AEM Releases the Dyno-Shaft On-Vehicle Dynamometer System - Part 2
Old January 19th, 2012, 02:36 PM   #1
AEM
Performance Electronics
AEM's Avatar
AEM is on a distinguished road
Click for More info
Eliminate Guesswork - Know for sure if slower times are due to a loss of power, vehicle set up or driver error.
Engine tuning - Stop trying to approximate real world test conditions and start testing in the real world! Finally you can test with actual intake air conditions, actual vehicle loading and the hundred other things that make a real vehicle behave very different than it does when on a dyno.
Chassis Set Up - Know when the tires will break loose. Ideal for optimizing drag launches and determining the longitudinal forces your tires can handle in road racing.
Torque Converter and Clutch development - Finally know what your Torque converter or clutch is doing while you are making a pass!
Dyno It All - The Dyno-Shaft accurately reads in all conditions including steady state, uphill or downhill, even while coasting down!
AEM DYNO-SHAFT SPORTSMAN FEATURES:
• Measures Torque and RPM at the driveline to deliver real Horsepower and Torque numbers
• Does not skew readings like accelerometer-based units
• Eliminates guesswork when troubleshooting or making changes at the track
• Laboratory-grade strain gauge requires no slip rings or batteries and is maintenance free
• Create dyno charts which can be saved, printed, or shared electronically (requires AQ-1 Data Logger)
• Sportsman slip yoke is manufactured from ductile cast iron
• Sportsman slip yoke splines are manufactured from a broaching process that produces industry-leading mating fit parts
• Sportsman slip yoke is temperature compensated and individually calibrated for load through a multi-point process
• Can be used with the AEM AQ-1 data logger, AEM Series 2 EMS, and some third party CAN-enabled engine management systems, data loggers and displays (contact AEM Technical Support or Sales Dept at (310) 484-2322 or contact your direct vendor to confirm whether your CAN-enabled device can read the Dyno-Shaft datastream)
Old January 19th, 2012, 03:06 PM   #2
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
Give us a link to more info and pricing.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old January 19th, 2012, 03:18 PM   #3
Get out of my way.
SL1MDADDY's Avatar
2001 Mustang GT
SL1MDADDY will become famous soon enough
And at a price of 1160. This would be great for the true sportsman of a team or armature racers looking to save a buck on dyno readings. Kind of cool.
Procharged 2001 Mustang GT
Old January 19th, 2012, 03:24 PM   #4
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
Yup, at $1160 I'll pass and keep using my 15+ year old G-Tech Pro...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old January 19th, 2012, 04:12 PM   #5
Baker Jr.
bandity2k00's Avatar
Coming after build!!
bandity2k00 is a jewel in the roughbandity2k00 is a jewel in the roughbandity2k00 is a jewel in the rough
Send a message via AIM to bandity2k00
Ill go 500
MMR-Modular Mustang Racing
Phils Machining-For your ABS Module Delete Manifold!
American Muscle-www.Americanmuscle.com
HorsePower By Hermonn-TUNER
THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
Old January 19th, 2012, 04:13 PM   #6
I like boobs!!!
2000 GT convertible
dunno
I'll go $501 Bob
Old January 19th, 2012, 04:14 PM   #7
jkolbfleisch's Avatar
2001 Mustang GT
jkolbfleisch will become famous soon enough
I read an article in some magazine a few years back about this idea that some kid thought up and patented. I wonder if this is the end product of that?
Looks pretty damn cool!
2001 Mustang GT [518 WHP, 502 WTQ][P1SC + 10psi][MMR900][Trick Flow Heads/Intake][Stage 3 Blower Cams][JBA Headers, Magnaflow Tru-X, Flowmasters][11.89@119mph]
Old January 19th, 2012, 06:46 PM   #8
2003 Mach 1
glittle75 has a spectacular aura aboutglittle75 has a spectacular aura aboutglittle75 has a spectacular aura about
there a video or some thing of this thing working? Why would the average guy need this? or is it more aimed at race teams? Do i need to get a different driveshaft? How much power can this thing handle before it breaks?
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons.
497hp, 460tq.
Old January 19th, 2012, 07:33 PM   #9
Jackpot, fishypoopypants!
2003 GT
1@3,000,000.... or is it 3,000,000@1?
Cathedral has a spectacular aura aboutCathedral has a spectacular aura about
I would imagine it would be targeted to teams or hardcore enthusiasts. After all, it's just a data logger. You still need the capability to change/modify things based on that data. Which is why most people would just go to a dyno shop once or twice and get it dialed in.
But it definitely is a sweet idea.
yoink!
Slipped Moebius
mhm28x9
alt.alien.vampire.flonk.flonk.flonk
Old January 19th, 2012, 07:43 PM   #10
cliffyk's Avatar
I see it as a replacement for going "to a dyno shop", and would really like to have one--except for that $1200 part.
If you had one of these, or even one of the accelerometer based tools they decry (like my old G-Tech Pro), there is no need to go up on the rollers unless you want to get a baseline or updated numbers. A dynamometer is just another tool to measure power--it has nothing to do with changing or modifying a tune...
-cliff knight-
My Mustang
Old January 19th, 2012, 07:54 PM   #11
2003 GT
You're right, I didn't mean to imply that the dyno itself did anything other than read numbers. My point was that most people go to a dyno shop to have the car tuned, because the people there know how to go about that and have the technology to do so. Most people would have no clue how to program an ECM themselves and having this thing recording all the data would do them no good aside from just looking at the numbers. Now, a hardcore enthusiast would love to dig into it for sure.
yoink!
Slipped Moebius
mhm28x9
Old January 24th, 2012, 01:11 PM   #12
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
So can you hook this up to a guage and it'll show you your power your making all the time? Like instead of showing you your boost it shows you your power?
Rock stock
Old January 24th, 2012, 01:45 PM   #13
cliffyk's Avatar
Yup, it goes inline with the driveshaft, and measures transmitted torque and shaft RPM, then calculates HP. Apparently it has a CAN bus output...
-cliff knight-
My Mustang
Old January 24th, 2012, 11:50 PM   #14
JerseyTrueBlue's Avatar
2001 Mustang GT
JerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura aboutJerseyTrueBlue has a spectacular aura about
The ad for this is all over this website after every other god damn post do we really need a sticky advertising it too?
True Blue Crew Member #2
315's Crew Member (Dat azz)
255/298
Founder of the please leave my signature alone, I want it to say what I put there and don't appreciate you deleting it club
Old February 6th, 2012, 12:19 AM   #15
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
Meh
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old March 25th, 2012, 09:31 PM   #16
1966 Mustang 289
Zephyr66 is on a distinguished road
guess so...
Threads Similar to: AEM Releases the Dyno-Shaft On-Vehicle Dynamometer System - Part 2
AEM Releases the Dyno-Shaft On-Vehicle Dynamometer System AEM Modular Mustangs 0 December 9th, 2011 12:02 PM
04N20Gt's dyno session part 2 04N20GT 99-04 81 March 18th, 2011 11:59 PM
aluminum drive shaft for better dyno results? american_muscle 99-04 24 February 25th, 2010 04:39 PM
05 MUSTANG GT:SALEEN SC:DYNO:PART II SMP 2005 - 2010 3 January 15th, 2006 01:57 PM
