Automatic Revy
Old January 18th, 2012, 01:09 AM   #1
Wh1t3F1sh's Avatar
2001 Mustang GT
13.65 @ 102.88
Wh1t3F1sh is on a distinguished road
Question
Automatic Revy
This is for the auto guys primarily, but if you have some input please feel free. From a dig, my car has a serious issue of always banging revy going into 2nd. It seems to have gotten worse since I've had the car, or maybe I just now notice it. But when I install my tune (basically a canned sct) it practically never hits revy. I almost constantly DD with the tune loaded up until recently. I had a feeling I was banging my trans too hard with the tune and a friend keeps telling me that my trans is starting to go. So I took the tune off and now im banging the limiter just about every day. Is this normal for autos? Or is my trans just taking a shit?
Amazon Green GT
Everyone loves bolt-ons
Old January 18th, 2012, 01:12 AM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
i am not a pro on auto, but i know i probably wouldnt notice the problem cause i would be driving the trans am instead
bone stock from the factory!
Old January 18th, 2012, 01:21 AM   #3
Wh1t3F1sh's Avatar
2001 Mustang GT
13.65 @ 102.88
lol yeah given the chance id take the TA as well
Amazon Green GT
Old January 18th, 2012, 03:00 AM   #4
86er's Avatar
whats the fluid look like, miles on the car
Just a truck
Old January 18th, 2012, 07:08 AM   #5
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
need a little more description, i'm assuming this is only when your wot that your hitting the limiter? do you have aftermarket gears in it? a stock tune with different gears could cause the shift points to be way off. also i would just put the tune back on, unless everything on the tuner is maxed out there's no reason why it should be hurting your car.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old January 18th, 2012, 08:56 AM   #6
'03 GT
15@98mph :(
Macattac is on a distinguished road
Saw your ET....you're one second faster than me at the same speed....MAN I need to practice my 60-foot
Magnaflow Catback | Steeda UDP | UPR CAI | AccuFab 75mm TB+Plenum| 14" rotors with 8 piston calipers | BMR LCA&UCA | Eibach Sportline Springs
Old January 18th, 2012, 09:24 AM   #7
MM sticker peddler
Shelbydog!'s Avatar
slowmatic
Shelbydog! is just really niceShelbydog! is just really niceShelbydog! is just really niceShelbydog! is just really niceShelbydog! is just really nice
Make sure your tune compensates for your rear end gears. I'm using a canned tune as well but have never hit the rev limiter. The only prob I have is at wot when the car shifts, sometimes the belt squeals from the sudden drop in rpm.
Visit this thread, more stickers possible coming soon! http://www.moddedmustangs.com/forums/clubhouse/263411-gauging-interest-more-new-mm-sticker.html
Old January 18th, 2012, 10:09 AM   #8
2001 Mustang GT Vert.
cbjohnson9 will become famous soon enoughcbjohnson9 will become famous soon enough
Have you made any internal modification to the tranny?
I'm wondering if the rev limiter is set at a lower RPM than what the shift point RPM is. This would be very bad, but could cause you to hit the limiter before the computer tells the trans to shift.
If they are very close together (shift RPM/limiter RPM), you might try lowering the RPM shift point a little bit so the car doesn't rev into the limiter. Or, if you shift points are perfect, try raising the limiter a couple hundred RPM. This would allow the trans to shift properly without bouncing off the limiter.
A lower gear would exacerbate this problem.
Mods in garage
Old January 18th, 2012, 12:13 PM   #9
Wh1t3F1sh's Avatar
2001 Mustang GT
13.65 @ 102.88
Fluid is good, completely full. I just rolled over 69k
Amazon Green GT
Old January 18th, 2012, 12:15 PM   #10
Wh1t3F1sh's Avatar
2001 Mustang GT
13.65 @ 102.88
Correct, only at WOT. Stock 3.27s. And im thinking I will just put the tune back on because I never hit revy while tuned. It only happens when I'm running stock tune.
Amazon Green GT
Old January 18th, 2012, 12:16 PM   #11
Wh1t3F1sh's Avatar
2001 Mustang GT
13.65 @ 102.88
Haha let's get it down boss! I'm looking at 13.8-13.9 this spring season. I added a few more toys to the pony
Amazon Green GT
Old January 18th, 2012, 12:18 PM   #12
Wh1t3F1sh's Avatar
2001 Mustang GT
13.65 @ 102.88
My tune is set up for the stock rear so I don't think that's my problem. Again it only happens when I'm running the stock tune; as soon as I load the canned tune it never happens.
Amazon Green GT
Old January 18th, 2012, 12:20 PM   #13
Wh1t3F1sh's Avatar
2001 Mustang GT
13.65 @ 102.88
Tranny is completely stock. I think you're right, maybe I just need to raise the limiter.
Amazon Green GT
Threads Similar to: Automatic Revy
3.73 vs 4.10 automatic fluffy 2005 - 2010 48 April 13th, 2010 11:48 PM
03 Automatic willsurforbeer9 V6 Mustangs 63 May 8th, 2008 12:14 AM
Those w a automatic adrenaline=lifeline 99-04 7 May 7th, 2008 11:40 PM
Anyone here an automatic? Mustang Mike 99-04 0 March 20th, 2007 07:15 AM
automatic rchauvin General Tech 14 February 19th, 2007 12:04 AM
