5.4 Windsor Swap
I'm gonna swap the blown motor in my car for a 2000 5.4 windsor and was wanting to know what all was involved in the swap and what will bolt on the 5.4 from the 4.6 and if my intake and TR-3650 will bolt up?
2002 Redfire Metallic Ford Mustang GT - 5.4 2V, Steeda CAI, Bassani X-pipe, 24lb. inj., 4.10 gears, 75mm TB, UDP's, Ported Plenum, AWAITING DYNO NUMBERS AND TUNE!!!!! |
are yoiu staying with the sohc or dohc. if your sticking with the 5.4 sohc, it will be a simple swap in. if your switching to dohc, youll need the wiring harness and ecu to make er run right
#3 | |
Is the 5.4 sohc the same block as the 4.6? The biggest thing is will the intakes interchange? B/c If I go this route I want to put my KB on it too.
Mustangless atm 2006 2500 HD Diesel. Built allison trans and other goodies
its the 2V anyone know the stock RW numbers on the 4.6 and 5.4 2V's
the 5.4 will make a lot more tq and power. no they are not the same block dimensionally. physically they look the same but the 5.4 is a little bigger i do believe
#6 | |
Kinda sucks, If it would work I'd forge a 5.4 block and slap my KB on it.
1990 GT
you can still use the 4.6 intake manifold. you just need adapter plates. reichard racing makes them. the only thing is they are slow as shit making stuff unless you get lucky and they already have some made. heres a link to them http://www.reichardracing.com/46to54adapter.php
1990 5.0 getting all fixed up for next season 2004 mustang gt 520rwhp, 491 trq sold
#8 | |
I might have to look into this a bit more, could be fun!
#9 | ||
1999 Mustang GT
it can be done but it's not easy, the 4.6 and 5.4 are not the same block the oil pan on the 5.4 is deeper and will not clear the k-member, I know what you are thinking "but they did it to the 5.4 2000 Cobra R" that block was specifically built for the cobra. Now you can put the truck motor in a mustang you will need to buy a special K-member for the car "look in a mustang magazine I see them all the time" I don't think the mustangs computer will work with it though so you'll have to take the trucks and flash it for what you want, my brother in-law did the swap with a 96 gutted v6 to a 5.4 and it was a pain in the ass, but it is doable.
Mamma I wanna go FAST!
WRONG!!!!!!!everything bolts up....mine is already in
Proud American
You got the 2V already inthere? Congrads
1999 Mustang GT
all power to ya, we had to buy a new k-member.
yeah i got to rig the return style fuel rails though...i did crank it up and it sounded mean i cant wait to drive it...BTW i'll post pics when i clean it up a bit as i had to make splices and such the only problem i am having aside from the fuel rails is the exhaust gotta bend the bassani X-pipe and grind the flange down on the passenger side
wild steeda what yr did you do the swap on mine was a 02 and the steering arm was in the way but i just shook it for a min and it went in there...nvm just reread your post thats why because the k members are different for the 96-98 and the 99-04's and the 99-04's computer will work fine just needs to be reflashed
had to use stock 5.4 intake manifold and 4.6 exhaust manifold. if you want to use the 4.6 UDP's swap out the water pumps
as the snout on the 5.4 is longer than the 4.6's thats the only swapping i had to do...the exhaust manifolds and the water pump and splice(extend) the MAF Sensor, Throttle Position Sensor, and the Coolant temp. sensor and get a longer throttle cable
Threads Similar to: 5.4 Windsor Swap
| Windsor Swap Into A SN95 | Justincredible | 94-95 | 21 | May 17th, 2012 03:41 PM |
| windsor or BB? | sloppyjosey | 5.0 Mustangs | 18 | October 26th, 2007 12:25 PM |
| 351 windsor | Iownastang | 5.0 Mustangs | 7 | July 24th, 2007 12:36 PM |
| 351 Windsor | dragpipe | General Tech | 5 | February 28th, 2007 06:40 PM |
| Want to swap in a 302 Windsor into a 2001 GT. | Mus408 | Modular Mustangs | 1 | February 5th, 2007 06:43 PM |
