P0720 Code
Old January 16th, 2012, 11:00 AM   #1
waynetx383 is on a distinguished road
P0720 Code
I have an '04 and I went out a few weeks ago and everything worked great. The next day I had no speedo and threw a P0720 code. I've replaced the OSS sensor, and done the gauge cluster self diag test. The old and new sensor both ohm test fine and the gauge sweeps properly. I've also checked the signal voltage and ohm readings per the ford service procedures and they all check out ok. The wire harness looks fine with no visible cuts or other damage to it. I had the trans rebuilt a couple months ago and noticed when I pulled the old OSS sensor that the magnet on the end was covered in metal shavings. Seemed a bit odd on a rebuild and makes me wonder about the quality of their work. From what I've read the OSS reads a 12 teeth gear as it rotates in the output shaft and uses that reading to calculate the speed of the vehicle. Is it possible that the gears broke, or do they serve another function as well? This is the 3650 5-speed btw. Does anyone have any other suggestions? The ford service manual says replace the PCM if everything else checks out, but it seems far fetched to me that it would only throw one code if the PCM was bad.
Threads Similar to: P0720 Code
DISCOUNT CODE DELETED - New Code Available - Please Read! AMNick American Muscle 86 May 14th, 2012 08:22 PM
How to Fix Airbag Code and EGR Code ModMustang97GT 96-98 2 April 10th, 2011 10:17 PM
SES light-code P1401 code-& DPFE sensor ?'s PacificMustang01 V6 Mustangs 6 May 18th, 2010 02:39 PM
code help 99 gt 99-04 4 September 3rd, 2007 10:11 PM
What would cause this code? hawks05 99-04 3 March 16th, 2007 05:17 PM
