will these wheels fit? need input on em asap?
Old January 16th, 2012, 04:40 PM   #1
zinsavage123's Avatar
2001 Mustang GT
12.33@111.23mph
zinsavage123 will become famous soon enough
I have a 01 gt and a guy wants to trade me these for my cobra r"s. Weld pro stars
Front 15x3 1/2", 175/80/15 tires
Rear 15x10 6.5" spacing, 275/60/15 tires
Now he said they were on a 97 gt and he has and ran 1/4" spacers on front. Now will these fit with everything I listed on my 01 gt and what about the spacers a lot say no to spacers is it that bad pros n cons of it? I really want these if it all fits and I wanna know how to make em work with spacers or whatever I need to do?
2001 Mustang GT - mods+pics in garage, tuned by matt@performance evolution
1996 Civic DX - my dd
Old January 16th, 2012, 04:50 PM   #2
GreyWarrior07's Avatar
2001 Mustang GT
8.98 1/8
GreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura about
Your going to need to run spacers on the fronts, or grind your brake caliper (which isnt recommended) And your going to want longer wheel studs for the front and backs, especially in the front.
CHECK MEH GARAGE
BAMA Performance Drag Team #9
Old January 16th, 2012, 04:57 PM   #3
2001 Mustang GT
12.33@111.23mph
So my stock wheel studs won't work? What's the deal with spacers a lot vote against em but if thays the only way to make em work whT can u do?
Old January 16th, 2012, 04:57 PM   #4
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
+1 this guy is all fact!
MM FOBRA CLUB CO-FOUNDER
Old January 16th, 2012, 05:01 PM   #5
termi_GT's Avatar
12.41@114
If you are going to use spacers in the front MAKE SURE they are hub-centric. That way the spacer is centered on the hub. If you use the cheap spacer it is difficult to make sure they are centered and then you lugs are trqed down evenly.
I do not think that they make that small of a spacer in Hub-centric so its use at your own risk.
Old January 16th, 2012, 05:06 PM   #6
2001 Mustang GT
8.98 1/8
I run these,
Just Mr. Gasket ones from jegs.
People say there shit, they work and get the job done. I just always make sure when im torquing them down that its centered and not to one side or the other. And im only running my prostars when im going down a track.
CHECK MEH GARAGE
Old January 16th, 2012, 06:37 PM   #7
skidad62's Avatar
2003 Centennial Edition
skidad62 will become famous soon enoughskidad62 will become famous soon enough
I run that set up - I use the 1" hubcentric spacer up front. Trimmed the non threaded tips of the OEM studs for now so they fit subflush with the back of the wheel on the other side of the spacer. Will switch to 3.5" ARP studs later and punch out the studs in the spacer.
No grinding needed on the calipers.
I run the 3.5" ARPs in the rear to be track legal - you can get away with OEM studs for street use.
Vortech YSI driven MMR 1000
Threads Similar to: will these wheels fit? need input on em asap?
Wheels opinions.. I NEED your input on size, brand, model.. etc Mystry 99-04 15 November 26th, 2011 04:56 PM
input on this deal..need ASAP Chris747 The Clubhouse 13 April 18th, 2011 07:06 PM
Quick Question About Wheels!!! Need Answer Asap!! RedDevilGT V6 Mustangs 3 August 13th, 2009 10:45 PM
Need help with wheels asap ~C~ General Tech 8 July 29th, 2009 03:14 PM
wheels & tires help please! asap! cristo General Tech 0 March 23rd, 2007 04:12 PM
