2002 GT high mileage Help
Hello all I own a 2002 GT that currently has 125,000 miles on it, when I let it idle for a while and give it some gas a little bit of white smoke comes out of the exhaust, i just replaced the valve stem seals and it is still doing it, any thoughts on what it might be?
Also if I were to get this engine rebuilt and wanted to add a supercharger on to it what all would i have to do to the internals to make sure i could get a good boost on it? |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
its common during the winter to have white smoke come out of the exhaust. my car dumps out a ton of white smoke
![]() bone stock from the factory! |
00 Mustang GT Vert/88 5.0
in order to get GOOD boost you would need to replace your internals, if you wanted to stay under 10PSI you wont need to do anything except get a good tune after your supercharger install. the safety of your car boils down to your tune.
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
12.73@111.36
Condensation. This time of year water drips out of my exhaust when I first start the car.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
2002 Mustang
launch soft, shift slow, stay slow
![]() ![]() iTrader: 4 reviews
If you want boost and are already rebuilding it you should look into lowering the compression a little bit.
"Happiness is being blown and stroked at the same time" V6 => vt 302 forged stroker My Build Thread click link http://www.moddedmustangs.com/forums...shs-build.html
2003 mustang v6 ;)
slow
Stock slugs are 17cc dish which is fine for fi. Most I would lower it would be 18cc dish
2001 Gt
Is that the only way that you get white smoke? Does it smell like oil? If so it's 99% a ring on a piston going bad and you need to rebuild the bottom end. I would not out any boost to a motor like that!
what colour is the smoke? in the winter my car smokes like crazy, but it's white/grey which is normal.
Blue=Oil White=Coolant Black=Rich |
12.73@111.36
No. White smoke doesn't smell like oil. If you are burning oil then you will get a bluish colored smoke and oil residue in your tail pipe. I don't have a lot of experience rebuilding engines, but the times that I've seen bluish smoke on an otherwise good running motor, it was valve seals.
04 mustang gt
7.21 @ 98
white smoke can smell like oil. my girlfriends car blows white smoke on start up and its definitely oil...does it in any climate.
![]() cams + 150 shot |
12.73@111.36
Interesting. Mine just smokes and drips water on the ground. No smell at all. Do you think its the valve seals or rings?
I run 12lbs on a 148k mile motor. No problems for 25k miles now. Before that I ran about 20 bottles of nitrous through it at 125hp and 150hp settings. Keep the power under 450rwhp, dont miss any shifts. Will last along time. Usually.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
Thanks for all the answers, It does not smoke while driving nor on start up but when idling for several minutes and give the gas a punch it will puff out, looks to me like white smoke and smells like shit. but the motor runs great? its just embarrassing when i take off from a light and dump smoke on that car behind me..
Threads Similar to: 2002 GT high mileage Help
| high mileage gt | HMStang217 | 96-98 | 6 | August 15th, 2010 11:16 PM |
| Cam for 03 high mileage | clodingos97 | 99-04 | 16 | August 1st, 2009 06:42 PM |
| High Mileage | KIKa55GT | 96-98 | 11 | January 21st, 2008 08:31 PM |
| GOOD MILEAGE FOR 2002 GT? | phimpju | General Tech | 7 | November 7th, 2007 12:59 PM |
| High Mileage | stanginit | 99-04 | 3 | August 14th, 2007 11:54 AM |
