2002 mustang gt
![]() iTrader: 1 reviews
wideband question!
My friend(screwed4vgt) bought an aem wideband and I was wondering if it replaces the 02 sensor or if we have to weld in another bund? First reply with answer gets re'd
Rock stock
New bung has to be welded in
2000 roush stage 2 novi 2000 @ 15 psi. forged shortblock. Svo Focus pump and bap |
I like boobs!!!
2000 GT convertible
dunno
This is true. The AEM, or any wideband for that matter used a 5 wire O2 sensor to track your true air/fuel ratio. You still need to have at least the front two O2 sensors to keep your ECM in check.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
2003 Mustang GT
Correct! And position it in the collector with the tip facing at an angle downward to prevent moisture build up
![]() Sent from my Autoguide iPhone app
![]() '03 GT w/BBK CAI, MAC Pro chamber, Borla Stingers, MGW Orange, SCT X3, and some make it sexy mods ![]() '89 GT 5.0 w/full bolt ons-SOLD '04 STi w/ A'pexi N1 catback and accessport-SOLD '00 Audi A6 2.7t stock - DD/Wifey's whip |
2003 Mustang GT
If your rear O2 sensors are shut off, you can use one of those bungs instead. Itll take an extra second to "heat" up vs being 2" away from the collector. But itll work fine at the rear O2 sensor bung.
I dont like putting the wideband infront of the Primary O2 sensors. That could get in the way of alittle air flow and throw off the O2 sensor's reading alittle. Also, if you get the bung welded on, you want it at a 3 oclock or 9 oclock position so it wont get wet.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
MM's king of Neon's
404 - car not found
17.81@87
If you have your rear HOS's turned off, you can put it in their places. If not, you will want a separate bung.
Sensor location is very important for an accurate read. You want it in an area in the flow with a very consistent homogenous flow path. This means stay away from bends and elbows. To promote longevity mount the sensor within +/- 45 deg of the vertical. Ensure that the female connector is oriented facing down to prevent moisture from collecting in it. You don't want the bung too deep or too shallow into the flow. The probe shoulder should sit about even with the pipe inner diameter. Last but not least is thermal protection. You want the sensor at least 2" away from hot components, and the wire 4" from them. External sensor parts should not exceed 220 deg F in operation. And it goes without saying you want no exhaust leaks, and you want to be as close to the upstream HOS as possible without interrupting flow to get the most accurate readings and quickest response. ...all of those are standard engineering requirements (IQA) for the installation of any Cummins engine. I know, I review this for every OEM. I'd say that is quite repworthy.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
12.9 @ 111.44
I have mine in place of a rear O2 sensor, works fine.
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
2003 GT
The AEM wideband comes with a new bung to weld in. Maxi muffler welded mine in for 45 bucks.. i went back into the shop to make sure the put it in the right place and at the right angle.
![]() 2003 DSG GT ... P1SC, MGW Shifter, NTO5 295 Rear Tire, H&R SS, MAC Long Tube Headers and Prochamber, Flow masters, 3.73 Gear, Blowe Cams, Tuned by Bob Kurgan My Build Thread |
2002 mustang gt
I rep'd all who answered! Thanks! How would you go about passing e check? Could he put a mil eliminator in one side and wideband in the other? I ask because I know you get the system rediness code when the rears are turned off
Rock stock
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
you wont be able to run a single mil with the rear o2 sensors on. you will have to turn the rears off compleatly or get a bung welded.
![]() bone stock from the factory! |
2002 mustang gt
Alright cool, it came with a bung so might as well use it, thanks
Rock stock
2003 Mustang GT
Hmmmm... Could you wire your driver rear o2 into your passenger rear o2 and keep the rear o2 turned on and run a wideband sensor in the driver rear bung?
2003 mustang v6 ;)
slow
that did not make sense, there are 4 total bungs with 4 sensors. he is adding a 4th, without eliminating the rear 2 out of the tune he wont be able to remove just 1 with out a check engine light. mil eliminators work by altering the frequency out put of the o2 sensor, the sensor still has to be pluged in and installed to function.
2002 mustang gt
Shaun is asking if you would be able to "splice" the drive side rear 02 sensor harness into the passenger side harness
Rock stock
2003 mustang v6 ;)
slow
you could possibly do that but you gotta be good with electical stuff. you gotta remember ohm's law for that and even still who knows. it may be just easier to weld the extra bung in that case
2003 Mustang GT
Yes sir! Lol sorry if I put it in a retarded way, but yes
2003 Mustang GT
Yeah true, good point. I was just thinking of a way to bypass one of the rear O2's but keeping them on for emissions. But like you said, at that point might just be easier getting the bung welded
2002 mustang gt
If we do it that way ill let you guys know how it turns out
Rock stock
Threads Similar to: wideband question!
| question for anyone running a wideband AFR setup | mrblueoval | 99-04 | 3 | March 19th, 2011 01:49 PM |
| Wideband question | 1999cobra92 | 99-04 | 36 | December 9th, 2010 11:09 PM |
| Wideband Question | Jimmyc206 | 99-04 | 3 | November 27th, 2010 07:10 AM |
| Wideband Install Question | Stanginsean | 99-04 | 4 | August 12th, 2010 09:50 PM |
| Wideband sensor install question | Uberlord | 2005 - 2010 | 9 | June 3rd, 2009 01:56 AM |
