what will fix my pull to the left?
i have an 02 gt that has a nasty pull to the drivers side. i got an alignment about 4 months ago n it didnt help and. i recently lowered it with ford c springs which helped a little bit. took it back to the shop after i lowered it and they said i didnt need cc plates but the car has a nasty pull to the left any ideas what it could be or what could fix it? they said the alignment is in specs but it wont drive straight
!FACEPLATED!
did you rotate your tires and try it after they were rotated?
![]() MM Bracket Racing Crew Co-Founder ~Its a Drag Car, Not a Show Car~ LINK-->Custom Race Transmission Build<--LINK
#3 | |
2002 Mustang GT Conv
Sent from HTC Rezound on autoguide app
![]() 2002 Mustang GT "Lasered" Slow Auto 2 Valve Sequential Tail Light Kit, Eibach Pro-Kit, Borla Stinger Cat Back, 17' OEM Chrome Cobra Wheels
!FACEPLATED!
You dont not need CC plates because your lowered. It depends on how much its lowered. He said it was aligned after it was lowered and didnt need them. Anything up to a 1.5" drop does not need CC plates
yeah its not even 1.5 inch drop ford c springs drop it 1.25". could a wheel be warped or something? its been doing it quite a while but its just bothering the hell outta me lately.
!FACEPLATED!
Tires can cause a pull. i would rotate the tires and try it. If it still does it then go from there
2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
My moms crv kept pulling to one side. I thought it needed an alignment. I took it to a shop and the guy said hell bet it's the tire separating in the middle. He took it around the block said that's the issue. I bought her new tires on the front and solved the issue. Maybe your issue is just that simple.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
alright well ill be getting new rims n tires in a few months n then check the alignment again and go from there.
2006 Mustang GT
did you check and make sure none of your brakes were dragging?
Resident DJ
'01 Cobra Vert.
![]() Does the pull happen with your driving, or when you're braking? If it's pulling harder while you brake, then chances are a caliper is sticking.
2003 MUSTANG GT
12.5@113
My k member is misaligned so I pull to the right
2003 Mustang GT 398 hp, 365 tq 12.518@114.38mph Vortech V3, BA 2600, Magnaflow CatBack, Pro 5.0 shifter, SCT Livewire, BBK Catted X, M/T ET Streets 315/35/17, 160* Stat, FRPP 4.10, CXRacing IC, Vortech MaxFlow Race Valve, 3.33 Pulley, BBK 78MM TB |
2001 Mustang GT Vert.
+1 rotate tires to see if it's still pulling
is there excessive toe play in the steering?=bad inner/outer tie rod(s). How many miles are on the car? (I'm thinking ball joints)
Mods in garage |
04 mustang gt
7.21 @ 98
just because the alignment is in spec doesn't mean that the toe isn't adjusted to the right or left in both directions. i'm just sayin that if the toe is adjusted as far right or left as possible on both sides (yet still in spec) its gonna pull. do you have a sheet of the specs?
![]() cams + 150 shot |
Threads Similar to: what will fix my pull to the left?
| pull out pull out.... | psycho bob | 2005 - 2010 | 38 | April 7th, 2009 12:31 PM |
| starting to pull left | 91cobra5.0 | 5.0 Mustangs | 11 | December 1st, 2008 10:33 AM |
| why cant this cop pull me over? | graystang01 | The Clubhouse | 9 | May 16th, 2008 01:04 AM |
| Best Way To Pull Out The 4.6 | mbmconstruction00 | 99-04 | 14 | March 13th, 2008 05:01 PM |
| Where is it best to pull the 3.8 out from? | 2000Silverbullet | V6 Mustangs | 9 | May 25th, 2007 07:32 PM |
