My build so far. What do u think she will run
Old January 17th, 2012, 04:14 PM   #1
dbmustanggt's Avatar
2004 mustang gt
dbmustanggt is on a distinguished road
Thumbs down
Hey guy n girl I though I would share my build of my 04 gt hear what u guys think about it. Just wondering what u think it will do in the 1/4 What I have as of know is
D1-sc with 3 core intercooler with mondo bypass Anderson power pipe
Hi tech stage 2 cams (won't run till motor build might sell too)
8 rib
Acfabe 75mm pl n tb
Bassina x pipe o/r Stinger cat back
Upr upper lower controll arms
31 moser axles true trac 3:55 gears Prefect launch diff cover
Bride racing seats
60 pound injector
Spec 2+ clutch n flywheel
Weld rts with 285 et street
Plains to get before April
Coilover (not sure on spring rate please helP out)
Upr k member
Tko 600
Slp line lock
D spec shock n sturt.
N the rest of the fuel system
What do u think?
04 mustang gt dropped on true forged rims with a little d1 408whp 390tq 10psi
Old January 17th, 2012, 04:17 PM   #2
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
I think it sounds like a pretty sweet setup. I think the only thing that hurts you will be your gears. You probably need at least a 3.73, I'd say 4.10's. All in all, it should get into the 12's
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old January 17th, 2012, 04:21 PM   #3
2004 mustang gt
Yeah I was plain on turbo but got one hell of a good deal on the d1 with a bunch of goodies I couldn't pass up I might switch them out not sure yet
Old January 17th, 2012, 05:14 PM   #4
2004 mustang gt
How ur build coming nick?
Old January 17th, 2012, 05:48 PM   #5
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Nice build. How much power? I think the 3.55s will be fun. Thing will pull hard in 4th.
You should have no problems getting into the 11s depending on how you launch
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old January 17th, 2012, 06:09 PM   #6
GreyWarrior07's Avatar
2001 Mustang GT
8.98 1/8
GreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura aboutGreyWarrior07 has a spectacular aura about
I would say you wouldnt have trouble getting in the 11s, depending on the power/ driver but i think after some runs you will be getting in the 11s
CHECK MEH GARAGE
BAMA Performance Drag Team #9
Old January 17th, 2012, 06:22 PM   #7
2003 mustang gt
bigboy05 is on a distinguished road
looks like the shortblock is the limiting factor at this point... id say you shud be able to get into the 11's
Kenne Bell powered
11.44@121.9
1.59 60 foot
Old January 17th, 2012, 08:40 PM   #8
2004 mustang gt
Still waiting to take it in to get dyno. I'm hoping 425 whp I just got to figure out the rest of my fuel system i only want to do it onces
Old January 17th, 2012, 08:49 PM   #9
2004 mustang gt
I'm hope to have the cash to built the motor by next fall
Old January 18th, 2012, 12:13 AM   #10
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
Cammed D1SC at 8psi should make that no problem. With the suspension and that power you should run high 11's easily.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old January 18th, 2012, 06:13 AM   #11
2004 mustang gt
Hope so. I might hold off on the cams n see what it makes on a 8psi pully n the power pipe O n love the color my stang dsg too
Old January 18th, 2012, 06:37 AM   #12
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
TRACTION IS EVERYTHING IN A RUN! this guy is running a 28 inch et drags on his Ttrim powered buit 2v
bone stock from the factory!
Old January 18th, 2012, 07:14 AM   #13
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
^yes.
IF you can hook up and keep it hooked up, 11's should be no problem. if you can drive really good and cut good 60's(ie 1.60 and lower) then mid 11's aren't out of the question. now with that being said, once you put in a built motor, 10's or bust. that d1 should have no problem clearing 550ish whp even with stock heads.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old January 18th, 2012, 02:34 PM   #14
2004 mustang gt
0-130 MPH in a supercharged Mustang, Part 2: new mods - YouTube
I hoPe I hook like that!
Threads Similar to: My build so far. What do u think she will run
build 2v or swap to 4v and build? Garagebuilt01 99-04 33 December 7th, 2011 11:38 PM
My 82 GT Build Lazor05 5.0 Mustangs 3 February 1st, 2010 04:30 PM
5.0 Build RIDIN5.0 5.0 Mustangs 22 March 22nd, 2009 05:17 PM
help me out with a build White Thunder 5.0 Mustangs 24 November 4th, 2007 11:31 AM
