Fuel pump not working
Old January 22nd, 2012, 10:17 AM   #1
Big Rob's Avatar
02 Mustang GT
Big Rob is on a distinguished road
Ok,
Car died out on me on Thursday, had a mechanic look at it. Told me it was the fuel pump. I bought a new pump at Advanced Auto Parts, dropped the tank swapped it out, but nothing. I went back in the tank and I couldn't here it turning on when i turned over the ignition.
Checked the fuse in the engine bay, it was good. Got a pen light volt tester thing and it apparently the tank was getting power, I don't know how much voltage but there was something. I took the pump back out and connected it directly to the car's battery and it worked. No clue as to what to do next. Help plz
Old January 22nd, 2012, 10:21 AM   #2
Big Rob's Avatar
02 Mustang GT
Would the Constant Control Relay Module have anything to do with this? I had my AC stop working a little while ago and I think it was due to it blowing a fuse there. And throughout December my car did hesitate here and there to start so maybe it was an ongoing thing
Old January 22nd, 2012, 10:46 AM   #3
dhicks7806's Avatar
2003 Mustang GT
dhicks7806 will become famous soon enough
Did you check the inertia shut off switch in the trunk? It's a little black box by the drivers tail light with a red button in it looking down from the top...button should be pressed down- then I would say to check the fpdm- mine had a hot ground and was doublin the voltage to the pump- I had 90psi base fuel pressure!
Sent from my Autoguide iPhone app
'03 GT w/BBK CAI, MAC Pro chamber, Borla Stingers, MGW Orange, SCT X3, and some make it sexy mods
'89 GT 5.0 w/full bolt ons-SOLD
'04 STi w/ A'pexi N1 catback and accessport-SOLD
'00 Audi A6 2.7t stock - DD/Wifey's whip
Old January 22nd, 2012, 10:56 AM   #4
Big Rob's Avatar
02 Mustang GT
Yeah I checked the Inertia switch. What's the FPDM, where is it located?
Old January 22nd, 2012, 12:06 PM   #5
dhicks7806's Avatar
2003 Mustang GT
Fuel Pump Driver Module - Basically it supplies and controls power to your fuel pump. It is located in the trunk behind the carpet paneling on the left. It is a about 3x3 with one plug connected to it. Try pulling the connector off and using some contact cleaner on the pins/sockets. There is also a way to test it with a multimeter, but im not sure exactly which pins to check...google it I know that if the fpdm is getting more than 10.5 volts coming in and the pump is not receiving said voltage, the fpdm is bad.
Old January 22nd, 2012, 12:16 PM   #6
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
9 out of 10 the FPDM committed suicide.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Old January 22nd, 2012, 06:55 PM   #7
Big Rob's Avatar
02 Mustang GT
Sounds good I'll look into this tomorrow, thanks guys
Old January 29th, 2012, 04:55 PM   #8
Big Rob's Avatar
02 Mustang GT
It was the FPDM, thanks again guys
Old January 29th, 2012, 05:30 PM   #9
dhicks7806's Avatar
2003 Mustang GT
No problem, happy to help! Reps? :shifteyes and what did you pay for a new one? If you don't mind...
Old January 29th, 2012, 06:12 PM   #10
Big Rob's Avatar
02 Mustang GT
I got a used one for $65 off of some dude on Craigslist. I don't really know how much they run for and it was the most convenient. However, some of the cables in the fuel pump assembly were holding onto dear life by a thread so I ended up changing the entire assembly which cost $230 I believe. Sucked, I had to take that away from the money I had saved for a blower
Old January 29th, 2012, 06:56 PM   #11
tyzride's Avatar
2002 Saleen S281-SC
tyzride is on a distinguished road
Sorry to hear about replacing the entire module. At least you found out the cause of the problem and got it resolved.
Threads Similar to: Fuel pump not working
8-9lbs boost gt500 fuel pump 47lb or 80lb fuel injectors? justin503 2005 - 2010 8 March 7th, 2011 01:41 AM
fuel gauge not working after fuel pum[ install starin 96-98 12 August 13th, 2010 08:16 PM
Boost-A-Pump or GT500 Fuel Pump? stanglifemike 2005 - 2010 64 September 21st, 2009 01:17 PM
Fuel pump question. Stock GT pump to GT (supercar) pump. Nate's4.6 99-04 15 May 14th, 2008 02:25 PM
