2003 ford mustang gt
13.9 stock
upr adj control arms
anyone running these 1999-2004 Ford Mustang Pro Street Adjustable Upper & Lower Control Arm Package local guy has em for sale, but they have soild bushings any pros/cons about that? my car is a DD right now so i wont install them till after i get a 2nd car and plans for it are track 1/4 only
thanks guyshere are some pics ![]()
k&n cai, mangaflows exhaust, summit udp's, 24lb injectors, 78mm bbk plenun, tri-ax s/s, a/c delete,3.73's, aluminum drive shaft, upr upper/lower control arms, solid motor mounts, bbk heades, upr xpipe,bbk cc plates, camber bolts.bama tune
13.9 stock
no one uses these?
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
I have them. They are ok a little noisy but decent for the track. I would spend the money on base line or team z. Coil overs with 110# spring and ajustible shocks in the back.
![]() bone stock from the factory! |
13.9 stock
ok thanks stal, but do you use the solid bushin too?
2003 mustang v6 ;)
slow
Yes you want hemispherical ends like those. I have my torque boxes welded along with supports.
13.9 stock
ok thanks stal once again i'll be buying these shortly then
12.73@111.36
That's the UPR ProSeries. I'm running them with spherical busings and I also have the torque boxes and tubes welded. The only difference is that mine have the sway bar mount. Like Stal said, the steel on steel has more NVH. It took a while for me to get used to it. I had ProTree Racing do the installation and welding. They told me they had 9 second cars running the same control arms. But they also recommended Team Z if I was going to be on the track a lot.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
2003 Mustang Fauxbra
N/T @ Fast
I'm running them and they're fine. A little much for a DD in my opinion. I prefer poly bushed on something I DD because of the noise.
![]() All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now? 03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold |
2004 mustang gt
I ran them n like them
04 mustang gt dropped on true forged rims with a little d1 408whp 390tq 10psi
Threads Similar to: upr adj control arms
| front control arms (A arms) | smokey9027 | 94-95 | 1 | August 2nd, 2010 02:48 AM |
| Best rear lower control arms? need control.. | Speeddemon | 94-95 | 6 | April 19th, 2010 02:55 AM |
| steel control arms vs aluminum control arms | Saleenwolf720 | 99-04 | 1 | October 15th, 2007 01:32 PM |
| Upper Control Arms & Lower Control Arms | LUV2XLR8 | 2005 - 2010 | 6 | October 6th, 2007 11:45 AM |
| Steeda lower control arms (Trailing arms)? | kmjsmith | 2005 - 2010 | 6 | July 4th, 2007 04:59 PM |
