2003 GT & 2003 Cobra
Becoming a corner junkie...
Need MORE Termi help (clutch)
I'm at a total loss of what to do now. I installed the clutch quadrant, firewall adjuster, and cable tonight from UPR. I first ran into issues with how fucked up the UPR stuff is. Nothing was threaded right. We had to drill out the holes because they weren't big enough. I took the dust cover off as recommended. I inspected the clutch (no coloring. looks stock?). Now, according to someone when I bought the car, it was supposed to have a stage 2 clutch with stock cable and quadrant. Well thinking this would be a 20 minute job, I went head first into the floorboard to get the new quadrant in. Needless to say after 2 and a half hours, we finished. Now the car goes into gear flawlessly. Not quite butter, but better than it was, but now the clutch is HARD AS F*CK, as in the pedal is now unbelievably hard to push in, not anything like it was with the stock cable. It doesn't have the eventual give like it did, or the recoil (lack of better terms).
Cliffs: Car was hard to get in gear Installed UPR quadrant, adjuster, and cable Removed dust cover (looked stock/no identifiable color)(was told stage 2 clutch when I purchased the car) Now it shifts amazingly The clutch pedal is EXTREMELY hard to push down. I'm now lost.
Formerly known as SVT_WANNABE MILITARY CREW - E-3 - ARMY ANTI-RICE Founder ![]() *My YouTube Channel* http://www.youtube.com/user/PS3Turbostangs?feature=mhee |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
sounds like you may have looped the cable wrong and it is getting excess drag when you push it in.
![]() bone stock from the factory! |
We routed it just like the stock one. My friend said usually he can get the cable off with one hand using channel locks (on the fork) but he said he had to use all his might to get it off with 2 hands. The fork is on the pivot ball too, so now what do I check?
2003 Mustang GT
What stal said, I had this issue too. I'm confused though did you put an aftermarket cable in? If so put the stock cable in. Much better. The cable was routed wrong or is at a bend so the clutch pedal is stiffer, and doesn't come up as quick. You'll notice if you let the car warm up, its slightly easier to push in.
Just check it out again, make sure its not at a bend or anything
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
#5 | |
I'm guessing these symptoms aren't really leading to it being a clutch problem?
2003 mustang v6 ;)
slow
No break in period for a cable. I have gotten a few after market clutch cables that are longer than stock which don't ever work out. Did you also remember the 8mm bolt that holds the cable to the fender
2003 Mustang GT
Damn stals to quick. Yeah aftermarket are usually to long and you'll have to bend it at a certain angle so the pedal will be stiffer. Use the oem cable. I'm telling you. So much better.
And yea don't forget about the bolt in the fenderwell that goes into the bracket on the cable.
Let me make sure.
Ok, the cable is still attached and isn't in a bind. It moves freely throughout the cable sheathing.
I'm almost 100% sure the cable is the same length.
2003 Mustang GT
Put the stock cable back in.
2003 mustang v6 ;)
slow
it could be the cable, or it could be the sleeve on the tob needs greese. they are common to break and go bad so if you drop the trans i would swap it out.
2003 Mustang GT
Also make sure your new quadrant is shimmed properly or you chew your cable up
Priest of the Car Gods
Have you tried lubricating the cable inside the sheath? Either with powdered graphite or teflon spray?
Ok, the clutch wasn't as stiff before the new stuff. Now it is.
So before the pedal was easier and shifting was harder. Now, the pedal is harder and the shifting is easier. The cable moves just as good as the stock cable did so, why exactly would it affect how hard the clutch pedal is when we didn't mess with the clutch? I'm only asking because it was fine before. I basically traded one problem to another, well I would think so. Do any of you think it could be the clutch that is being the issue?
2003 Mustang GT
How many times do we have to say it? Stock cable!!!!!!!
2003 Mustang GT
^^this...all the research I have done basically points to the stock cable being the way to go. People have problems all the time using aftermarket cables...
Sent from my Autoguide iPhone app
![]() '03 GT w/BBK CAI, MAC Pro chamber, Borla Stingers, MGW Orange, SCT X3, and some make it sexy mods ![]() '89 GT 5.0 w/full bolt ons-SOLD '04 STi w/ A'pexi N1 catback and accessport-SOLD '00 Audi A6 2.7t stock - DD/Wifey's whip |
I'll do it this coming weekend Shaun. Thanks.
Threads Similar to: Need MORE Termi help (clutch)
| termi clutch/fly in a bullitt? | Karl Rodg88 | 99-04 | 3 | February 23rd, 2011 01:04 AM |
| ocean city and we got a termi down, we got a termi down. | 07stanggt | 2005 - 2010 | 16 | October 14th, 2008 05:04 PM |
| any of you changed out clutch cable and quadrant on a termi? | WilltheThrill | 4V / SVT | 24 | September 2nd, 2008 01:28 PM |
| factory 03 termi clutch cable | WilltheThrill | 4V / SVT | 5 | June 7th, 2008 12:49 AM |
| termi vert VS termi coupe | mikeGTmurr46 | 4V / SVT | 35 | February 8th, 2008 10:57 PM |
