![]() iTrader: 2 reviews
4.6L in car head/cam swap
I'm sure there is some information on doing a head/cam swap in car, but i can't seem to find any. If any one knows a of a good thread i'm interested. If not, i want to put some high flow heads on my 2v 4.6L and a new cam. Does anyone know if i can do this with the engine still in the car?
I found an article in the fed 2012 issue of muscle mustangs and fast fords, but the yonly explain the cam swap not the head swap. thought? |
April 2012 ROTM
i don't see why you couldn't do a head swap with bolts....studs may be another story...Tryin to clear the head over the studs would put you well in to the shock towers I would think? Unless you laid the dead down and then ran the studs through....that might work?
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer |
2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
There's a few threads on cam swaps in car. I can't recall what it was called but they used dowel rods and had a few tips in there.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
2003 MUSTANG GT
![]() ![]() ![]() ![]() iTrader: 10 reviews
You could probably loosen the motor mounts and tilt the engine a little bit to each side to do it one at a time if there is an issue with clearance.
![]() 4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton 4v MMR Stroker 1000 / Posi Race Ported Eaton Build How To: 2v to 4v COP Swap |
Threads Similar to: 4.6L in car head/cam swap
| PI head swap | devildog0311 | 96-98 | 3 | October 3rd, 2011 12:13 PM |
| Anyone who has done a 4v head swap | nileppezdel77! | 99-04 | 0 | February 26th, 2011 02:37 PM |
| p.i. head swap help | blkice067 | 96-98 | 13 | September 26th, 2010 10:24 PM |
| 4.6l head swap to 5.4l head. (questions) | 9-d-9 cobra | 4V / SVT | 72 | May 19th, 2010 11:59 AM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 12:57 AM |
