April 2012 ROTM
what does everyone know about B heads?
found a set of B heads that I can get for pretty cheap...for a future build. I have read somewhere that the B heads are the best flowing of all the production 4v heads? Any off the top of your head info would be great!
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer |
2003 Mustang GT
I believe C heads are the best ones IIRC
Sent from my Autoguide iPhone app
![]() '03 GT w/BBK CAI, MAC Pro chamber, Borla Stingers, MGW Orange, SCT X3, and some make it sexy mods ![]() '89 GT 5.0 w/full bolt ons-SOLD '04 STi w/ A'pexi N1 catback and accessport-SOLD '00 Audi A6 2.7t stock - DD/Wifey's whip |
1999 GT
The 03/04 Cobra/Mach C Heads flow the best then come the 99-01 Cobra C heads. The B heads came from the 96-98 Cobra's. Not sure of the flow number, but I'm sure a simple google search would get you the answers.
From svtperformance: B heads: Intake: 230 cfm at .500" of lift Exhaust: 145 cfm at .500'' of lift C heads: Intake: 225 cfm at .500" of lift Exhaust: 145 cfm at .500’’ of lift. 03/04 heads: Intake: 233 cfm at .500" of lift Exhaust: 168 cfm at .500 of lift
![]() 35th LE 99 GT |
B heads can flow the best but dont make a difference until you get up to serious numbers I.E 700-800rwhp range. If not c heads make more lower end power when comparing 500hp to 500hp
88 LX automatic-non stroked 302 with iron heads 01 GT manual-h-pipe bullets dumped-125shot 97 GT automatic-SOLD |
April 2012 ROTM
it'l be an all out turbo build if I do it...by all out i mean the absolute limits of pump gas
B heads arent bad, but they arent the most desirable.
How they are generally viewed from least to most desired: B heads Early C heads Revised C heads/Navi heads GT500/GT super car heads 00 Cobra R heads
#7 | |
2001 Mustang GT
34.82 @ 21
![]() ![]() iTrader: 4 reviews
I just looked up the Cobra R head flow numbers, and wow. 35CFM over TFS 2V heads and 03-04 Cobra heads at .500. That would be nice.
86er, did Ford ever reproduce them? Or do you have to wait for someone to wreck a Cobra R?
'01 GT - T56 6 Speed - Centerforce DFX - SCT LiveWire - Borla Stingers - Magnaflow Catted X - Steeda Tri Ax - Cobra Aluminum Driveshaft - 3.73s - Eibach Pro-Kit - MM Full Length Subframe Connectors - MM Caster Camber Plates Vortech V1 sold |
They made some but most of the parts for that car you had to show ownership to even get. But its usually wait for a wrecked one or someone who had an extra this or that to go ahead and sell them
April 2012 ROTM
so youre saying the TF heads are just a shade behind the 04 4v heads stock for stock?
#11 | |
2001 Mustang GT
34.82 @ 21
It's one of the reasons why I'm going to stick with my 2V, although I may buy a Cobra one day.
#12 | |
2001 Mustang GT
34.82 @ 21
2001 Gt
I sent you a PM wishIhada5.0
#14 | |
Stock 4v>tfs. Port both and the 4vs run away in the comparison If you pay more than 200 for a set of B heads youve been had
2001 Mustang GT
34.82 @ 21
Yeah, I never bothered to research ported TFS heads Vs. a ported 4V head, I just assumed what the outcome would be, the 4V flowing more.
I saw a Teksid and bare B heads for sale by some girl on craigslist a while ago for only like $100, the block and bare heads. I should have went and checked out the block real carefully and bought it. Even if it were in bad shape, it's like 86 pounds of aluminum. Money right back.
April 2012 ROTM
I can land the heads for$ 170.....are they the best option though by comparison to the somewhat readily available c heads? Assuming both were worked over.....
C heads are just as easy to find. Hell just buy a complete engine and drop it in. Aviator engine and be done
2001 Mustang GT
8.98 1/8
a link i have saved talking about all 4 valve heads... here is part
B/Swirl Port: (93-97 Lincoln Mark VIII, pre 99 Lincoln Continental, 96-98 Cobra). The first and only production Ford head with two (square primary, round secondary) intake ports per cylinder, these swirl port castings arrived first in the ’93 Lincoln Mark VIII. Aptly named, due to the way they promoted the incoming air to swirl into the combustion chambers, much like water running down the drain of a once full sink. Through the years these heads have proven themselves to be excellent high rpm (8000rpm+) performers—mainly in power adder applications--since their tremendous combined intake port cross sectional area and volume (when combined, a full 55cc more than any other 4.6L head design) provide for exceptional power production in the upper regions of the tach. Ironically, it’s those same big, beautiful, twin ports that also prove to be the B head’s largest inherent design flaw. The extra intake port size has a tendency to kill low/mid rpm intake port velocity and power production—hence the use of Ford’s first IMRC (intake manifold runner control) intake on the 96-98 Cobra. By allowing air to reach only one of a B head’s twin intake valves, velocity, and therefore low/mid range torque production was restored in situations under 3250rpm. Later head designs are clearly superior in this regard, which happens to be the one of the most important considerations for those wanting a stout street motor. There is also some controversy over the single fuel injector/dual intake port setup. Some claim insufficient air/fuel mixing because of the compromised design, however, others contest that the ability to make 1000+rwhp with only minor porting and some form of power adder is testament to the contrary. Whoever you believe, there is little doubt that even after as little as 8,000 miles, carbon and other deposits tend to form on the secondary ports, causing a major airflow impedance, as there is no fuel present to clean them. B heads feature a somewhat small stock exhaust port that really hinders flow in power adder applications. Major gains from porting come with a quality valve job, some pocket and lots of exhaust work. There really isn’t a lot of material to remove from the intake ports themselves. The Bottom Line: B heads aren’t the best choice for a naturally aspirated street motor. In order to really shine, they need to be paired with a power adder and a short block that can sustain high horsepower and rpm levels. These, the oldest heads, may still be a great choice for full race applications. Stock Intake Choices: ‘93-‘97 Lincoln Mark VIII, ‘96-‘98 Cobra. Aftermarket/Modified Stock Intake Choices: HCI, SSR, PHP. B head dimensions: Combustion Chamber: 52cc, Intake Port Vol.: 107cc primary (square), 115cc secondary (round). Intake Port Entrance: 1.500x1.300” primary (square), 1.660x1.400” secondary (round), Valves: 37mm Int., 30mm Exh.
![]() CHECK MEH GARAGE BAMA Performance Drag Team #9 |
#19 | |
where did this link come from? all 4v's have the same exhaust port 48mmx25mm
#20 | |
2001 Mustang GT
8.98 1/8
But yes you are correct they are the same, this thing has floated around so many times im not sure if it was a mistake, or someone changing it, or not knowing 86er, it wouldnt let me rep you, but nice catch.. ill get you back sometime
Threads Similar to: what does everyone know about B heads?
| ProComp Aluminum heads vs. Windsor Sr. heads | novamastr | 5.0 Mustangs | 9 | March 14th, 2011 08:30 PM |
| Shorty heads vs long tube heads? | bioberg | 5.0 Mustangs | 52 | January 3rd, 2011 12:14 PM |
| Cam Question for New Livernois heads ( anyone running these heads? ) | aluv4speed | 99-04 | 12 | July 22nd, 2010 03:10 PM |
| sn95 cobra b heads vs 03 04 c heads | mystk96 | 4V / SVT | 30 | April 22nd, 2010 12:22 PM |
| replacing stock 302 heads with windsor 351 heads - questions | Tootheroots | 5.0 Mustangs | 5 | April 15th, 2010 10:51 AM |
