wheel stud broke now what
Old January 16th, 2012, 12:33 PM   #1
1999 mustang gt
14.04@99.57
Imslow is on a distinguished road
i was putting on my new wheels and was breaking the lugs loose and with barley any effort one broke off.. i lifed the car started taking the lug nuts off and the last one right before it would come off, just starts spinning which i assume the stud is spinning with it. so i put the lug nuts back on and could not get that last one to tighten anymore like it was spinning again. so i assume i have 2 studs to replace, i backed out and drove 10 ft and there was vibrating coming from the passenger front(which the broken studs are) is this caused by the studs being like this? and if so am i going to have to tow it to a shop and have them replace the studs aswell as the hub? any info would help never had this happen before.
Old January 16th, 2012, 12:36 PM   #2
gt_andy's Avatar
13.10@103
gt_andy is on a distinguished road
Send a message via AIM to gt_andy
If its the front the studs they are pretty easy to replace..
Just go to autozone and get new ones..
2000 Ford Mustang GT 5spd (TOY)
1997 Ford Tunderbird LX = Daily Driver
Old January 16th, 2012, 12:39 PM   #3
T-Lee. 30's Avatar
03 gt, 96 tbird, 05bv gxp
Faster than trolls!
T-Lee. 30 is just really niceT-Lee. 30 is just really niceT-Lee. 30 is just really niceT-Lee. 30 is just really nice
Send a message via Yahoo to T-Lee. 30
I had it happen to my front studs like 8 years ago on my cougar. Just bang them out with a hammer and replace them with new ones.
03 V1 S trim @5psi 339/359 3:73's Iraq and Afghanistan War Vet 4 deployments from 01-08.My Wife is also a War Vet
Old January 16th, 2012, 12:44 PM   #4
1999 mustang gt
14.04@99.57
alright thanks, any idea of how much they cost? and are they easy to replace?
Old January 16th, 2012, 12:47 PM   #5
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
they are easy to replace, and they are only a couple bucks each.
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old January 16th, 2012, 12:49 PM   #6
'66, '83, '89, '04 & '11
thunderbolt64 is on a distinguished road
usually no more than 2 bucks per stud
check the hub assembly and make sure the stud hole is not cracked
as previously stated, knock stud out and press new one in
Old January 16th, 2012, 12:49 PM   #7
1999 mustang gt
14.04@99.57
good to hear, any tips i should know on how to replace them
Old January 16th, 2012, 01:03 PM   #8
T-Lee. 30's Avatar
Faster than trolls!
knock the old ones out with a hammer and put the other ones in. if you dont want to try and bang the other ones in put spacers on the stud and put the bolt on and tighten it down untl you see the stud is all the way in.
Old January 16th, 2012, 01:23 PM   #9
1999 mustang gt
14.04@99.57
thanks for the info
Old January 16th, 2012, 02:10 PM   #10
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
wheel studs are easy to replace i break them all the time. once the wheel is off it takes me about 3 min to replace with mistakes.
i fish out the stud with a magnet stick
bone stock from the factory!
Old January 16th, 2012, 02:12 PM   #11
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
Dont take it to a shop, worst case scenario you just buy a new assembly for 40-5 bucks and end up with a new wheel bearing too.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old January 16th, 2012, 02:22 PM   #12
KV007's Avatar
2003 Mustang Gt
Slow
KV007 will become famous soon enough
they suck so much ass man. always happens. especially when it happens to the back and its stripped out so u have to get replacement 31 spline axles...
409rwhp at 4500 rpms.Vortech V1 Intercooled,kurgan motorsports powerpipe, 3.12 pulley, all Mac Exhaust,Sct Tuner,Bolt Ons,Cobra Brakes,MM cc plates,Vis 2000 cobra r hood,MGW shifter,Strange 31 Spline axles,Eaton Possi
Old January 16th, 2012, 02:36 PM   #13
1999 mustang gt
14.04@99.57
thanks for the vid, when i get out of work im going to go pick some up and try it. thanks guys
Old January 16th, 2012, 02:39 PM   #14
2000 gt
mustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nicemustanginky is just really nice
if they wont easily come out a little heat goes a long way, just get a propane torch and heat up the hub assembly a bit and you'll be good to go.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tq
HARDCORE CREW
BRIGHT ATLANTIC BLUE CREW #1 MEMBER
Old January 16th, 2012, 02:57 PM   #15
1999 mustang gt
14.04@99.57
so just remove the wheel. do i have to remove anything else?
Old January 16th, 2012, 03:02 PM   #16
stal94gt's Avatar
2003 mustang v6 ;)
slow
I don't take off the brakes and rotors. But it is alot easier if you do. I use a magnet stick to fish the stud threw
Old January 16th, 2012, 03:06 PM   #17
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
Punch the stud out.
Place new stud in hole.
Hand tighen a lug nut on it.
Tighten with a breaker bar.
Make sure its sucked into the hole properly.
Voila, job well done.
Old January 16th, 2012, 03:07 PM   #18
1999 mustang gt
14.04@99.57
seems easy enough, wont get a chance until tomarrow to do it. hope it goes smooth
Old January 16th, 2012, 05:36 PM   #19
WKvernich's Avatar
1999 Mustang GT
WKvernich is on a distinguished road
It's a lot easier with an impact gun. I did this two days ago, literally took 10 minutes once I got everything off.
Old January 16th, 2012, 05:40 PM   #20
stal94gt's Avatar
2003 mustang v6 ;)
slow
Of course its easy with an impact gun but someone can do it just as fast if not faster than I did in my vid with simple hand tools. I made a few mistakes
Threads Similar to: wheel stud broke now what
stud broke in my manifold HELP :( 02GT89 99-04 1 February 4th, 2011 08:32 PM
Broke a dang lug stud rk_2000_Z/28 4V / SVT 16 June 29th, 2010 02:29 PM
broken wheel stud ddarkslayer 5.0 Mustangs 13 October 18th, 2009 07:14 PM
Header Stud Broke TheWeiser1 Modular Mustangs 2 March 3rd, 2008 10:09 PM
Wheel Stud Replacement 2000v6 V6 Mustangs 5 September 11th, 2006 10:42 PM
