2003 Mustang GT
Which block to buy
Should I buy a Teksid block or a Ford Racing block for a build?
Sent from my SPH-D710 using AutoGuide.Com Free |
12.9 @ 111.44
what kind of build? I've heard tekskids can handle like 1,200 hp or something o.O I've seen a few sold locally for like 300$..
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
2003 Mustang GT
Just doing a rebuild to beef everything up. If it can hold that much I'm better off instead of buying one for over $1000.00
2003 Mustang GT
Buying a ford racing block for $1000.00 I mean.
You wont break a teksid, and Ill put a dollar to your dime you wont make the power to even begin to stress the stock block you have now
2001 Mustang GT
34.82 @ 21
![]() ![]() iTrader: 4 reviews
Yeah, them Romeos are tough. I want to pick up a Teksid for the weight savings mainly. Just a small bit of stuff you have to do to run 2V heads on a Teksid. Need to drill a coolant passage in the upper left (Passenger side cylinder bank) of the block, can use a head gasket to show you were. Then a 94-95 2V timing cover, and tensioner arms from an aluminum block 2V Explorer.
I need more money.
'01 GT - T56 6 Speed - Centerforce DFX - SCT LiveWire - Borla Stingers - Magnaflow Catted X - Steeda Tri Ax - Cobra Aluminum Driveshaft - 3.73s - Eibach Pro-Kit - MM Full Length Subframe Connectors - MM Caster Camber Plates Vortech V1 sold |
2003 Mustang GT
So I should just pick up another romeo block and stick with that?
2001 Mustang GT
34.82 @ 21
Wait a minute, what's wrong with your current block?
2003 Mustang GT
Nothing I'm just not going to take it apart and build from ground up so I still have something to drive
the weight is a plus, but if you are worried about strength theres nothing to worry about with your block
Threads Similar to: Which block to buy
| Mexican Block vs Stock 5.0 block | 96StAnG5.0 | 94-95 | 12 | May 19th, 2011 12:42 AM |
| short block's block vrs block in car stock? | adrenaline=lifeline | 99-04 | 7 | August 19th, 2008 08:22 AM |
| long block or short block? | jRoush | 5.0 Mustangs | 26 | January 26th, 2008 05:35 AM |
| short block differs from a long block how? | mustangfox9091 | 5.0 Mustangs | 35 | September 26th, 2007 10:57 PM |
| short block vs long block? | caintcatchmyGT | 96-98 | 3 | July 22nd, 2007 09:47 PM |
