Got engine fixed - not quite the same
Old January 20th, 2012, 08:00 AM   #1
Mike Hadz's Avatar
2000 Gt
Mike Hadz is on a distinguished road
okay so long story short i blew a piston and had it replaced and the cylinder re-honed, picked it up today and its not quite right, when i first picked it up it felt great, anyways with further driving started to notice the transmission (what i feel is the trans) feels like it bounces around when i hit bumps/dips w/e, the more noticeable issue is that the tranny makes a ticking sound, kind of like the sound when you are being pulled up a roller coaster on the chain, tinktinktink when i drive, feels quite terrible for the car and just not good. Third problem being when i start the car sounds slow-motion almost, not a strong start-up, whats up with all this? anyone else have experience with these issues?
Thanks a ton ^^
2000 Gt - full bolt on's 3.73's eibach suspension. 265hp/307tq
Old January 20th, 2012, 08:38 AM   #2
2003 Mach 1
glittle75 has a spectacular aura aboutglittle75 has a spectacular aura aboutglittle75 has a spectacular aura about
reputable shop? check all fluids and such when you got it back? For the first 2 issues i would get under it and look at your engine/trans mounts they may be worn or installed incorrectly. For the start-up issue, maybe try the starter first.
2003 Azure Blue Mach 1 - KB, Suspension, Bolt-ons.
497hp, 460tq.
Old January 20th, 2012, 08:44 AM   #3
Mike Hadz's Avatar
2000 Gt
my uncle did it in his garage he's a good mechanic, been doing over 40 years.
Old January 20th, 2012, 09:56 AM   #4
overnightmillionaire's Avatar
Mustang GT 2004
overnightmillionaire will become famous soon enoughovernightmillionaire will become famous soon enough
Send a message via AIM to overnightmillionaire
Then why don't you ask your uncle since he did it? lol
Just a thought.
2004 Mustang GT 384 rwhp - Vortech V2 supercharger, methanol injection, Short Throw Shifter, 3.73 Gears, Flowmaster American Thunder Catback, BBK H-Pipe and Long Tube headers
Old January 20th, 2012, 10:49 AM   #5
justAbullitt's Avatar
2001 Bullitt
justAbullitt will become famous soon enough
take it back, slow crank could just be a battery if it does it cold. Or It could also be a timing issue..... Are you positive the ticking noise is from the trans and not the engine??
Bullitt #4592
Mods list in my garage
Google+
Old January 20th, 2012, 11:02 AM   #6
Tits Magee
STANG34's Avatar
4V Swap GT
STANG34 is on a distinguished road
The problem is you didn't attach a kenne bell ..but on a serious note. if your able to jack the car up. get underneath her and see if you can get to your bell housing. Make sure all the bolts are on and snug. To often bell housing bolts get lost or not tightened down all the way because of some of the angles. Especially if the motor came out and in seperate from the transmission. Just a thought.
Needing some COP covers for 4V Cobra
Did you know if you sound out gullible slowly it rhymes with orange?
Old January 20th, 2012, 04:50 PM   #7
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
^or, if they came out together, check the trans mount...you have to drop that down to be able to get the motor/trans out together.
was everything put back together using all OEM parts???
when i swapped the 4v in my GT, i noticed it cranks a wee bit slower but i think thats mostly due to the bump in compression i got from the swap.
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old January 21st, 2012, 07:25 AM   #8
Mike Hadz's Avatar
2000 Gt
i feel pretty positive its the trans, kinda sounds like its coming from right underneath shifter, also sounds like its coming from underneath the car, what could cause the timing problem to happen, possible my sct tune is bad? THanks
Old January 22nd, 2012, 02:02 AM   #9
Mustang_GTX's Avatar
13.515@102
Mustang_GTX is on a distinguished road
Send a message via AIM to Mustang_GTX
u check the connection from your manifolds(or headers) to your midpipe?
Mustang Mike
Old January 22nd, 2012, 03:12 PM   #10
Mike Hadz's Avatar
2000 Gt
Will look into it, didn't notice any leaking or anything you think that could cause a ticking? seems like it's in the possible location of the sound.
Edit: i'm not even sure if the manifolds were disconnected from the midpipe, only from the block.
Old January 23rd, 2012, 02:55 AM   #11
13.515@102
that wouldnt make much sense if you pulled the motor... manifolds are a bitch to take off with the motor in the car... much easier to pull the motor with them in and much more sensible.. therefore i believe it was taken off at the mid-pipe.. and yes you would def hear a ticking at low idle, and as idle went up you would hear it go faster and it would probably "go away" at high idle if you have a loud exhaust... which is like anything but stock on our cars... so yeah id def check that for a tick.
Mustang Mike
Old January 23rd, 2012, 03:44 AM   #12
Mike Hadz's Avatar
2000 Gt
thank you
Old January 23rd, 2012, 04:37 AM   #13
13.515@102
np
Mustang Mike
Old January 23rd, 2012, 02:04 PM   #14
Run ur car, not ur mouth.
SON1C's Avatar
2003 Sonic Blue 4.6L
SON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of lightSON1C is a glorious beacon of light
exhaust leak
238rwhp/263rwtq
Drew's Build Thread
Threads Similar to: Got engine fixed - not quite the same
can this be fixed? stang0246l 99-04 9 May 8th, 2011 09:22 AM
Can this be fixed? Muscletang Visual 6 January 13th, 2010 07:32 AM
I would like to see my DD fixed up.. FX4DTUF Chopshop 15 September 16th, 2009 10:24 PM
There, i fixed it 2006GTARPD3 The Clubhouse 7 August 4th, 2009 02:42 PM
ok can this be fixed? LXstang5.0 Visual 1 November 10th, 2007 04:20 PM
