yay or nay
Old January 15th, 2012, 07:13 AM   #1
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
yay or nay
I found this on ebay
Link: 8.8" Ford Mini Spool - 28 Spline - Mustang - 4x4 - NEW | eBay
Is it worth it since its still a 28 spine?
Rock stock
Old January 15th, 2012, 01:33 PM   #2
number1gt's Avatar
2002 mustang gt
Rock stock
Old January 15th, 2012, 02:49 PM   #3
GreyWarrior07's Avatar
2001 Mustang GT
8.98 1/8
GreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura about
why do you want a mini spool?
CHECK MEH GARAGE
BAMA Performance Drag Team #9
Old January 15th, 2012, 03:04 PM   #4
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
Why u mad man. A mini spool is a good cost effective way to have a true posi in the back. Mini spools slow you to keep your c clips. It also is easy to install since there is no need to re shim your rear end
bone stock from the factory!
Old January 15th, 2012, 05:34 PM   #5
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
that wouln't work with your factory carrier so after you add a new carrier/etc to the bill then it's not really worth it.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 15th, 2012, 05:47 PM   #6
skidad62's Avatar
2003 Centennial Edition
skidad62 will become famous soon enoughskidad62 will become famous soon enough
I'd skip a 28 spool - not great for the street and yet not heavy enough for the track?
Vortech YSI driven MMR 1000
Old January 15th, 2012, 06:56 PM   #7
stal94gt's Avatar
2003 mustang v6 ;)
slow
Motive Gear MS88-31 - Motive Gear Mini Spools - Overview - SummitRacing.com
this is the spool made for our cars and its 31 spline. but before ordering open your diff cause later new edge mustangs had closed carriers. i know my 2000 had an open carrier so it could be used. i had one in my 93 and it was great for the track but crap on the street.
Old January 15th, 2012, 09:16 PM   #8
number1gt's Avatar
2002 mustang gt
I wasn't mad lol I just wanted someone to give some input, I saw that its cheap so I asked, so casper are you saying it wont work with my factory rear end? Im confused
Rock stock
Old January 15th, 2012, 09:20 PM   #9
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
although I can't seem to find a straight answer on the motive gear mini spool. the one the o/p linked to (along with most others) clearly states that an "open" carrier is required for installing the mini spool (along with most drop in e-z lockers)
what they are refering to when they say "open" carrier is a non trac-lock/non posi/etc carrier (ie. "one wheel peel").
since all GT's come with trac-lock, thats why I made the comment I did.
2012 300a GT auto
Old January 15th, 2012, 09:20 PM   #10
number1gt's Avatar
2002 mustang gt
I see that link you posted would probably be a better route, I thought a new diff would just consist or taking the carrier caps off and unbolting the ring gear...am I missing something?
Rock stock
Old January 15th, 2012, 09:24 PM   #11
number1gt's Avatar
2002 mustang gt
Okay the way it was said just confused me, so like the 7.5 rear ends would be an open carrier and our 8.8s would be a closed carrier.
I thought you were saying I would need a new rearend so disregard my previous post
Rock stock
Old January 15th, 2012, 09:24 PM   #12
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
not really, you'd at least have to check the gears due to having taken every thing appart & installed the new carrier.
a much better & easier way to go is just freshen up the carrier you already have with new clutches or just do a 31 spine swap.
2012 300a GT auto
Old January 15th, 2012, 09:25 PM   #13
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
it not really open & closed, it's open or trac-lock.
2012 300a GT auto
Old January 15th, 2012, 09:32 PM   #14
number1gt's Avatar
2002 mustang gt
Well the link stal posted is 31 spline so I would just need axles
Rock stock
Old January 15th, 2012, 09:35 PM   #15
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
& a 31 spline carrier. the carriers themselves are diffrent from 28-31 spline.
sorry bud, no easy way out.
2012 300a GT auto
Old January 15th, 2012, 09:46 PM   #16
number1gt's Avatar
2002 mustang gt
Okay so you have to buy a carrier to? I just thought it was complete, I haven't eatin researched them before so I didn't know
Rock stock
Old January 15th, 2012, 09:53 PM   #17
stal94gt's Avatar
2003 mustang v6 ;)
slow
a mini spool can be run in the older diffs, i belive ford changed the diff after 01. i would not drive a car with a spool in the back on the streets. i just like mini spools over full spools cause you dont have to run c clip eliminators. im not 100% sure on the year ford changed out the diff, but the older style is what alot of companys base after market guts off of. i had a buddy that ran a power trax locker in the back, but it was junk.
Old January 15th, 2012, 09:54 PM   #18
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
Just weld your spider gears together. Cheaper and easier. I did this on my car/motor. Been holding strong. 600rwhp on spray. 437rwhp on motor and dumps on slicks at the track and DRs on the street.. 28 spline BTW.
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Old January 15th, 2012, 09:54 PM   #19
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
pretty much.
bottom ine with them is they are more geared for 4x4's than cars.
make life easy on yourself & just stick with a trac-lock till the car needs something better.
2012 300a GT auto
Old January 15th, 2012, 10:05 PM   #20
number1gt's Avatar
2002 mustang gt
The car is driven on the street about 2k miles a year, do you get any hopping around turns? If not and the axles will hold up ill do that, I don't plan on seeing over 400 with this car so yeah
Rock stock
