Vortech questions
Old January 17th, 2012, 05:30 AM   #1
hippojumqer is on a distinguished road
Question
Vortech questions
I am thinking about picking up a vortech V1-SQ complete kit soon here but i just don't know if its a good idea..
My car is completely stock except gears and exhaust and i have an sct tuner..
I guess my question is will this kit blow my motor or tranny or rear end?
I would definitely go with a conservative tune so what would my numbers look like if i dyno'd considering my short list of mods? What are some things i need to be cautious of running this kit on a stock motor?
It comes with a 2.8 pulley.. I heard that i would need a bigger pulley to run on a stock motor. True or false?
Thanks.
Old January 17th, 2012, 05:39 AM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
i take it your buying a used kit. for a v2 s trim i would go with a 3.33 if non-intercooled and want to put out roughly 10-11#. if you want to keep it safe a 3.6 pulley will make around 7-8# non ic. as for hp you will make depends on how agressive your tune is. if you run the 3.6 pulley with lets say 14 degrees timing non intercooled you could see between 350-360. if you run the 3.33 pulley with 14 degrees timing you could see 360-370 hp. safe tune for me would be 11.4-11.6 af with 14 degrees timing and have the computer pull timing at intake temps over 100 degrees.
bone stock from the factory!
Old January 17th, 2012, 06:56 AM   #3
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
2.8 is going to be way to much to run Like stall said. You will be fine running the above mentioned combination without the fear of blowing your motor. these motors are tougher then they get credit for. It is rare for one to blow unless it has been severly abused beyond its capabilities or poorly maintained.
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old January 17th, 2012, 08:51 AM   #4
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
In general 8 psi non-intercooled or 10 psi intercooled is reasonably safe. The transmission and rear end will be fine unless you are doing hard launches with drag radials at the track and power shifting.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old January 17th, 2012, 10:43 PM   #5
apalladino is on a distinguished road
I dont want to hi-jack your thread, but can one of you point me in the right direction? I'm trying to find info on supercharging a 32v, roots style.
thanks
Old January 17th, 2012, 11:40 PM   #6
12.73@111.36
Wrong forum but contact Stal, he's running 03/04 Cobra
Old January 18th, 2012, 02:04 AM   #7
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
Originally Posted by stal94gt View Post
i take it your buying a used kit. for a v2 s trim i would go with a 3.33 if non-intercooled and want to put out roughly 10-11#. if you want to keep it safe a 3.6 pulley will make around 7-8# non ic. as for hp you will make depends on how agressive your tune is. if you run the 3.6 pulley with lets say 14 degrees timing non intercooled you could see between 350-360. if you run the 3.33 pulley with 14 degrees timing you could see 360-370 hp. safe tune for me would be 13.4-13.6 af with 14 degrees timing and have the computer pull timing at intake temps over 100 degrees.
13.4AFR????
A 3.6 pulley and a power pipe would work great and get you to 10lbs probably. My V3Si makes 12lbs with a 3.6 pulley and a power pipe at 6200 RPM...
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old January 18th, 2012, 02:09 AM   #8
stal94gt's Avatar
2003 mustang v6 ;)
slow
Originally Posted by Nitmare67 View Post
13.4AFR????
he asked for safe, that is playing it real safe. hell my cobra is tuned at 11.5 af. with non ic cars especialy running alittle on the fat side is safe cause fuel acts as a cooling agent.
Old January 18th, 2012, 02:29 AM   #9
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
13.4? My car is dialed in at 11.75:1 from 3000-6500rpm. Typo?
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old January 18th, 2012, 02:35 AM   #10
stal94gt's Avatar
2003 mustang v6 ;)
slow
i was just saying on the super safe side. the guy asked a question about non ic setups and keeping it fat is safe for them. imagin intake temps over 200 degrees on a summer day. more fuel = cooler intake temps. sure you give up a few hp but it will prevent detonation.
Old January 18th, 2012, 02:39 AM   #11
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
I understand that but isnt 13.5 pretty lean? Or else I'm just confused?
Old January 18th, 2012, 02:40 AM   #12
stal94gt's Avatar
2003 mustang v6 ;)
slow
oh shit my bad, i ment 11.4, now i see what the fuss is about
edited my posts, i havent been sleeping the past month so my head is cloudy
Old January 18th, 2012, 02:53 AM   #13
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Ahh okay lol! I didnt know if I was wrong thats all.
Get some sleep man!
Old January 18th, 2012, 03:04 AM   #14
stal94gt's Avatar
2003 mustang v6 ;)
slow
i would sleep but im on a new work sched. im stuck working now and i dont get off till 7 am
Old January 18th, 2012, 03:12 AM   #15
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
That sucks. Getting used to a new schedule blows. I want to work overnights. I'm always up late. It's 330 and im supposed to be to work at 6 lol. Can't sleep early.
You'll get used to it sooner or later. Good luck man
Threads Similar to: Vortech questions
Vortech Questions blueAsmurf 99-04 18 February 18th, 2011 11:22 PM
vortech V-3 Si questions slater 2005 - 2010 36 January 10th, 2011 06:53 PM
Vortech V3 Questions luisdeli8 2005 - 2010 29 September 29th, 2010 07:45 AM
Vortech V2 questions UPRNewEdge 99-04 6 December 31st, 2009 06:32 PM
Vortech SC questions killermach1 2005 - 2010 2 December 29th, 2007 12:09 PM
