'01 Gt Vert auto
13.2@103.8 n/a Stock stall
which way to go about my engine
well im gonna buy a shortblock soon
im wondering what you guys think i should do order one from mmr or just build one? i want to have fun n/a and spray a 125 shot keep the 2v so no go with a 4v stuff
![]() 253rwhp 294rwtq motor 337rwhp 427rwtq 90 shot |
12.9 @ 111.44
If you have the tools and the 'know how' then just build one yourself. BUT mmr does have some amazing motors for a great price and they come with a warranty, I will be purchasing a short block from them in the future.
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
'01 Gt Vert auto
i see deals on corral for shortblocks
but idk if im confident to buy them from over there i may end up buying one from mmr question is which one woulld fit my goals best
2003 Mustang GT
Id say look into the 5.1L stroker motor they have. Then slap a big shot of nitrous on it.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
2003 Mustang GT
Go with high compression, 11:1 atleast
#6 | |
2001 Mustang GT
34.82 @ 21
![]() ![]() iTrader: 4 reviews
Maybe it's the Boss block with the 4.75L stroker crank, slightly smaller than the 3.750" crank. That'd be a neat combination.
'01 GT - T56 6 Speed - Centerforce DFX - SCT LiveWire - Borla Stingers - Magnaflow Catted X - Steeda Tri Ax - Cobra Aluminum Driveshaft - 3.73s - Eibach Pro-Kit - MM Full Length Subframe Connectors - MM Caster Camber Plates Vortech V1 sold |
2003 Mustang GT
I thought they had a 5.1L motor? idk....
2001 Mustang GT
34.82 @ 21
Lol, I've been trying to figure out MMR for a while. For the most part their big bore 5.3 stroker is advertised as 324-325 cubes, when it's 322-323, and the stock bore/3.750" stroker is I believe advertised as a 5.0, even though it's slightly less than 4.9.
But I'd settle for that, at least I know it's actually 297"/4.87 liters.
'01 Gt Vert auto
11:1
dont you think that would be a a little to much shaun?
2003 Mustang GT
Hell nahhh. 11:1 compression would be ideal for a nitrous motor, and youd get everything you could out of it NA. I believe the guy that made like 395rwhp through his stroker motor (TFS heads, MHS cams etc....) was making 11.5:1 compression.
Idk what the max compression you can run for pump 93. Id say about 11.5-12:1 but not 100% sure. Compression alone will make good horsepower
Threads Similar to: which way to go about my engine
| 03 crown victoria engine vs. 2003 mustang gt engine?? Which tko 500? | 98 Stanga Banga | 99-04 | 8 | September 20th, 2010 08:25 PM |
| 2005 V6 engine swap to 2002 saleen engine | MCLARK | V6 Mustangs | 7 | May 14th, 2010 06:02 PM |
| 2005 V6 engine swap to 2002 saleen engine help? | MCLARK | 2005 - 2010 | 7 | January 11th, 2010 09:27 AM |
| Engine install: Life engine up, or drop engine? | trill gear head | 2005 - 2010 | 14 | October 26th, 2009 01:17 AM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 05:09 PM |
