Bad starter?! Car died while moving and wont start? - Forums at Modded Mustangs
post #1 of 33 Old January 21st, 2012, 06:26 PM Thread Starter
Wheelin' and dealin!
blakenel1122's Avatar
I was driving like 50 mph in 4th gear and I put in the clutch for a red light and it just cut off. I tried starting it back up and it just would crank real slow and not fast enough to turn over. then i tried a few more times and it just acts like its jammed? it like clunks and it doesnt even turn over. I was told by a few people that my starter went bad but I just wanted some more input on it. maybe this happened to you? All input is appreciated!! Oh and my oil pressure gauge wasnt reading at all, and i had the perfect amout of oil. I think its just a bad sensor from the new motor swap. And the thing is i just had a new motor put in last night and this just happened this morning?
THANKS!
1997 Mustang GT-SOLD
2002 Mustang GT-SOLD
2004 Mustang GT 40th Anniversary - SOLD
1993 4 CYL FOX-SOLD
2002 Turbo'd Vert-SOLD
2000 GT-SOLD
2001 GT/COBRA- DD
blakenel1122 is offline
post #2 of 33 Old January 21st, 2012, 06:31 PM
stal94gt's Avatar
bad battery
bone stock from the factory!
stal94gt is offline
post #3 of 33 Old January 21st, 2012, 06:34 PM
dhicks7806's Avatar
I would say dead battery for the cranking real slow then not at all...and as far as dying after drivin for a while, perhaps the charging wire from the alternator was not hooked back up properly after the motor swap?
Sent from my Autoguide iPhone app
'03 GT w/BBK CAI, MAC Pro chamber, Borla Stingers, MGW Orange, SCT X3, and some make it sexy mods
'89 GT 5.0 w/full bolt ons-SOLD
'04 STi w/ A'pexi N1 catback and accessport-SOLD
'00 Audi A6 2.7t stock - SOLD
'00 Ranger 4x4 - DD
dhicks7806 is offline
post #4 of 33 Old January 21st, 2012, 07:11 PM
Y2KGT's Avatar
I agree with DHicks....If you were driving and the car shut off and now wont crank, than for sure you have a charging issue. The alternator charges the battery when the car is running so when all the electronics are on it does not drain the battery. So if you lost power when driving and now it won't crank i would look at the charging system, not so much the battery. Im not saying it isnt the battery, i just think you have a wire misplaced or bad cable or bad connection. Good luck.....
Y2KGT is offline
post #5 of 33 Old January 21st, 2012, 07:19 PM Thread Starter
Sorry guys, I forgot to mention that the battery still has full power, my air works and my windows work and everything, but its just that when i go to start it just clunks and doesnt turn over. its not excessive clicking, just one clunk... and he said he had the battery ground is tight on the motor mount and its all good. Im 90% sure its not my battery.
But my question is would the starter cause my car to just shut off while driving??
1993 4 CYL FOX-SOLD
2000 GT-SOLD
2001 GT/COBRA- DD
post #6 of 33 Old January 21st, 2012, 07:25 PM
dhicks7806's Avatar
No it wouldn't...and if you're battery has full power and it's making one clunk, my wife's cavalier did that when the timing chain broke and got lodged. I'm not sayin that's your problem but it's possible someone didn't tighten something and it worked free and is now causing a bind. Check your starter out but I'm gonna lean towards a mechanical bind if it doesn't spin at all
'00 Ranger 4x4 - DD
post #7 of 33 Old January 21st, 2012, 07:35 PM Thread Starter
When the motor was swapped, we didnt pull the timing cover off or touch it, the motor had 40 k on it and there shouldnt be a mechanical malfunction. I didnt hear any crunching or anything like that but i wont know till i swap my starter out tomorrow, but i hope thats all it is, this car is nothing but trouble
1993 4 CYL FOX-SOLD
2000 GT-SOLD
2001 GT/COBRA- DD
post #8 of 33 Old January 21st, 2012, 07:37 PM
dhicks7806's Avatar
Ok I hope the starter is just locked up or something but that doesn't really explain your at dying, so I guess you'll know more once you swap the starter.
'00 Ranger 4x4 - DD
post #9 of 33 Old January 21st, 2012, 07:51 PM Thread Starter
Im keepin my fingers crossed. My first engine blew up 6 months ago and it dropped a valve and i know when that happened, it made a horrible noise, and i didnt hear anything, like i didnt know my car shut off untill i looked at the tach.
1993 4 CYL FOX-SOLD
2000 GT-SOLD
2001 GT/COBRA- DD
post #10 of 33 Old January 21st, 2012, 08:08 PM
Y2KGT's Avatar
Have you tried turning the engine over by hand? That will tell you if you have a major issue or not.
Y2KGT is offline
post #11 of 33 Old January 21st, 2012, 08:13 PM Thread Starter
no i have not, how would i go about doing that? with some kind of torque bar or something?
1993 4 CYL FOX-SOLD
2000 GT-SOLD
2001 GT/COBRA- DD
post #12 of 33 Old January 21st, 2012, 08:16 PM
dhicks7806's Avatar
Put a socket on the crank pulley and see if you can turn it over a couple times- sorry I didn't mention trying this...it slipped my mind
'00 Ranger 4x4 - DD
post #13 of 33 Old January 21st, 2012, 08:43 PM Thread Starter
wow alright, Ill see if i can do that tomorrow cause its raining and cold as balls here
1993 4 CYL FOX-SOLD
2000 GT-SOLD
2001 GT/COBRA- DD
post #14 of 33 Old January 21st, 2012, 08:48 PM
reeking havoc
281SLEEPER2v's Avatar
What you describe happened to me exactly except i was accelerating. long story short motor seized up on a 4th gear pull on the highway.
hope your situation is diffrent but mine did the exact same thing, turn key and just a !!!!!CLUNK!!!! and nothing. i also thought it was just my starter had seized or something but i was wrong. my engine was gone.
VALLEY STANG
2v+Cams+Nitrous
stock longblock till she blows
281SLEEPER2v is offline
post #15 of 33 Old January 21st, 2012, 08:49 PM
Shaun13GT/CS's Avatar
iTrader: 27 reviews
Could have blown a fuse. Check all the fuses under the hood.
When I had the N2MB WOT box that happened to me. I went to push in the clutch and the car just shut off. Tried starting it, it wouldnt and the theft light would be blinking. Found out (I forget which one) But I blew a fuse because the wire going through the firewall chaffed a tiny bit and a wire shorted out.
Just some food for thought
14 Mustang GT M6 - TVS, Kooks Full Exhaust, AED Tune
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
09 Corvette Z06 - 11.7 @ 123.5 (stock)
13 Mustang GT Bolt Ons - 11.58 @ 122.13
03 Mustang GT Vortech - 11.98 @ 118.68
Shaun13GT/CS is online now
post #16 of 33 Old January 21st, 2012, 08:55 PM
iTrader: 13 reviews
alternator? similar thing happened to my buddys six and that was the culprit
SON1C is offline
post #17 of 33 Old January 21st, 2012, 08:56 PM
iTrader: 27 reviews
Could be a PATS issue too. When you try to start it, is the theft light blinking really fast?
11.04 @ 130.1
621/557 @ 8.6psi
Previous Cars
post #18 of 33 Old January 21st, 2012, 08:57 PM Thread Starter
I hope its not what 281sleeper says it is... and when you say locked up? what exactly happend? like broken cam chain or broken piston?
And no lights are on which worries me..ughh this sucks i didnt even get to drive it one full day and im in high school and the last time i drove it was about 6 months ago
1993 4 CYL FOX-SOLD
2000 GT-SOLD
2001 GT/COBRA- DD
post #19 of 33 Old January 21st, 2012, 08:58 PM Thread Starter
nope,no lights are on at all
1993 4 CYL FOX-SOLD
2000 GT-SOLD
2001 GT/COBRA- DD
post #20 of 33 Old January 21st, 2012, 09:13 PM
reeking havoc
okay this happened to me twice. first was timing chain guide broke pats system came on and wouldn't let me start the car, and the theft light was blinking. because the broken pieces ended up in the oil pan, once i did start the car it read no oil pressure on the gauge. replaced timing chain guides and put it back together.
a year later my engine blew while i was on the highway i noticed the oil gauge went all the way down and car just turned off, no violent boom or clunk, just pulled over to the side and never started again. had that same clunk when i tried to start
never really found out what happen but i did find lots of metal shavings in the oil pan, couldve have spun a bearing and threw the motor out of balance and seized up.
try turning the engine by hand thru the crank pulley bolt. mine did not spin for shit so i knew it was done.
VALLEY STANG
2v+Cams+Nitrous
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/246885-bad-starter-car-died-while-moving-wont-start.html
Driving Pasted A Car Engine Died And Just Clunks When I Try And Start It? | Ask Help Box This thread Refback July 25th, 2014 02:50 AM
