302 block help
Old January 18th, 2012, 03:20 PM   #1
2003 Mustang GT
Bischoff is on a distinguished road
302 block help
Will a 302 block work with 4.6 items such as heads timing cover etc.
Sent from my SPH-D710 using AutoGuide.Com Free
Old January 18th, 2012, 03:23 PM   #2
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
Are you talking about a pushrod 302?
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old January 18th, 2012, 03:30 PM   #3
2003 Mustang GT
No an ford racing 302 block
Old January 18th, 2012, 03:34 PM   #4
I like boobs!!!
2000 GT convertible
dunno
Oh, that's a larger bore I believe, but I'm pretty sure everything will bolt up to it. The problem is you will never be able to see the full potential of it unless you go 4V because of the restriction you have from small intake and exhaust valves on the 2V. It's very similar to the old Chevy 305. They had the worst rap for being dog engines, and for the most part they were. That's because they had to have small valves due to the narrower bore. You could run a 305 head on a 350 (but why would you want to), but you can't run a 350 head on a 305 because the valves would hit the cylinder wall.
Old January 18th, 2012, 03:38 PM   #5
2003 Mustang GT
Ok I'm trying to build a 347 stroker.could it be done on my block or no?
Old January 18th, 2012, 03:41 PM   #6
I like boobs!!!
2000 GT convertible
dunno
The 347 is a 302 with a 351 crank and again, that is a pushrod engine. I don't know what the combinations are with the mod motors, but I'm pretty sure you're not going to get a 347 out of a mod. And as I said before, once you start going with the larger displacements, you need to move to a 4V head or the engine will be starving for air.
Old January 18th, 2012, 03:45 PM   #7
I like boobs!!!
2000 GT convertible
dunno
With the BOSS 302 block and the 5.0 stroker crank you will be at 5.3 liters, which is approximately 323 cubic inches.
Old January 18th, 2012, 03:49 PM   #8
2003 Mustang GT
Ok thanks for the help
Threads Similar to: 302 block help
Mexican Block vs Stock 5.0 block 96StAnG5.0 94-95 12 May 19th, 2011 12:42 AM
short block's block vrs block in car stock? adrenaline=lifeline 99-04 7 August 19th, 2008 08:22 AM
short block differs from a long block how? mustangfox9091 5.0 Mustangs 35 September 26th, 2007 10:57 PM
short block vs long block? caintcatchmyGT 96-98 3 July 22nd, 2007 09:47 PM
Stock Cobra Block and GT Block the same?? bbrewer03 96-98 2 August 26th, 2006 01:31 PM
