, 2012, 11:06 PM   #9
2001 Mustang GT
yea an i checked my oil today an its not black an it still at same level when i saw it last time
CAI
C&L Plenum
Trans go shift kit
Old January 15th, 2012, 11:07 PM   #10
1999 Mustang GT
Tell City sir
Old January 15th, 2012, 11:08 PM   #11
2001 Mustang GT
how do i check the intake for oil?
CAI
C&L Plenum
Trans go shift kit
Old January 15th, 2012, 11:11 PM   #12
MM's king of Neon's
404 - car not found
17.81@87
Take the intake off, pre-plenum. Look for oil in there coming from the lines that run to the valve covers. Alternatively take off the CCV lines that run from the valve covers to the intake and see if they're full of oil.
Old January 15th, 2012, 11:12 PM   #13
1999 Mustang GT
Pull the plenum off.
Old January 15th, 2012, 11:13 PM   #14
1999 Mustang GT
right on!
Threads Similar to: Burning oil?
Burning out in the 6 02Sandstorm V6 Mustangs 20 May 31st, 2011 02:38 PM
oil burning ?'s 93lx306dev 5.0 Mustangs 1 April 4th, 2009 10:03 PM
Burning oil 69fastback Classic Mustangs 6 February 15th, 2009 10:46 AM
Fuel Problems Burning Rich / Burning Lean Steves LX 5.0 Mustangs 5 March 21st, 2007 09:46 PM
