EEC stuck in closed loop....
Old January 15th, 2012, 11:44 PM   #1
LowFlyin99GT's Avatar
1999 Mustang GT
LowFlyin99GT is on a distinguished road
Is this an issue that may be able to be resolved without reflash or replace? I haven't had the chance to get it on a good scan tool, but the Innova at my store tells me that the system rediness won't complete. It had been driven long enough that it should have gone into closed loop and be runnin off the sensors. I have never seen any PCM of any kind do this, and im not getting a single DTC. Any advice would be great. Its prolly getting hooked up to one of those expensive Snap-On jobbers tommrow, but ideas flowing in ASAP is cool with me! thanks in advance!!
Old January 16th, 2012, 12:22 AM   #2
1999 Mustang GT
i have open and closed loop backwards...my bad.
Old January 16th, 2012, 01:40 AM   #3
NeverEnuff's Avatar
1989 LX Coupe
7.1@99mph
NeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura aboutNeverEnuff has a spectacular aura about
How long are you driving it for?
89 LX Coupe-Carb'd 32v-437rwhp NA, 592rwhp N20
01 Bullitt-32v swapped
96 GT-Cammed E85
www.KPERacing.com
Old January 16th, 2012, 08:56 AM   #4
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
A number of things can cause the car to stay in open loop, and most are sensor related.
The first I would look at is to make sure your upstream HOS (heated oxygen sensors) are hooked up. Then check other sensors, such as coolant temp and MAF. Make sure they are all hooked up and functioning. If the car (or sensor in the HOS case) isn't getting up to temperature, or if it does not have sufficient data for air/fuel trims it will stay in open loop.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old January 16th, 2012, 09:59 AM   #5
limited's Avatar
99 limited edition vert
limited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of lightlimited is a glorious beacon of light
do you have any mods?chips? tune?
KB'd 446rwhp/451rwtq, Mustang Dyno http://www.youtube.com/watch?v=3ZDpQ0EEm1M
Tuned by Joe at http://www.tricktuners.com
Old January 16th, 2012, 02:51 PM   #6
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
^^^This.
Shouldn't be an EEC problem, should be an input to the EEC problem.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Old January 16th, 2012, 10:39 PM   #7
1999 Mustang GT
O2s are all hooked up. Car is getting to temp, but when i hook the scan tool up to it, it says that readiness moniters not complete (P1000) and it flashes the EVAP monitor is the one thats not ready. I know nothing about the EVAP system so i dont know what to check. Mods are; BBK CAI and 75mm TB, Granetelli plenum, modified factory H-pipe with 3" crossever and downstream cats gutted into Mac mufflers with no tails. The car was working just fine up until about 2 months ago.
Old January 16th, 2012, 10:41 PM   #8
1999 Mustang GT
over an hour on multiple occasions
Old January 17th, 2012, 05:56 AM   #9
bulloch27's Avatar
N/T @ Fast
P1000 is common and won't clear itself for a few miles of driving, sometimes more than a few. O2s aren't the only sensors in this equation. MAF, IAT and ECT play a large role, read the outputs on them and determine if they are functioning.
Old January 17th, 2012, 06:38 AM   #10
MineralGreyGT's Avatar
MineralGreyGT will become famous soon enough
It's not a matter of time its a matter of distance. Reset the system and drive about 100 miles then check again.
http://img192.imageshack.us/img192/9175/sig1xts.jpg
Old January 17th, 2012, 08:35 AM   #11
MM's king of Neon's
404 - car not found
17.81@87
Ok, this sounds like your problem is your P1000 code, not open loop. Having a P1000 code DOES NOT mean your car is in open loop. You can smell when your car is in open loop, and your gas milage will suck. You know how it smells real rich at startup and idles high, then the smell dissipates and the idle drops? That's it going into closed loop. All P1000 means is that one of your systems is "not ready," it will still go into closed loop with a P1000.
Originally Posted by bulloch27 View Post
P1000 is common and won't clear itself for a few miles of driving, sometimes more than a few. .
It's very common. Have you cleared codes recently? That will do it. You'll have to go through the Ford drive cycle for that monitor for the code to go away, though my EVAP monitor usually pops within 40mi (sometimes as little as 5) if I have an EVAP leak.
If we can narrow this down to an EVAP system problem I wouldn't worry. EVAP is horrible, and really doesn't effect your driveability or performance, it's just another emissions control.
Old January 17th, 2012, 01:41 PM   #12
1999 Mustang GT
Thanks for the info. Gonna throw it on a good diagnostic tool today and see what happens.
1999 Mustang GT Convertible Mods-BBK CAI and 75mm TB, Granetelli Plenum, modified stock H-Pipe (3" crossover, gutted downstream cats), Mac Mufflers with no tails. Long tube headers, cams, tuner and dyno tune comming soon.
Old January 17th, 2012, 10:40 PM   #13
1999 Mustang GT
ok....so after 3 hours of diagnosis....here is what we found. Vac leak in the EVAP system and a dead ABS module. Gonna go through the EVAP system Friday night and see if maybe i got a wireing issue to the abs module. Will post results.
Old January 18th, 2012, 08:07 AM   #14
MM's king of Neon's
404 - car not found
17.81@87
That is good news.
EVAP really has no point, and you can live without ABS. Hell, the PO of my car destroyed the left front ABS wiring, and let the rear ABS sensor drag on the ground. I don't need it.
Better still, look how many guys do the ABS delete.
Old January 18th, 2012, 10:38 AM   #15
1999 Mustang GT
I know the evap has no point....but a vac leak is a vac leak.....and if the abs isn't a simple fix....it's not getting fixed.
Threads Similar to: EEC stuck in closed loop....
Intake manifold runner control valve stuck closed FLEX4.6 V6 Mustangs 17 May 25th, 2011 07:51 PM
closed loop smoke p4ndiamond 96-98 3 March 24th, 2011 09:26 PM
open loop and closed loop demonicus 5.0 Mustangs 7 February 28th, 2009 11:57 AM
VT engines is closed? 03 R Code 4V / SVT 22 January 22nd, 2008 06:19 PM
